Old 10-04-2017, 05:33 PM   #407
chucky12012
Drives: 2013 Asphalt Scion FR-S
Running the SSC setup this weekend. Honestly, all of the areas of heartburn and change are not going to really change the performance. I want some time with the car as soon as possible to get the shocks, bars and alignment set up so I don't end up fiddling with all of that through next year. I get waiting on the exhaust and even the wheels, but I got the TR wheels and will run the 5mm spacers, so I feel pretty safe there. We shall see. It would be nice if we had both the prepped STX twin and DS twin at our local this weekend for some perspective, but we'll see how that goes.
chucky12012 is offline   Reply With Quote
The Following 4 Users Say Thank You to chucky12012 For This Useful Post:
blkwrxwag (10-04-2017), Shark_Bait88 (10-04-2017), strat61caster (10-04-2017), Twinz (10-04-2017)
Old 10-04-2017, 06:02 PM   #408
iLuveKetchup
My VTEC fluid is full
iLuveKetchup's Avatar
Drives: EFF JAY
I'm also running SSC set up this weekend. Putting all parts in this Fri. There are great DS & STX drivers locally, but I'm no bench mark (reason I'm going SSC is to get my learn on).
iLuveKetchup is offline   Reply With Quote
The Following 2 Users Say Thank You to iLuveKetchup For This Useful Post:
Old 10-04-2017, 06:20 PM   #409
tony_r
tony_r's Avatar
Drives: '15 STX
Is there enough thread engagement to be safe?
tony_r is offline   Reply With Quote
Old 10-04-2017, 06:22 PM   #410
blkwrxwag
Drives: DS FRS
No, you will need extended lugs. 3mm is about the max you can go safely.
-Max H.
blkwrxwag is offline   Reply With Quote
The Following User Says Thank You to blkwrxwag For This Useful Post:
Old 10-04-2017, 06:42 PM   #411
Twinz
Twinz's Avatar
Drives: 2016 FR-S MT, 2015 Scion FR-S AT,
Originally Posted by JakeRogue View Post
16.94 lbs
I got a set of these after they clarified the as-raced weight and weighed them. With center caps and TPMS, they are 17lbs. -And that's before any balancing weights.
They make weight (as raced) and look nice, but the thick spokes pushed to the outer edge of the wheel do not make for ideal weight distribution. The FF10's are functionally better (if not as pretty) but require 5mm spacers to get the 40mm offset that will allow for maximum camber.
+1. I started setting up for CS last summer and didn't get the car right until November. I am not one of those people who can put parts on a car and have it just work well on my first guess. (If it ever happens it will be mostly due to dumb luck)
Originally Posted by TrqlessWonder View Post
The stage 1 kit is probably fairly safe, but the wheels have been revised once already, and no one has filled in the blank even on a preliminary level on the tires. We're not sure if a nameless-type exhaust would be allowed, and there's some confusion on the crash bolt/SPC bolt arrangement.
It's...um...fluid. It won't hurt me to put my credit card away for a bit. My next event won't be until April, and TR delivery is super-dee-duper fast.
I totally understand people's apprehension, (which is why I didn't mention the Konig's before) but in the SCCA's defense, all but one of the updates have just been clarifications. The only contradiction (the offset change) was fixed within a couple days, and put back to the original spec. So the only "revision" was quickly "un-revised".
I don't particularly like the exhaust clarification, and I wish the tire would have already been named, but for all the heat they are taking for the roll-out, it's been rather stable.
The suspension "kit" shipped yesterday. I'm all in now too.
Twinz is offline   Reply With Quote
The Following User Says Thank You to Twinz For This Useful Post:
bholliday (10-04-2017)
Old 10-04-2017, 07:53 PM   #412
strat61caster
strat61caster's Avatar
"All in"?
Worst case, class tanks, you've got three options.
1. Convert to DS (or whatever street class) lose a few hundred on parts from Eibach, SPC and wheels (keep the tires if the compound is good).
2. Start building towards STX (or ST*), wheels+tires+header+tune and you've got a decent >75% baseline build, you'll probably eat $1k or more to unload all the SSC stuff and build STX (on top of added cost for STX parts), but you always eat the cost of mods you don't keep forever (so most of them)
3. Dump the chassis and move onto the next hot street class car
Hardcore competitive guys already enter the class with option #3 accounted for, it's been years and there's always some change to Street class that bumps cars from competitive to not (RX-8, E36, 86, etc.), people more dedicated to the car than being competitive ASAP will have a taste of more mods (and complexity) and decide which direction to go in, Street vs. Street Touring.
Originally Posted by Shark_Bait88 View Post
If I were making a ruling on, as the rules stand now, I'd probably say that being a "track pipe" makes it illegal.
