86WORX
Old 11-17-2017, 04:51 PM   #645
Twinz
Twinz's Avatar
Drives: 2016 FR-S MT, 2015 Scion FR-S AT,
Originally Posted by tony_r View Post
Close to -3.5 with +40.
Maybe with tires that don't run as wide as the Rival S's.
I think this was -2.9 40mm offset Ultraforms:
Twinz is offline   Reply With Quote
The Following User Says Thank You to Twinz For This Useful Post:
snoxracer183 (11-17-2017)
Old 11-17-2017, 05:07 PM   #646
tony_r
tony_r's Avatar
Drives: '15 STX
Yep, with a Rival S' on the Advanti Storm S1 + 5mm spacers.
tony_r is offline   Reply With Quote
Old 11-17-2017, 05:43 PM   #647
Twinz
Twinz's Avatar
If I add another .5 degrees of negative camber, the tire will be all over the suspension.
I suspect the discrepancy is between our measuring equipment. I'm not to concerned about it though. We will all be running the same struts, springs and tires. Minimum clearance should pretty much be the same from car to car, so real camber up front should be in the noise between cars.
Old 11-17-2017, 05:50 PM   #648
tony_r
tony_r's Avatar
Drives: '15 STX
You doubt Scott Fraser's alignment rack!?!?! /s
Could be a number of things. Different wheels change some measurements for sure. Lip can make the tire narrower or raise the location a hair. Plus the inclusion of spacers might change things ever so slightly, as well.
Spec isn't always spec, lol.
Old 11-17-2017, 05:55 PM   #649
Twinz
Twinz's Avatar
Got a pic of your clearance?
Old 11-17-2017, 06:55 PM   #650
iLuveKetchup
My VTEC fluid is full
iLuveKetchup's Avatar
Drives: EFF JAY
I’m running -3.6 on +40 with Nexens.
iLuveKetchup is offline   Reply With Quote
Old 11-18-2017, 11:35 PM   #651
solort
Drives: Series 10 FRS
What is the wheel offset? And what is the wheel offset rules for Spec Twin? Can you go + or -7mm offset and use spacers?
solort is offline   Reply With Quote
Old 11-19-2017, 12:09 AM   #652
edj
edj's Avatar
Drives: 2022 Toyota GR86
40mm or greater offset
can use spacers to get there
Eric
2022 Toyota GR86 Steel
edj is offline   Reply With Quote
Old 11-19-2017, 12:46 AM   #653
rande
rande's Avatar
Drives: Spyder, MR2, FRS, Tundra
Are the spacer counted as wheel weight?
rande is offline   Reply With Quote
Old 11-19-2017, 01:21 AM   #654
iLuveKetchup
Drives: EFF JAY
Weight of the spacers cannot be counted for the weight of the wheel.
On another note, do you guys have issues with the SPC LCA unable to hold camber? It seems to go out of alignment spec easily.
Old 11-19-2017, 04:51 AM   #655
tony_r
tony_r's Avatar
Drives: '15 STX
I was worried that might be a thing. Probably have to over torque to the eccentric like the Miatas.
Our car looks like the RR toe is out of place, mean to check it soon. Might have the same issue.
Old 11-19-2017, 12:13 PM   #656
Radster
Radster's Avatar
Drives: 2014 FR-S
Oil cooler!
"We have some news coming out of the SEB Face to Face meeting this weekend.
Doug will post an updated version of the SSC rules this week.
Two changes
Exhaust - The minimum weight will remain as written.
The follow lines will be REMOVED
Material for cosmetic exhaust tips is not restricted.
Track pipes” and “straight pipes” are not allowed.
The following line will be ADDED;
An engine oil cooler may be added."
Also, spec tire announcement eta mid-january
Was just posted on the FB group.
Radster is offline   Reply With Quote
The Following 3 Users Say Thank You to Radster For This Useful Post:
blkwrxwag (11-19-2017), strat61caster (11-19-2017), Twinz (11-19-2017)
Old 11-19-2017, 07:26 PM   #657
tigermack
STX 188
tigermack's Avatar
Drives: STX BRZ
Send a message via AIM to tigermack
Why'd you need an oil cooler? lol
tigermack is offline   Reply With Quote
The Following User Says Thank You to tigermack For This Useful Post:
M0nk3y (11-20-2017)
Old 11-19-2017, 07:31 PM   #658
FirstWinter
Drives: Car
For people who track with one.
FirstWinter is offline   Reply With Quote
The Following 3 Users Say Thank You to FirstWinter For This Useful Post:
DaWorstPlaya (11-21-2017), JakeRogue (11-19-2017), Shark_Bait88 (11-19-2017)
Upgrading brakes on the lower spec GT86 (the standard spec outside of US market) OnionTou Suspension | Chassis | Brakes -- Sponsored by 949 Racing 55 07-01-2016 02:36 AM
what's the difference between twin screw, centrifugal, single turbo and twin turbo? warplane95 Forced Induction 86 04-17-2014 03:36 PM
my twin RWDGUY Mid-Atlantic 2 04-08-2013 10:23 PM
JDM Spec-C V9 Twin Scroll VF36 complete Nico TURBO Engine, Exhaust, Bolt-Ons 0 12-05-2012 12:20 PM
