86WORX
Old 08-14-2017, 06:16 PM   #15
Ultramaroon
fabulous
Ultramaroon's Avatar
Originally Posted by B T View Post
indeed, Ultramaroon. There was no contact prior to the bushing melting. I had more important things to monitor during my track day than EGT. I had 4 or 5 20 minute sessions at Florida International Rally and Motorsports Complex. Each run was 20 minutes apart. I think a majority of the melting happened after parking (4 cool down laps). I didn't hear it banging while I was still on track. I'm still running the stock front pipe, waiting on my ACE unit to come in. The lack of flow past the overpipe could have contributed to this.
I was thinking the same, that it was hot while stagnant. Even the shielded stock overpipe is rough on that bushing. Melts all the grease out of it.
Still odd. Lots of A350s out there by now. Staying tuned.
Old 08-14-2017, 10:52 PM   #16
weederr33
Airborne at your service
weederr33's Avatar
Drives: '17 BRZ Series.Yellow
Wow that is melted for sure. I've never heard of this happening before though. Could it be the bushings that came with the Whiteline sway bars being subpar?
MS, CSCS, TSAC-F, CPT
Old 08-14-2017, 11:58 PM   #17
lazyluka
Drives: GT86
I think someone on here had issues with aftermarket poly engine mounts.
One of the comments on that post went along the lines of:
The aftermarket poly mounts couldn't handle the heat, but the stock ones would have been fine because they are designed for durability so could handle higher temps.
Not sure if that helps?
lazyluka is offline   Reply With Quote
The Following User Says Thank You to lazyluka For This Useful Post:
Ultramaroon (08-15-2017)
Old 08-15-2017, 12:24 AM   #18
Ultramaroon
fabulous
I had the same thought. Consensus doesn't make us correct but...
weederr33 (08-15-2017)
Old 08-15-2017, 12:29 AM   #19
weederr33
weederr33's Avatar
It also looks as though part of the axle bushing is melted too, though.
Old 08-15-2017, 12:40 AM   #20
Ultramaroon
fabulous
Shit, that looks like the inner tie rod cover.
Old 08-15-2017, 11:40 AM   #21
Krion
Drives: 2017 BRZ
Would using some type of exhaust wrap help in this situation?
Krion is offline   Reply With Quote
Old 08-15-2017, 11:41 AM   #22
B T
yeah, the inner tie rod cover it busted too. Hopefully my ACE front pipe will be here soon and my exhaust will be able to move heat away from that bushing a little faster. I'll probably heat wrap that portion as well for extra safety.
B T is offline   Reply With Quote
Old 08-15-2017, 11:44 AM   #23
B T
maybe we could get @AceHeader-MT to weigh in on this?
Old 08-15-2017, 09:18 PM   #24
Turdinator
Señor Member
Turdinator's Avatar
The stock sway bar bushes look awfully like a soft poly rather than the traditional rubber. That doesn't mean the whiteline ones don't have less temperature resistance though.
1974 TA22 Celica
2013 86 GT
Old 08-15-2017, 09:27 PM   #25
Ultramaroon
fabulous
OP melted his inner tie rod cover (bellows). I haven't seen that issue pop up.
Changing my take on this issue. I don't know how but that area must have gotten exceptionally hot. Maybe an exhaust leak? More pics from different angles if possible?
Old 08-16-2017, 06:09 PM   #26
B T
I'm pretty sure I'd have heard an exhaust leak, my car is still pretty quiet with the stock front pipe-muffler. Header/Overpipe are also ceramic coated inside and out btw. I'm leaving town for a few weeks, but I'll investigate further when I get back. Going to try wrapping the overpipe and install new bushing. The tie rod cover looks more like it split than melted from what I recall seeing.
The Following User Says Thank You to B T For This Useful Post:
Ultramaroon (08-17-2017)
Old 08-17-2017, 01:26 PM   #27
MurderousPandas
MurderousPandas's Avatar
Drives: 2013 Scion FRS
My first mod exhaust wise was a catless over/front pipe combo, then headers. No problems with heat that started melting stuff.
Sent from my HTC6535LVW using Tapatalk
MurderousPandas is offline   Reply With Quote
Old 08-30-2017, 02:58 PM   #28
B T
No word from Whiteline or ACE on this matter
Search this Thread:
Advanced Search
Melted Throw Out Bearing danthedirt Issues | Warranty | Recalls / TSB 59 01-25-2018 06:32 PM
Clutch Release Bearing Melted Haulin Engine, Exhaust, Transmission 37 05-29-2016 07:35 PM
Buddy Club Tails Damaged/Melted? Krazy Cosmetic Modification (Interior/Exterior/Lighting) 13 01-07-2016 12:11 PM
Perrin exhaust with added benefit of melted plastic s30series Engine, Exhaust, Transmission 3 09-12-2014 09:44 PM
Muffler delete on track (melted bumper?) celica73 Tracking / Autocross / HPDE / Drifting 12 04-01-2014 05:27 PM
