#365 |
Drives: 2013 Firestorm FR-S
Yep. The car is very quiet stock, IMO, and I like to be able to hear where it is in the RPM range. Also, VROOM VROOM noises make me happy.
Most catbacks offer a few pounds of weight loss at best, some are closer to ~10lbs, and then things like muffler deletes are ~20lbs off the rear. Power gains are minimal to non-existent (if the butt dyno reads them, it's in your head). So I'd say that adding an exhaust on these cars is really only ever done for the sake of noise, ocassionally as a means of weigh reduction. Edit: Also mostly done for aesthetic purposes. Bigger tips, single exit, titanium/burnt look, etc. I think 90% of the reason to change the exhaust on these cars is for sound/looks. The other 10% is a split between weight and better exhaust flow. (These are not real figures. I pulled them out of my tailpipe to illustrate a point )
"Shark_Bait88, the man who’s spent the most money modding his stock FR-S and it’s still stock." -@jdnguyen
#366 |
Drives: 2017 BRZ
You can get stock length ARP studs.
#367 |
Those came out a bit too late for some of us
#368 |
Drives: 2017 BRZ
Hah. I'm running extended up front but plan stock length rear for easy install... Need to clear the brakes with the spare and that takes 20mm+... I'm being lazy, over 60 wheel changes and no problems. Doesn't see salt and gets an awful lot of wheel swaps over mile driven, both probably help. I carry tools and replacements though...
Then again, I'm not running SSC... |
#369 |
Drives: 2016 FR-S MT, 2015 Scion FR-S AT,
I don't think SSC-legal cat backs will offer much in the way of weight savings or exhaust flow/hp.
| The Following 2 Users Say Thank You to Twinz For This Useful Post: | Cueman (10-02-2017), Shark_Bait88 (10-02-2017) |
#370 | |
I think the major reason for the exhaust rules is weigh restriction, while also maintaining tolerable noise output. FYI, updated rules were posted this morning. Offset range is back to +40 to +48. I've got some loose TPMS at home that I need to weight...
| The Following 2 Users Say Thank You to Shark_Bait88 For This Useful Post: | strat61caster (10-02-2017), Twinz (10-02-2017) |
#371 |
The 40mm offset should make the camber bolts useful (and make our tires last longer). I am so glad they fixed that and stuck with the original rule.
*edit* re: exhaust rules....I think they are trying to make sure big spenders don't gain an advantage, but a simple steel/resonator rule would keep things cheap and quiet. (Just one and straight through allowed if it meets db restrictions) The wheel alignment thing was far more important to me. The ability to get some camber will make more of a difference than being stuck with my stock exhaust. |
| The Following 2 Users Say Thank You to Twinz For This Useful Post: | Shark_Bait88 (10-02-2017), strat61caster (10-02-2017) |
#372 |
Drives: Red frs and a few 90s celicas
yes the camber is far more important and that's good that it changed have to 40.
My only problem with the exhaust rule is that I bought my car with the invidia n1 and did not get a stock exhaust so it just adds another part I have to buy or hope someone is willing to trade. |
| The Following User Says Thank You to Jshreiner For This Useful Post: | Shark_Bait88 (10-02-2017) |
#373 | |
#374 | |
Custom User Title
I've decided I'm sticking to D-Street next year after they posted the exhaust rules. That pretty much solidified the decision for me not to spend more money on yet another class switch.
LOCUST 2015 FR-S (STX) and 2012 Evo X MR Instagram: LocustAutoX Sponsors:DSGPerformance Drift Office Evil Apex Racing |
| The Following User Says Thank You to Locust For This Useful Post: | Shark_Bait88 (10-02-2017) |
#375 | |
Drives: In Perfect Control At All Times
| The Following User Says Thank You to Cueman For This Useful Post: | Shark_Bait88 (10-02-2017) |
#376 |
Well that's good to know. Still sucks to be at the point to where I am selling everything I bought earlier this year. At this point I am weighing the cost of parts to how much seat time I could get for less.
#377 |
Drives: 2014 FR-S SSC
What would lead you to believe that a straight through - perforated core muffler would not be legal? This type of muffler meets any definition of baffled I've ever run across.
#378 |
Just the first thing that popped up from the Google machine (and it is in line with what I always thought a baffled muffler was):
https://www.quora.com/How-do-baffles...-of-an-exhaust "Baffles reduce the amount of sound produced by the exhaust most commonly on an internal combustion engine by forcing the exhaust flow to take an indirect route before exiting the muffler." Your picture looks like what I always thought a straight-through muffler/resonator was. I have yet to see a specific definition in the rule set though. |
| Upgrading brakes on the lower spec GT86 (the standard spec outside of US market) | OnionTou | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 55 | 07-01-2016 02:36 AM |
| what's the difference between twin screw, centrifugal, single turbo and twin turbo? | warplane95 | Forced Induction | 86 | 04-17-2014 03:36 PM |
| my twin | RWDGUY | Mid-Atlantic | 2 | 04-08-2013 10:23 PM |
| JDM Spec-C V9 Twin Scroll VF36 complete | Nico TURBO | Engine, Exhaust, Bolt-Ons | 0 | 12-05-2012 12:20 PM |
