86WORX
Old 08-11-2017, 02:37 PM   #71
Ultramaroon
fabulous
Ultramaroon's Avatar
Originally Posted by paulca View Post
Just thought I'd throw in the 2017 UK has an oil temp gauge and it stabilises just over 90*C and pretty much stays there. I haven't ragged the car yet though. When the 1000 miles are up I'll get to pin it to the red line a few times and see if the oil temp rises much.
It will. Just cruise in third gear for a couple minutes. You'll boil off all that water you've accumulated.
finch1750 (08-11-2017)
Old 08-11-2017, 02:41 PM   #72
NeverInTime (08-11-2017), Ultramaroon (08-11-2017)
Old 08-11-2017, 03:02 PM   #73
finch1750
Undisputed El Presidente
finch1750's Avatar
Drives: Zenki 37J ZN6
Originally Posted by MJones_RB View Post
Is there a way to supercharge your engine WITHOUT sacrificing reliability? What about all those cars that come from the factory with superchargers/turbochargers? Do they have a higher maintenance factor built into the warranty, or is it a matter of pushing the tolerances to the limit?
I know Mitsubishi's EVOs had a more frequent maintenance schedule than the simple Lancer, same with the STi version of the Impreza.
Anytime you ask sometime to endure greature force then it was meant for you are compromising it's lifespan. Whether it is a noticeable amount or not will vary. But in general terms NA engines that are made FI don't have the tolerance (high comp vs low comp, strength of internals, etc). Even FI motors with upped boost lose reliability.
You could put down 400whp and be fine for 100k, but going into it you should be able to accept the possible outcomes (ie blown motor, broken tranny, etc)
I don't get it. I mean the picture and how it demonstrates your point. I get your point about the miniscule water molecules burning off or whatever (I think)
Old 08-11-2017, 03:09 PM   #74
The difference between evaporating the water in the system and boiling it. Just another poke at the supposedly massive build up of water these engines get and the need to reach above boiling to get rid of it all.
Sort of a "If I need to explain it then it isn't as funny as I thought" scenario I guess.
Old 08-11-2017, 03:20 PM   #75
finch1750
finch1750's Avatar
I figured something like that, I'm just not the most mechanically inclined person in that sense that looking at that just confused me lol
Tcoat (08-11-2017)
Old 08-11-2017, 03:26 PM   #76
Ultramaroon
fabulous
It's ok. We still heart you, man. #nohomo #notthattheresanythingwrongwiththat
finch1750 (08-11-2017), Tcoat (08-11-2017)
Old 08-11-2017, 03:33 PM   #77
Capt Spaulding
Persona Non Grata
Capt Spaulding's Avatar
Drives: '15 BRZ (WRB)
Don't feel bad. Other than the steam driving the piston I was a little perplexed myself. Sorry T coat.
Slow is smooth, and smooth is fast
Capt Spaulding is offline   Reply With Quote
The Following 2 Users Say Thank You to Capt Spaulding For This Useful Post:
Old 08-11-2017, 03:42 PM   #78
Maybe I used the wrong thing
Old 08-11-2017, 04:33 PM   #79
humfrz
........I'm not as forgiving.
finch1750 ...... it's a STEAM ENGINE ....... not rocket science, here ......
In your defense, I reckon you didn't have those experiences in your childhood.
humfrz
Old 08-11-2017, 04:45 PM   #80
finch1750
finch1750's Avatar
humfrz
Safe to assume anything in your childhood is not know by anyone here. Even @Tcoat
There ya go lol
humfrz (08-11-2017)
Old 08-11-2017, 05:05 PM   #81
WNDSRFR
Drives: FR-S,GTI
WOW
This discussion is........................
Interesting?
The Following User Says Thank You to WNDSRFR For This Useful Post:
Tcoat (08-11-2017)
Old 08-11-2017, 09:39 PM   #82
Capt Spaulding
Persona Non Grata
Most of us oldsters studied the dawn of the industrial age in school. It seems for humfrz it's a recent memory. lol
humfrz (08-11-2017), Ultramaroon (08-12-2017)
Old 08-12-2017, 11:47 AM   #83
EddieZ2
Drives: 2013 FRS
Wow, lots of response here. As was mentioned, go with the prescribed maintenance schedule. Get good, no, get great tires. You will feel the difference. Research tires depending on your driving. The same for brakes. Just an upgrade in pads can make a great difference. Once again they're dependent on your driving style. TRD mods... the TRD exhaust is pricey, adds a little deeper tone and doesn't do much. The TRD intake may give you 2hp increase but there is better response to it than stock. Sway bars, springs...are you doing any track days? If no don't waste the $. The Chassis was very well designed and once you upgrade your rubber you'll understand. Stay on top of maintenance, recalls and service bulletins and you'll be in great shape....then again if you want to throw $ at one of the finest designed and engineered rides then by all means, open up that bank account and buy, buy, buy. My only mods, great rubber which I'm still reviewing and a K&N filter. BTW, look at what the TRD intake uses for a filter. Save your $$ and buy ethanol free premium. Your car will love you for it.
EddieZ2 is offline   Reply With Quote
The Following User Says Thank You to EddieZ2 For This Useful Post:
BigHugeFatGuy (08-13-2017)
Old 08-12-2017, 05:32 PM   #84
root
Drives: Raven FR-S
As was mentioned earlier, only thing I've personally experienced as major issue is the throwout bearing. Grenaded at shortly after 60,000 miles. Cost me close to $2K for the service, and I didn't see the updated bearing part until after it was done so I have the same original spec OEM part in there. There's some debate that the stock clutch fork is weak and contributing to this failure. The fork is weak if you go upgraded clutch, but for stock is prob ok.
Only other thing I did was get a decent AGM battery as those unsealed batteries like to leak out the top and make a corroded mess.
root is offline   Reply With Quote
The Following User Says Thank You to root For This Useful Post:
guybo (08-12-2017)
Search this Thread:
Advanced Search
FR-S / BRZ reliability stats mkaresh Scion FR-S / Toyota 86 GT86 General Forum 82 03-12-2017 03:40 PM
Turbo Reliability VS Supercharger reliability KGB Forced Induction 130 09-08-2015 10:55 AM
FI Reliability pheonixone Forced Induction 42 02-22-2015 01:51 PM
