86WORX
Old 08-15-2017, 06:33 PM   #15
e1_griego
e1_griego's Avatar
Drives: Many
Well ok. Most people stopped having problems when they added a radial bearing.
Also solvable with square threads, but obv. all of the one-piece setups use tapered threads.
e1_griego is offline   Reply With Quote
Old 02-15-2022, 03:29 PM   #16
Scargod
Track Day Junkie
Scargod's Avatar
Drives: 2022 BRZ Limited
I like a lot of what you have posted but you lost me with this comment. Please explain.
Also, not directed at you particularly, but have people not heard of anerobic thread-locker or even the ones that don't harden or the ones that are like fingernail polish? Personally, I like running the thrust bearings. My MCS have them and are easily adaptable to any coilover. I've never had anything loosen on me.
Scargod is offline   Reply With Quote
Old 02-15-2022, 05:33 PM   #17
e1_griego
e1_griego's Avatar
Drives: Many
Coilover bodies with square threads usually just run a single collar instead of double locking collars, sometimes with a set screw or a pinch bolt. Like ground control sleeves. Once you have weight on the spring they never loosen up in my experience, even without the set screw or pinch bolt tightened up.
The tapered threaded bodies tend to run locking collars, and, especially without the inclusion of a radial bearing, can loosen up the spring perch.
Also just to note: you're digging up posts from 5 years ago.
The Following User Says Thank You to e1_griego For This Useful Post:
timurrrr (02-15-2022)
Old 02-23-2022, 09:14 AM   #18
obito.frs
team TEMPEST
obito.frs's Avatar
Drives: 2015 Scion FR-S
Everybody makes mistakes, after I installed my coilovers in my buddy's driveway at 2 AM the next day I realized the weight of the car was the only thing holding in the upper strut flange bolt and that the nut was completely missing. Quick fix but could have been real bad. Always check and recheck!
"I don't want to regret the way I lived"
obito.frs is offline   Reply With Quote
Search this Thread:
Advanced Search
Coilovers Coilovers, Coilovers: Tein, KW, BC, D2, Cusco, Eibach + more FREE SHIPPING! No Limit Motorsport Brakes, Suspension, Chassis 204 05-26-2017 01:09 PM
Help! From check engine light to fouled plugs back to check engine + plugs refouling larchamb Issues | Warranty | Recalls / TSB 44 04-03-2016 10:39 AM
WTB: Ksport Control Pro Coilovers or BC Racing Extreme Low Coilovers ProjectBrz Brakes, Suspension, Chassis 1 04-15-2014 01:21 AM
* BC Racing BR Coilovers & Stance Super Sport Coilovers | IN STOCK | FAST SHIPPING * Speed Element Brakes, Suspension, Chassis 21 03-03-2014 09:56 PM
FS: (IL) KW Variant 3 coilovers and Stance Super Sport Coilovers ill roller Brakes, Suspension, Chassis 5 12-14-2013 04:02 PM
