#29 |
Drives: Toyota GT86 Coupe Red (UK)
I managed 340 before chickening out and filling up. The total that day was 374 which I probably would have made on the tank without filling up, but didn't want to risk it.
400 would be tough, would need to be 95% highway / motorway.
Trunk = Boot | Hood = Bonnet | Sidewalk = Pavement | Transmission = Gearbox | Stick/shifter = Gear knob/stick | E-brake = handbrake | Windshield = Windscreen | Turn signal = Indicator
#30 | |
1st86 Driver!
Based on my usage, I look at 300 tank refills. Assuming that 13.2 US gallons is the usable fuel in the tank, I calculated the remaining miles to empty for each tank based on its MPG calculation. Out of those, 186 would have been over 400 miles before empty, the max being 483 miles, most well over 400. The minimum was 383. About 80% of these are from my standard commute (40.1 miles one way, usually takes me about 60 minutes, so avg about 40MPH but divided at about 80% at 55MPH and 20% at 0 to 35MPH).
![]() Visit my Owner's Journal where I wax philosophic on all things FR-S Post your 86 or see others in front of a(n) (in)famous landmark. What fits in your 86? Show us the "Junk In Your Trunk". |
#31 |
I drive 682-720 miles a week. This is 98% highway with cruise set at 75MPH. I fill up once a week one week and then twice in the following week (just how the numbers work out I guess). I have never paid attention to how many miles I get out of a tank but would guess that I easily get 400 on a regular basis since I usually let the tank get almost empy. I will have to watch over the next few weeks and confirm or retract this statement.
| The Following User Says Thank You to Tcoat For This Useful Post: | Dadhawk (08-25-2017) |
#32 |
#33 |
I think I usually get between 250 and 280 a tank, but a lot (most) of my day-to-day mileage is stop and go traffic commuting.
On long road trips I regularly see 320 or higher. Usually those are starting after a tank with a few days commuting on it though. On "usable" fuel. Does anyone know the amount of "tank" fuel the GT86 has? "Tank" fuel being fuel that cannot be pumped and is fuel for the tank itself effectively? (I take the term from aviation). The 2017 has a "Miles to go" before empty and I determined it zeros out at around ~5 litres (1 UK gallon) remaining. However I doubt all of that could be pumped, so when it says zero... how far will it really go? Another 20? 30? miles?
#34 |
Out of interest, over here, running out of fuel on the motorway is a traffic offense. You can actually be done for running out of fuel on the motorway as it's fairly dangerous for you to suddenly decelerate without brake lights. Fine on other roads, but the motorways have special laws.
#35 |
Drives: '17 Toyota 86 6MT
Our consumption computer is a giant liar, btw. I record/reset every tank and math it, along with keeping track of the delta between actual and displayed MPG. My FR-S averaged 1MPG higher display than actual for 100-ish fill-ups, 86 so far is .8MPG higher on average, with some tanks being +1.8. I fill up at the same station 90% of the time.
Also, the more I baby the car, the more egregious the lie (my "35MPG" displayed results in 33.1 actual, while 25MPG displayed is 24.5-ish). Lies
'17 Halo 86 6MT
#36 | |
#37 | |
It's horrible at measuring amount of injected fuel when I'm in 6th gear going 30mph it seems.
'17 Halo 86 6MT
#38 | |
#39 | |
1st86 Driver!
| The Following User Says Thank You to Dadhawk For This Useful Post: | Tcoat (08-25-2017) |
#40 |
1st86 Driver!
That's a tough one. From what I've read in the past most (but not all) auto manufacturers list it based on useable fuel but it is an average calculation and can vary by as much as 3% between cars of the same model due to manufacturing "sloppiness" in the tank. Probably more common in metal tanks than non-metal ones.
#42 |
Yep. But it hides the difference in efficiencies between engine braking in 6th with 0 fuel flow and coasting clutch down (or neutral) which consumes "idle" fuel.
To eco-mile, if you need to slow anyway use engine braking in the gear that will get you that deceleration. If you are trying to sustain speed, use neutral. If you free wheel in neutral to a stop the 127mpg starts to decrease and register around 20mph. The real test of fuel efficient driving in my book is not how far you can go on a tank, but how high you can get the MPG in rush hour traffic. Takes an awful lot of concentration to get it above 40mpg. (UK gallons) (33.307MPG US gallons) This morning I eco-miled to work and back. When I left the house the miles to go said 24. It's 12 miles each way to work. When I got home it read 7 to go. Average for the tank was 30mpg. So I significantly exceeded that today, seeing 45MPG (37.5 US MPG) for a while on the way to work, till I hit traffic.
| MT to AT swap? Doable or craziness? | Dfyfzx | Engine, Exhaust, Transmission | 46 | 02-13-2017 12:34 AM |
| Is this project doable? (My dream build) | Taisenki | Cosmetic Modification (Interior/Exterior/Lighting) | 17 | 10-30-2014 12:24 AM |
| Cautionary tale (not my car) boost can be a huge PITA too, its not all red roses..... | Sportsguy83 | Forced Induction | 208 | 10-11-2014 12:30 AM |
| Is this DoAble? | poptopclk | Forced Induction | 22 | 06-20-2014 09:15 AM |
| POST YOUR 1/4 MILE TIMES Quarter mile times | NYCsubaruBRZ | Tracking / Autocross / HPDE / Drifting | 1 | 02-04-2014 07:59 AM |
