Old 03-22-2018, 05:35 PM   #1065
cjd
cjd's Avatar
Drives: 2017 BRZ
Or...
Come to STX. We have aftermarket endlinks. No guarantees they won't suck too.
The Following User Says Thank You to cjd For This Useful Post:
G_Ride (03-22-2018)
Old 03-22-2018, 05:37 PM   #1066
14stu
14stu's Avatar
Drives: 2014 Subaru BRZ
I always thought that it was strange that SSC couldn't use aftermarket endlinks, every other class where you can change sway bars they let you do endlinks as well (which makes sense since the OEM endlinks weren't designed to work with anything other than the OEM swaybars).
Write your letters, write them often, and write them know that I stand beside you in your struggle against the tyranny of stock endlinks!
14stu is offline   Reply With Quote
Old 03-22-2018, 05:37 PM   #1067
Lex_K
Drives: 987S, e46, mkv, frs
Originally Posted by M0nk3y View Post
I think Lex is just doing logical thinking.
Introduce endlinks and it goes down a rabbit hole, IMO.
This is no different than say people that ran Hoosiers on HS Minis and tore through them in 15-20 runs. They simply just dealt with it.
That and the tune... Yes, limiter sucks, so just shift if you stay on it too long. A lot more fun that way.
Lex_K is offline   Reply With Quote
Old 03-22-2018, 06:13 PM   #1068
BoxCarRacer
Drives: 2014 Scion FRS
I am curious if this KC person may have damaged his endlinks when crashing in straight line on highway and that could be part of the issue.
BoxCarRacer is offline   Reply With Quote
The Following User Says Thank You to BoxCarRacer For This Useful Post:
Lex_K (03-23-2018)
Old 03-22-2018, 06:45 PM   #1069
Twinz
Twinz's Avatar
Drives: 2016 FR-S MT, 2015 Scion FR-S AT,
This is what I have for spares. No grease fittings.
Twinz is offline   Reply With Quote
Old 03-23-2018, 08:56 AM   #1070
steverife
Drives: 2016 Scion FRS
Originally Posted by Lex_K View Post
Because it takes an engineer to take them off and put them back on, albeit, at a little angle in the rear... So much concern, yet no reported cases of failure and the kit has been on the market for years.
I mean, nobody was really complaining that much.
KC had an unexpected issue with the install. ...and we discussed OE equivalents. Yeah, you can get them off a variety of ways, but if you want to adjust between runs, not dealing with rust and maybe an allen wrench would be nice.
With that said, end links is probably the only other mod I'd endorse. Under non-spec class circumstances, I'd never accept endlinks at that angle.
steverife is offline   Reply With Quote
Old 03-23-2018, 09:05 AM   #1071
Imp
Bring out your dead
Drives: '14 BRZ (SSC), '00 S2000
I'm curious who you are... Because there were other factors, 1st of which... that was a different car.
--kC
(Appears I have a stalker!!!)
K. Casey | NER SCCA | SSC - '14BRZ For Sale
Imp is offline   Reply With Quote
Old 03-23-2018, 09:39 AM   #1072
BoxCarRacer
My name is Wes. Was unaware different car sir.
Old 03-23-2018, 10:40 AM   #1073
Imp
Bring out your dead
Who you callin' sir, man?
--kC
(Understanding that can be ridiculed, I am male)
Old 03-23-2018, 01:33 PM   #1074
imhereforthecar
Drives: FRS
All of this talk about endlinks... I won't be able to install the SSC parts until days before the first event in my region. Should I prepare for the worst and buy some replacements so I'm not scrambling? Is it that big of an issue with these cars?
imhereforthecar is offline   Reply With Quote
Old 03-23-2018, 01:57 PM   #1075
14stu
14stu's Avatar
The OEM endlinks are highly rust prone. I was unable to remove either the fronts or the rears due to rust when my car was less than a year old and had never seen a winter.
If they aren't rusted so badly that you can't get an allen key into them, then you should be fine.
Old 03-23-2018, 02:12 PM   #1076
Imp
Bring out your dead
Yes. Have spares ready to go. You can always sell them or return them if not used.
And they will sell to other SSCers that DO have rusted ones.
--kC
Old 03-23-2018, 02:15 PM   #1077
JakeRogue
JakeRogue's Avatar
Drives: 2014 Monogram FR-S
--kC
How big a deal is this end link thing?
JakeRogue is offline   Reply With Quote
Old 03-23-2018, 04:33 PM   #1078
BoxCarRacer
The rear endlinks are at a pretty ridiculously lousy angle. I had called Eibach about it and they say that they are FINE. All that accomplished is make me think Eibach is a little more clueless than they let on.
Upgrading brakes on the lower spec GT86 (the standard spec outside of US market) OnionTou Suspension | Chassis | Brakes -- Sponsored by 949 Racing 55 07-01-2016 02:36 AM
what's the difference between twin screw, centrifugal, single turbo and twin turbo? warplane95 Forced Induction 86 04-17-2014 03:36 PM
my twin RWDGUY Mid-Atlantic 2 04-08-2013 10:23 PM
JDM Spec-C V9 Twin Scroll VF36 complete Nico TURBO Engine, Exhaust, Bolt-Ons 0 12-05-2012 12:20 PM
