#43 |
Drives: 2014 Subaru BRZ Limited 6MT SSM
#44 |
Rust bucket enthusiast
I second Apex's thoughts; that sounds like a lubrication issue when it's cold. Fluid change! The bonus with a fluid change is learning to service your own vehicle and seeing the running condition of your new car with your own eyes (should you choose to do it yourself)
#45 |
Drives: 2017 Subaru BRZ PP, 2016 Subaru WRX
Thanks for the tip. When I drove the BRZ yesterday I had zero grind, even cold. Buttery smooth. Granted, it was 100 degrees yesterday. I've been doing a lot of reading on this issue on these forums. Some mention altering shift technique for 2nd gear so I'll give that a try first. Maybe it's just me.
#46 | |
fabulous
Thinner fluid is nice but it gets noisy. I hear more neutral rollover with Redline MT90.
#47 | |
http://www.ft86club.com/forums/showthread.php?t=62288 |
#48 | |
fabulous
#49 |
Drives: 2017 Track Ready Limited Edition
Just FYI removing the lockout plate eill NOT allow it to be removed. There is another plate under neath that.
The comment above about shifting too fast is also correct. Smooth shifting is an equation between the lubrication and design of the synchros. Shifting too fast alsobwears out the gates as well as synchros extremely fast not to mention placing stress on shift forks and even the rods. I have the 2017 toyota 86 limited edition and i have installed the japanese TRD short throw shifter. There is a BIG difference between a short shifter and a short throw shifter. Over modifying a vehicle is quite common when individuals start bolting on aftermarket gear. Each to their own of course but i can vouch for all the TRD stuff that OEM in fitment quality and that it enhances the attributes of the car, not change them. I have written a review on a few TRD products on this forum. Hope this helps Sent from my SM-G955F using Tapatalk |
| Slight pull to the left on accel, pull to the right on decel | mightaswell | Issues | Warranty | Recalls / TSB | 18 | 01-12-2021 08:50 PM |
| Fender pull | pleong | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 3 | 11-30-2014 12:59 AM |
| If they Pull The Plug | exam2300 | Scion FR-S / Toyota 86 GT86 General Forum | 18 | 06-26-2014 12:59 PM |
| Datalogging 2nd gear pull? | 1Cor10:23 | Software Tuning | 11 | 04-04-2014 02:42 AM |
| Help about to pull the trigger.... | JerryMichaels7 | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 12 | 02-25-2014 07:12 PM |
