86WORX
Old 11-22-2017, 12:45 PM   #687
Lex_K
Drives: 987S, e46, mkv, frs
Based on the new fastrack, looks like all twins in DS will be in SSC very soon...
Lex_K is offline   Reply With Quote
Old 11-22-2017, 12:47 PM   #688
blkwrxwag
Drives: DS FRS
Whilst a lot of that is a proposal for 2019, the 2017 Twins and CTR are effective to DS in 2018. Makes SSC for 2013-2016 Twins a no brainer.
-Max H.
blkwrxwag is offline   Reply With Quote
Old 11-22-2017, 12:56 PM   #689
snoxracer183
Drives: 2014 FR-S SSC
Originally Posted by Ribface View Post
Look like the Konig Dekagram might not be an option after all.
The specs section has been updated and list a wheel weight of 16.66lbs for the 17x8 5x100 ET40
https://konigwheels.com/wheels/flow-...eels/dekagram/
Sounds perfect. I'll duct tape some wheel weights in the center cap if I have to
snoxracer183 is offline   Reply With Quote
The Following User Says Thank You to snoxracer183 For This Useful Post:
Shark_Bait88 (11-26-2017)
Old 11-22-2017, 01:15 PM   #690
Ribface
Drives: 2014 FR-S Hot Lava
Hmm center caps are not included in weight rules. Might be worth a letter for clarification.
 Minimum Weight, without spacer if used (lbs.): 17, including:
• Wheel weights
• TPMS sensor if installed
• Tire valve stem (type unrestricted)
Ribface is offline   Reply With Quote
Old 11-22-2017, 01:16 PM   #691
snoxracer183
Thats why i'm using wheel weights
Old 11-22-2017, 01:50 PM   #692
Lex_K
Anyone actually weigh in a 949 wheel? best looking option imo and et40. FT Speedfactory lists them at 16.6
http://www.ft86speedfactory.com/949-...l#.WhWtqlWnFaQ
Old 11-22-2017, 01:55 PM   #693
Ribface
That would be my top pick too but they are listed as 16.1 lbs on 949 website.
Look like the Konig Ampliform will also come in our size but no communicated weight yet.
Old 11-22-2017, 05:28 PM   #694
Lex_K
I have to say I am somewhat frustrated with the lack of et40 wheels that meet the criteria. Seems like someone should have done the research prior to making this rule. Konig Ultraform is plain ugly, but it may just be me, I hate flat faced spokes. I think if they update the rule to go down to 16lbs, a number of options would open without driving the cost up. Hypergram and Dekagram are so much better looking.
Old 11-22-2017, 06:25 PM   #695
strat61caster
strat61caster's Avatar
Studs + spacers are readily available, no different than maximizing performance in street class playing with +/-7mm offset from OE where some cars have a plethora of options and others are hosed.
If anything, +40 may hinder the performance of the class if that's what's limiting maximum camber.
It does suck that the minimum weight excludes some popular options like Enkei, 949, OZ, Wedsport, etc. unless you're comfortable taping a pound of weights to each wheel.
ineedyourdiddly
Old 11-22-2017, 07:20 PM   #696
tony_r
tony_r's Avatar
Drives: '15 STX
The amount of camber we are able to achieve at +40 is acceptable.
Wheel choices do suck at the moment if you're looking for a one stop shop for max class allowance. Specs were definitely skewed to give TRM's an advantage vs others. If 15 or 16lbs was chosen, would have become a spec wheel in the Enkei or 949 offerings.
tony_r is offline   Reply With Quote
Old 11-22-2017, 09:09 PM   #697
iLuveKetchup
My VTEC fluid is full
iLuveKetchup's Avatar
Drives: EFF JAY
The TR FF10s +40 will be available Feb '18 per site. Not the prettiest but low cost. Would be nice if they offered a black option.
iLuveKetchup is offline   Reply With Quote
Old 11-22-2017, 09:28 PM   #698
strat61caster
Don't fight the stereotypes, embrace them...
ineedyourdiddly
Old 11-22-2017, 11:02 PM   #699
Imp
Bring out your dead
Drives: '14 BRZ (SSC), '00 S2000
Originally Posted by Twinz View Post
I have seen the class referred to as the "special snowflake class"
Well, I think I know the hood decal, and maybe the number roundel background...
--kC
Imp is offline   Reply With Quote
Old 11-26-2017, 06:41 PM   #700
Charlie Davis
Drives: STX BMW 325is, STR NB Miata
What are the current thoughts on 18 lb. exhausts?
Charlie Davis is offline   Reply With Quote
Search this Thread:
Advanced Search
Upgrading brakes on the lower spec GT86 (the standard spec outside of US market) OnionTou Suspension | Chassis | Brakes -- Sponsored by 949 Racing 55 07-01-2016 02:36 AM
what's the difference between twin screw, centrifugal, single turbo and twin turbo? warplane95 Forced Induction 86 04-17-2014 03:36 PM
my twin RWDGUY Mid-Atlantic 2 04-08-2013 10:23 PM
JDM Spec-C V9 Twin Scroll VF36 complete Nico TURBO Engine, Exhaust, Bolt-Ons 0 12-05-2012 12:20 PM
