#29 |
Geo Tyrebighter Esq
Drives: '13 scion fr-s
This is how I package the random stuff I take along to keep it from sliding around loose.
Some anti slip matting keeps the box from shifting. Have a breaker bar in it, but the scissors jack seems adequate.
"I gotta rock." -- Charley Brown |
#30 |
Drives: Frs
I figure that the 20lbs of crap I carry is offset by the weight ive lost with mods...also...id rather be .0001 slower to 60 than without something I need.
JDL UEL Turbo GT2860RS, AP Racing BBK, Verus Splitter/diffuser/canards, Sard rep carbon wing, TFF bash bar, HKS hi power, Tein Flex A, Hotchkiss FSB, Radium MCB, Konig Hypergram 17x8, FS Indy 500, 6k HID, Whiteline trans bushing insert, Verus AOS, grimmspeed strut brace, Racerx oil cooler w/ setrab 619, ES steering rack bushings, Whiteline subframe bushings, Toms tails, STi mirror caps, IRP shifter, TRD Steering wheel
#31 |
If you keep it in the cabin find a way to secure it, otherwise it's a projectile in the event of an accident.
I don't carry anything with me other than the stock tools, but am not usually that far from home or a phone call way from a friend. I think I have roadside assistance through insurance but I've never used it
#32 | |
I'll echo the other comments though, you really shouldn't need a breaker bar to get your lug nuts off. They're only supposed to be torqued to 89 ftlbs. |
#33 |
i keep a breaker bar and socket with my wheel locks but not so I can do a tire change on the fly but because I keep losing them LOL, I also have a tire inflator and booster cables in all my cars
2013 Whiteout FRS 6MT with a JRSC @ 301 WHP
![]() 2023 Ignition Red BRZ 6MT |
#34 |
Drives: '87 Buick GN, '16 500 Abarth
Years ago one of my vw's came with these plastic cargo blocks with Velcro on the bottom- you could link them together to make walls/blocks in the trunk. When I traded the car in I kept them and move them to each new car. Super handy, I think they sell something similar on Amazon.
Past Rides: '87 Mazda 626 with junkyard turbo, '86 Fiero SE v8 swap, '87 Fiero GT v8 swap, '87 Grand National, '96 Nissan Maxima (s/c), '04 Dodge SRT-4, '08 VW Rabbit 5cyl, '10 VW Golf 5cyl.
Current: '87 Grand National '16 Fiat 500 Abarth (dumb, immature fun!!) Shopping for a BRZ/'86 right now as an additional toy. Last edited by fierostetz; 08-24-2017 at 01:52 AM. Reason: Absurd autocorrect results lol |
#35 |
THE CORVETTE KING!
Drives: 2013 FR-S, and 2016 FR-S!
Just Smith&Wesson for me!
2013 Scion FR-S.
2005 Corvette. |
#36 |
So you can force somebody else to change your flat?
| The Following 2 Users Say Thank You to Tcoat For This Useful Post: | extrashaky (08-28-2017), Qadthane (09-01-2017) |
#37 |
Drives: 2017 Ice Silver BRZ Limited
#38 | |
Drives: 2014 BRZ Limited
I've had my dash apart trying to redesign my homemade phone mount and put the dash trim pieces behind the seat and forgot about them. Then I took a couple of hard turns and heard crap tumbling around behind me. Sure enough, now they have nicks and scratches. |
#39 |
Huge E85 fan!
Drives: 2016 Scion FRS
6:30 AM, I forgot I had my coffee mug kind of wedged into the door pocket one morning on the way to work. It has a lid but I must not have closed the sippy opening. There's this one light when I get off the highway- you go down a hill and take a left through a very wide open intersection- and the light was about to turn so I punched it and kind of drifted through the intersection (oops!
) because there was no one else around. And I have an FRS.Talk about projectiles! I counter steered and the rear end whipped into shape and I got a hot projectile splashing on my junk. Not burn hot but get your attention hot. Luckily I wear dark blue shorts at work but I was wearing that fucking coffee all day long. I smelled fabulous. |
#40 |
Weight Weenie
Drives: 15 FR-S
A long time ago I used to carry tons of tools and about every external part needed if an alternator crapped out, water pump went, broken belt, etc. It was easy and needed seeing as I drove junk.
Today, I carry a cell phone and CAA and have emptied out the junk in the trunk. That said, I'm never far from a major centre. |
#41 | |
In the trunk at all times: Trolley jack Breaker bar 200 piece tool set (mechanic grade) Assorted v belts 2 gallons of prestone and water mixed Can of either quick start Dozen or so assorted fuses (the little round glass ones) Assorted 12 volt twist in bulbs Spare set of wiper blades (the vacuum powered wipers tended to fling them into space) Brake fluid WD40 (gallons of the stuff to dry the plug wires when it rained) Spark plugs (in case the WD 40 wasn't enough) A spare manual choke cable (They had to bend in a weird direction and broke often) At least 3 quarts of oil Tow rope And... At one point a spare clutch which I ended up installing in a field on the side of the highway since I sucked at guessing how long the old one would last when it started to chatter.
| The Following 2 Users Say Thank You to Tcoat For This Useful Post: | NeverInTime (08-28-2017), new2subaru (08-28-2017) |
#42 | |
I keep a long handled 1/2" ratchet with a 19mm socket in the car anyway because that's the size for the hitch bolt for my bike rack. I like to check that it's snug sometimes on long road trips because I usually have a couple of thousand dollars worth of bikes back there. |
| The Following User Says Thank You to gravitylover For This Useful Post: | Tcoat (08-28-2017) |
| Tie Breaker! | ichitaka05 | Announcements, Contests, Giveaways | 1 | 07-07-2016 06:42 PM |
| WTB: Low profile floor jack and jack stands! | lupindub | Want-To-Buy Requests | 2 | 11-27-2015 12:03 AM |
| RCE Yellows, WRX Rear Sway bar, trunk jack | Keenercarguy | Want-To-Buy Requests | 2 | 10-31-2015 05:14 PM |
| Osram Night Breaker Plus & Others | Aznek | Cosmetic Modification (Interior/Exterior/Lighting) | 1 | 11-18-2012 10:14 AM |
