Old 10-01-2017, 09:10 PM   #351
strat61caster
strat61caster's Avatar
Originally Posted by Jshreiner View Post
No mention of using the stock crash bolts with the spc bolts so that's not an option now. why the restriction to oem endlinks?
Reread the alignment section again, crash bolts are manufacturer approved parts for aligning the car, they're still allowed and probably why they're specifying the 14mm spc bolt so you can put it in the bottom hole and use the bottom bolt in the top hole.
ineedyourdiddly
Old 10-01-2017, 09:14 PM   #352
Twinz
Twinz's Avatar
Drives: 2016 FR-S MT, 2015 Scion FR-S AT,
I think wheel/strut clearance will be the limiting factor on front alignment. -Particulalrly with the new offset specs.
Twinz is offline   Reply With Quote
Old 10-01-2017, 09:38 PM   #353
chucky12012
Drives: 2013 Asphalt Scion FR-S
It is the limiting factor. The 8" wheel at about 3 degrees of camber rubs the shock. Might also have the tire rubbing on the spring. I still need to play around to see what camber level the rubbing goes away. Was going to remedy with a 5mm spacer on the 45mm offset wheel, but that's now out...
chucky12012 is offline   Reply With Quote
The Following 3 Users Say Thank You to chucky12012 For This Useful Post:
Shark_Bait88 (10-02-2017), strat61caster (10-01-2017), Twinz (10-01-2017)
Old 10-01-2017, 10:46 PM   #354
Cueman
Cueman's Avatar
Drives: In Perfect Control At All Times
That +43mm bit is a damn lame update to the regulations.
Cueman is offline   Reply With Quote
The Following User Says Thank You to Cueman For This Useful Post:
Twinz (10-01-2017)
Old 10-01-2017, 10:57 PM   #355
Cueman
Cueman's Avatar
Authorized Parts
• Parts superseded by Toyota® or Subaru® may be used on either vehicle.
Does this allow for anything fun? Blue limited parts on a standard BRZ?
I sure as hell want it too... just to add a little bit of personality.
The muffler and midpipe (as shown in the figure below) may be substituted provided the system exits the car in one or both of the original locations.
o “Track pipes” and “straight pipes” are not allowed.
o Materials are restricted to steel and/or stainless steel.
o The midpipe must include a functional baffled resonator.
o The muffler must include a baffled or chambered section with a minimum length of 5 inches. o Material for cosmetic exhaust tips is not restricted.
This makes me feel that canister mufflers aren't even legal.
Old 10-01-2017, 11:26 PM   #356
Twinz
Twinz's Avatar
I can't help but think they are steering people toward keeping the stock exhaust without actually mandating it.
Old 10-02-2017, 06:39 AM   #357
Jshreiner
Drives: Red frs and a few 90s celicas
Will baffled midpipes be the big issue with most of the aftermarket exhaust or the 5" muffler?
Jshreiner is offline   Reply With Quote
Old 10-02-2017, 08:21 AM   #358
Twinz
Twinz's Avatar
I guess it depends on what "Baffled" means. It sounds like like it means no straight-through resonators. They have basically required weight and restricted air flow in the exhaust by requiring *two* sound-control sections in the exhaust and baffles.
The stock exhaust seems to do that well enough without spending extra $$$. (for those of us that still have stock exhausts laying around)
The Following User Says Thank You to Twinz For This Useful Post:
Old 10-02-2017, 10:48 AM   #359
Shark_Bait88
Shark_Bait88's Avatar
Drives: 2013 Firestorm FR-S
I think the best solution for exhaust is going to be buying an axleback with a baffled muffler, which there are a few options for (though it limits the options quite a bit), and keeping the stock midpipe.
Hopefully they clarify and straight through resonators are deemed legal, otherwise the exhaust rules are pretty lame for SSC.
"Shark_Bait88, the man who’s spent the most money modding his stock FR-S and it’s still stock." -@jdnguyen
Shark_Bait88 is offline   Reply With Quote
Old 10-02-2017, 11:45 AM   #360
iLuveKetchup
My VTEC fluid is full
iLuveKetchup's Avatar
Drives: EFF JAY
Pardon my ignorance but are extended wheel studs allowed in SSC? I've already broken 3 wheel studs and looking to replace with ARP. I just bought the car used and the previous owner must have over torqued the lug nuts.
Wheel spacers allowed too?
iLuveKetchup is offline   Reply With Quote
Old 10-02-2017, 11:45 AM   #361
strat61caster
Work dual exit muffler seems like it would play by the letter of the law but not the spirit, no mention of if the exhaust must pass through the muffler...
Edit, sorry I meant Work, not Berk.
ineedyourdiddly
Old 10-02-2017, 11:48 AM   #362
strat61caster
I think it would fall under "industry standard repair" allowance on the wheel studs, no weight savings, but could be wrong on that given that it's an aftermarket part it could cause someone to nitpick.
ineedyourdiddly
Old 10-02-2017, 11:52 AM   #363
Shark_Bait88
Berk dual exit muffler seems like it would play by the letter of the law but not the spirit, no mention of if the exhaust must pass through the muffler...
Redacted per your update
The Following User Says Thank You to Shark_Bait88 For This Useful Post:
strat61caster (10-02-2017)
Old 10-02-2017, 12:28 PM   #364
Twinz
Twinz's Avatar
What would be the point, sound?
Search this Thread:
Advanced Search
Upgrading brakes on the lower spec GT86 (the standard spec outside of US market) OnionTou Suspension | Chassis | Brakes -- Sponsored by 949 Racing 55 07-01-2016 02:36 AM
what's the difference between twin screw, centrifugal, single turbo and twin turbo? warplane95 Forced Induction 86 04-17-2014 03:36 PM
my twin RWDGUY Mid-Atlantic 2 04-08-2013 10:23 PM
JDM Spec-C V9 Twin Scroll VF36 complete Nico TURBO Engine, Exhaust, Bolt-Ons 0 12-05-2012 12:20 PM
