Old 09-13-2017, 12:24 AM   #141
humfrz
Originally Posted by guybo View Post
1) you don't use a socket with an impact gun- you use an impact socket
2) if you manage to hurt yourself with a breaker bar, you're doing it all wrong.
No, no, you don't understand ........ here is @Tcoat with his breaker bar .....
humfrz
Ultramaroon (09-13-2017)
Old 09-13-2017, 02:28 AM   #142
Spuds
The Dictater
Spuds's Avatar
Drives: '13 Red Scion FRS
If we are actually talking about tools you didn't know you needed, I'd recommend a large C-clamp and ball joint remover-clamp-thingy.
The Following User Says Thank You to Spuds For This Useful Post:
Old 09-13-2017, 02:54 AM   #143
Ultramaroon
fabulous
Ultramaroon's Avatar
A Dremel with a stack of cutoff wheels.
You're welcome.
Old 09-13-2017, 06:10 AM   #144
guybo
Huge E85 fan!
guybo's Avatar
Drives: 2016 Scion FRS
humfrz
OK OK OK, mine is only 24". With that set up I'd use a special socket. THAT is a hell of a breaker bar. When you use that one you have to be careful what direction you're pointed in because you may slow the earth's rotation down.
The Following User Says Thank You to guybo For This Useful Post:
humfrz (09-13-2017)
Old 09-13-2017, 07:43 AM   #145
I am just saying beware of the quality of cheap tools. Many cheap sockets are cast and if you try to use them on a breaker bar (even a 24" one) they will shatter or slip. If you have a socket shatter while pulling on a breaker bar you will get hurt I guarantee it. I am not saying run out and buy Snap On tools but beware of cheap ones. There is a middle ground and it is better to buy that level.
Old 09-14-2017, 07:56 PM   #146
LudwigMiles
Drives: '13 BRZ
I've used my C-clamps to press the calipers back during a pad change.
What else have you used it for?
You've already changed your ball joints ?
LudwigMiles is offline   Reply With Quote
Old 09-14-2017, 08:32 PM   #147
Spuds
The Dictater
Spuds's Avatar
Nope. The ball joint remover is for replacing wheel lugs when the air tool torque monkey inspection guys destroy them.
Also, while I'm at it, a torque wrench is very important too.
Search this Thread:
Advanced Search
Trunk kit with tools MicheleAbbate Mechanical Maintenance and Tools 1 09-06-2016 02:55 AM
Tools huynh_FRanciS Other Vehicles & General Automotive Discussions 7 03-18-2016 06:36 AM
Tools and their uses CoupedUpSubie DIY (Do-It-Yourself) Guides 17 12-20-2014 03:50 AM
Tools? Gost Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 35 04-03-2013 04:46 PM
talk me out of buying other cars and wait for the 86! mokinbird87 FR-S / BRZ vs.... 68 02-13-2012 07:53 AM
