#337 |
Drives: 2016 FR-S MT, 2015 Scion FR-S AT,
#338 | |
Drives: '15 BRZ, '19 GTI
Expanding on my previous post...
"Spec" tire weight measured at minimum usable tread depth: 21 lbs New, unused, tire weight: 23 lbs Spec wheel weight: 17 lbs So if we weigh the wheel/tire combo to verify compliance, the minimum weight is 21 (tire) + 17 (wheel) = 38 lbs. So with new tires (23 lbs), to hit that 38 lb target, you can use 15 lb wheels. "So what" you may ask? - It means you can have multiple sets of different wheels to use with tires of varying tread depth. This would be an advantage in the wet, where you presumably want nearly-new tires with deeper grooves. - It means competitors are going to be monitoring tire/wheel weight between events, and possibly even between runs. - It means competitors might need to drive over OPR to pick up weight after a run. - It means a wheel/tire that was legal on run 1 might not be legal on run 3. - It means TireRack can give us a spec tire weight when the tire still has usable life left, meaning the tires are junk if you have 17.0 lb wheels. I don't want any of those things (and the associated protests) in SSC. I think the method proposed to verify wheel weight has unintended consequences, and should be changed. I realize the competitive advantage of my above scenarios would be small. However, in a spec class even small advantages are advantages. We have the opportunity to write clear, unambiguous rules that prevent these kinds of cost-adding maneuvers and petty protests to the competition. I propose the following: - Manufacturing tolerances and wear affect the weight of the spec tire. The spec tire shall always be allowed for competition regardless of weight, provided it meets safety requirements. - Competitors may be required to remove one wheel/tire assembly after competition for weighing. TireRack will provide a minimum expected tire weight so that the weight of a wheel may be estimated using subtraction. The wheel weight estimate will be available to all competitors so they may lodge a protest. - Upon protest of wheels on the basis of weight, tires will be dismounted and the wheels individually weighed (including valve stems and caps, wheel weights, center caps, and TPMS sensors). The weight of any wheel used in competition can not be less than 17.0 lbs.
#339 |
"- Upon protest of wheels on the basis of weight, tires will be dismounted and the wheels individually weighed (including valve stems and caps, wheel weights, center caps, and TPMS sensors). The weight of any wheel used in competition can not be less than 17.0 lbs."
I wouldn't have an issue with that.^ |
#340 |
Custom User Title
I run with the gas light on.
LOCUST 2015 FR-S (STX) and 2012 Evo X MR Instagram: LocustAutoX Sponsors:DSGPerformance Drift Office Evil Apex Racing |
#341 | ||
#342 | |
- A "known legal" wheel being modified to be lighter, such as machining the backside of the spokes, machining between the bolt holes, removing paint, or simply removing the center caps. - A "known illegal" wheel being modified to ADD weight. Someone could machine solid steel center caps for RPF1s, and have a perfectly legal 17lb wheel with lower rotational inertia. - An "unknown" wheel. Someone could have custom 3 piece wheels made, that may or may not be legal. I think the method of checking wheel weight compliance is inadequate, and opens doors that aught to remain shut.
#343 |
Drives: 23 BRZ 15 Impreza
Has anyone weighed a tpms sensor? I bought a set of the Advanti DST Storm S1 wheels back in the spring for daily driving, It would be fantastic if I didn't have to buy another set of wheels.
#344 |
Drives: 2014 FR-S Hot Lava
Hmmm given the class philosophy I think I'd rather wheel choice be limited to an approved wheel list.
Will remove most weight issues/concerns/protests and make things easier to police. Or at minimum rule should be that wheel weight has to be a minmum of 17lbs without balast. |
#345 |
Drives: 2014 Subaru BRZ Limited 6MT SSM
Don't think this has been already posted: https://dk1xgl0d43mu1.cloudfront.net...pdf?1506722313
#346 | |
Most of this PDF clarifies things not specified in the original release on the SCCA's official website and basically just "fills in some blanks". However, the offset specifications for the wheels actually contradicts both the SCCA's official website and Tire Rack's wheel options for the SSC spec coupe vehicle. People are already buying parts to prep, so this is kind of important to straighten out.....soon. |
#347 | |
Drives: 2022 BRZ Premium
Sent from my SM-T310 using Tapatalk |
| The Following User Says Thank You to bholliday For This Useful Post: | Twinz (09-30-2017) |
#348 |
Drives: 2015 CWP BRZ
They should just go with Hoosiers! That would be a ton of fun!
| The Following 4 Users Say Thank You to bslate3 For This Useful Post: |
#349 |
Any rumors on when the tire will be named? Now that they have changed the offset, Tire Track will probably be where I get my wheels from but I would prefer to order the wheels with tires already mounted.
| The Following User Says Thank You to Twinz For This Useful Post: | JakeRogue (10-01-2017) |
#350 |
Drives: Red frs and a few 90s celicas
No mention of using the stock crash bolts with the spc bolts so that's not an option now. why the restriction to oem endlinks?
| Upgrading brakes on the lower spec GT86 (the standard spec outside of US market) | OnionTou | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 55 | 07-01-2016 02:36 AM |
| what's the difference between twin screw, centrifugal, single turbo and twin turbo? | warplane95 | Forced Induction | 86 | 04-17-2014 03:36 PM |
| my twin | RWDGUY | Mid-Atlantic | 2 | 04-08-2013 10:23 PM |
| JDM Spec-C V9 Twin Scroll VF36 complete | Nico TURBO | Engine, Exhaust, Bolt-Ons | 0 | 12-05-2012 12:20 PM |
