#29 | |
![]() humfrz |
#30 |
Reformed
Drives: '23 GRC, '11 Prius, '04 RAV4
I'm still quite confused where the actual problems are on OP's car? I've still yet to read anything regarding mechanical failure or even hindrance.
#31 | |
could be an axle nut or catastrophic engine failure, guess the dealership decided to replace the engine
#32 |
Drives: 2017 WRB BRZ
| The Following User Says Thank You to MyGT86Yas For This Useful Post: | strat61caster (10-05-2017) |
#33 |
Reformed
still confused how your tranny issues had anything to do with the engine. just difficult to see it being an issue with a facelifted 86 and not user error. too bad you don't have a video showing of you shifting "normally" and showing the stick popping out.
#34 | ||
Does the car have a short shifter in it? The TRD short shifter is known to be problematic and improper install can screw up shifting noticeably. You'll have to be patient with the skepticism, I've never seen anyone claim to have an 86 that's popped out of gear and I've beat the hell out of mine without repercussion as have many others. Abnormal noises come and go, it's hard to tell what's going on based on text description alone. Get that foreman and tech a case of beer when your car is healthy again, they're going the extra mile to get your car fixed even if we're all skeptical of what the hell is going on with your car. |
| The Following User Says Thank You to strat61caster For This Useful Post: | Ultramaroon (10-06-2017) |
#35 | |
#36 | |
This foreman in Orange is super nice and helpful. He did take an extra mile to help me on this issue. He spent half an hour test driving with me to hear the noises that I was complaining about
| The Following User Says Thank You to MyGT86Yas For This Useful Post: | Ultramaroon (10-06-2017) |
#37 |
fabulous
Much better rundown in your update. If we're talking about the retaining clips for the throwout bearing, The loose spring theory makes sense. Drawing a mental line between cause and effect, I can see where a loose one could allow the fork to knock back and cause some sponginess. Then it becomes a simple case of dragging clutch.
I just hope you get it all worked out. You have some great support in that dealership you're with. I agree with Strat that a case or two of beer is in order after the dust settles.
#38 |
I talked to the foreman last week and the latest information I got was:
The head casing was inspected and pressure tested and will be re-used in the new engine. Other than that part, all other parts are new (block and the upper half) and the whole engine is assembled at the dealership. I was told that they should have the car ready and thoroughly inspected by tomorrow, will let you guys know if that actually fix the problem. |
#39 | |
#40 |
They broke the injector seals when assembling the engine. If the injectors are not in back order I should have the car back tonight...should...
#41 |
Not sure if this is something I should worry/complain about, I can clearly see the carbon build-up in the head casing (they told me they gonna reuse it) but I was told it was supposed to be a brand new engine...
![]() Sent from my iPhone using Tapatalk |
#42 |
And Toyota decided to lemon my car
| The Following User Says Thank You to MyGT86Yas For This Useful Post: | Ultramaroon (10-17-2017) |
| Engine/Transmission noise | N1rve | Issues | Warranty | Recalls / TSB | 48 | 05-06-2018 11:17 PM |
| 17' manual transmission noise | dostoyevsky | Issues | Warranty | Recalls / TSB | 16 | 04-15-2017 04:49 AM |
| Transmission Grinding Noise | RedFR-s | Issues | Warranty | Recalls / TSB | 18 | 07-06-2016 03:18 PM |
| Automatic transmission noise. | zxzr750 | Engine, Exhaust, Transmission | 0 | 10-21-2014 06:58 PM |
| transmission noise when reaching 23-25m/h | Mokiki | Issues | Warranty | Recalls / TSB | 7 | 05-09-2013 10:13 PM |