Moot point but I'm going to say it anyway:
"track pipe" has zero definition. I'll say OE exhaust is a 'track pipe' since I've tracked it, it's illegal now. Call everything a 'track pipe' call nothing a 'track pipe' it has no definition or meaning, it's a marketing label with certain connotations to certain people until there's a definition in the SCCA rulebook. It's good that they're changing it if this was potentially an argument at all.
A list of approved exhausts is better for sanity, but an ugly solution imo
Make the axleback a free for all (barring exotic materials), bolt on the nameless track pipe for the big event, bolt on preferred muffler of choice after for your eardrums.
ineedyourdiddly
Old 10-04-2017, 09:55 PM   #413
Jshreiner
Drives: Red frs and a few 90s celicas
I'm set on running in the class. I haven't purchased any parts yet but Tire Rack is only 30min from me so I could get my parts next day if I wanted. I too am waiting for final rule set before just incase something odd comes up.
For those hopping the class will solidify for next year then you will jump in all you are doing is lessening the chance of the class sticking around by not participating. If the numbers are not there then it will not last, even if not competitive purchase a few or even just one of the spec class options and come support the class in 2018.
Jshreiner is offline   Reply With Quote
The Following 2 Users Say Thank You to Jshreiner For This Useful Post:
iLuveKetchup (10-05-2017), Twinz (10-04-2017)
Old 10-04-2017, 10:57 PM   #414
edj
edj's Avatar
Drives: 2022 Toyota GR86
Rt would be nice if we had both the prepped STX twin and DS twin at our local this weekend for some perspective, but we'll see how that goes.
how much are you willing to pay for me to come down there and kick your butt?
Eric
2022 Toyota GR86 Steel
edj is offline   Reply With Quote
The Following User Says Thank You to edj For This Useful Post:
Shark_Bait88 (10-05-2017)
Old 10-05-2017, 11:10 AM   #415
chucky12012
Sounds like Eric is coming to Houston this weekend! We'll buy you lunch.
Old 10-05-2017, 11:12 AM   #416
chucky12012
As noted, you need extended studs to run the 5mm spacer, but I installed them a while back under preventative measures just in case. I had also at times played with 8mm spacers in DS with the Kosei's, but wasn't actively using those anyways.
Old 10-05-2017, 11:19 AM   #417
Locust
Custom User Title
Locust's Avatar
Drives: 2015 Scion FR-S, 2012 OB Evo X MR
Send a message via AIM to Locust
The class isn't going to live and die on a few of us who have decided not to make the switch. If it takes that many people to make the difference then it's on life support already anyways. And if it doesn't make it then it doesn't make it. I'd like to see it become a permanent class but after spending money for two years to prep for CS/DS and then have 99% of the stuff I bought become disallowed in spec class I'm not ready to jump to a class that may or may not be there the year after.
LOCUST
2015 FR-S (STX) and 2012 Evo X MR
Instagram:
LocustAutoX
Sponsors:
DSGPerformance Drift Office Evil Apex Racing
Locust is offline   Reply With Quote
The Following 2 Users Say Thank You to Locust For This Useful Post:
CCJ (10-06-2017), DaWorstPlaya (10-06-2017)
Old 10-06-2017, 02:29 PM   #418
iLuveKetchup
Drives: EFF JAY
Have an issue with the front Koni struts. There is too much space between the spindle & strut attachment point. There is about a 1/4" gap.
https://www.flickr.com/gp/iluveketchup/z6Fh81
Old 10-06-2017, 02:33 PM   #419
CHDavis
Drives: E/S Miata STX BMW 325is
I would not be surprised if it passed supplemental status and went straight to National status very quickly.
But what do I know?
Charlie Davis
CHDavis is offline   Reply With Quote
The Following 2 Users Say Thank You to CHDavis For This Useful Post:
G_Ride (10-08-2017), Jawnathin (10-08-2017)
Old 10-06-2017, 02:37 PM   #420
blkwrxwag
Drives: DS FRS
Call Lee Grimes at Koni and show him that picture. I don't remember that when I installed my OTS Konis earlier this year, but maybe when you just tighten the bolts, it goes away. I would call Lee first though. (859) 586-4100
-Max H.
strat61caster (10-06-2017)
Upgrading brakes on the lower spec GT86 (the standard spec outside of US market) OnionTou Suspension | Chassis | Brakes -- Sponsored by 949 Racing 55 07-01-2016 02:36 AM
what's the difference between twin screw, centrifugal, single turbo and twin turbo? warplane95 Forced Induction 86 04-17-2014 03:36 PM
my twin RWDGUY Mid-Atlantic 2 04-08-2013 10:23 PM
JDM Spec-C V9 Twin Scroll VF36 complete Nico TURBO Engine, Exhaust, Bolt-Ons 0 12-05-2012 12:20 PM
