86WORX
Old 08-09-2017, 08:51 PM   #29
chaoskaze
The Fail Boat
chaoskaze's Avatar
Drives: CWP S.B.
Originally Posted by mrg666 View Post
My crickets love E10. Since I don't like crickets I use ethanol free. Ethanol free doesn't make much difference for me in gas mileage. But I am comparing 91 octane ethanol free with 93 octane ethanol gas. I will fill with 93 octane again next time to see how the crickets are doing and check the gas mileage. There is also air temperature. The car hates hot and humid air; power and mileage suffer miserably with such weather. I gotta find a nice week to test 93 ethanol gas.
From my experience is that higher octane really give it te good gas mileage boost if you love it. * but i did that test by mixing 91 with 100.... cuz california sucks.
Old 08-09-2017, 09:10 PM   #30
alan.chalkley
Drives: 4wd zooks
Originally Posted by guybo View Post
Why ethanol free? Ethanol is an excellent fuel and keeps the engine cleaner. It increases octane rating and is an excellent solvent to keep the fuel system and injectors clean. The thinking that ethanol is somehow inferior is stone age thinking going back to when cars weren't designed for it and the fuel system would be damaged by it. The 86 is designed to run on E15 reliably.
As for a reliability mods-
Unless you are going FI, don't install an oil cooler. The oil has to regularly run well over 212F to burn off water in the crankcase from normal condensation. An engine that does not run hot enough is going to have reliability issues.
Install an oil catch can. It's good for the long term health of the engine by preventing deposits from building up on the valves.
Ethanol blend in australia is often contaminated with paint thinners.
We recently had our sydney western freeway blocked by broken down cars that were using E10.
So when driving here we should use premium 98
alan.chalkley is offline   Reply With Quote
Old 08-09-2017, 10:08 PM   #31
guybo
Huge E85 fan!
guybo's Avatar
Drives: 2016 Scion FRS
True it gets less gas mileage... and so what? Doesn't mean it's bad for the engine. E10 (sorry my bad, not E15) does have higher octane.
The fact is, by design this car's oil does run above boiling temp. It's for getting rid of water in the oil as much as anything. It's by design. On a tracked car, if you modify for FI or whatever, you may need an oil cooler. But for a regular DD it's worse for the engine to have one and run the oil too cold. If you do track it and you're NA, install a bypass on the oil cooler and only use it when needed. There's a reason Toyobaru designed this car to run as hot as it does and it's not a mistake.
As for the wet t-shirt contest... 1) no pics, didn't happen 2) don't confuse water boiling off with evaporation. 2 totally different things.
Old 08-09-2017, 10:31 PM   #32
humfrz
Well, the only picture I have is of the winner.
As far as stuff boiling and evaporating ........ I ain't tupid ....... I learned everything I needed to know about that stuff from my uncle, back in West Virginia ...... so there!
humfrz
Old 08-09-2017, 10:33 PM   #33
So just how much water do you think gets in there? Where exactly does this massive quantity that needs to be "boiled off" come from? Where does it "boil off" to?
chaoskaze (08-10-2017), humfrz (08-10-2017), Ultramaroon (08-10-2017)
Old 08-09-2017, 11:12 PM   #34
UH60CE
Drives: 2017 Halo 86
reliability mods? best mod you can do to your car is simply not modding or changing a damn thing and driving the car for reliability and complete issue free ownership. now some good protective mods to increase reliability would be getiing mudguards installed to keep lower panel damage to minimum, clear bra or paint protection film and fabric guard application on the interior uphostery and getting the all weather floor mats
UH60CE is offline   Reply With Quote
The Following 5 Users Say Thank You to UH60CE For This Useful Post:
Adam_L (08-10-2017), BigHugeFatGuy (09-17-2017), humfrz (08-10-2017), Tcoat (08-10-2017), Ultramaroon (08-10-2017)
Old 08-10-2017, 01:32 AM   #35
Ultramaroon
fabulous
Ultramaroon's Avatar
My opinion is, by design this car's oil does run above boiling temp.
fify, unless, of course, you can point us to some design documentation. I'll gladly accept that.
humfrz (08-10-2017)
Old 08-10-2017, 02:31 AM   #36
humfrz
Now, about all this water that needs to be boiled out of the crankcase .......
humfrz
Old 08-10-2017, 03:13 AM   #37
Ultramaroon
fabulous
*sigh*
Old 08-10-2017, 04:03 AM   #38
504
504's Avatar
Drives: 2014 86 GTS
That's a ridiculous claim, sorry.
My friends brand new civic was destroyed filling up at a BP servo and he uses nothing but 98 (part of that train of destroyed cars on the freeway). Those cars lined up with hydrolocked engines were due to water seepage into the servo fuel tank. I have a picture of a water bottle showing the contents of the supposed fuel showing all the grit and water.
Assumptions are dangerous and contribute alot of misinformation
I've run nothing but e70+ for the past 3 years
504 is offline   Reply With Quote
The Following 2 Users Say Thank You to 504 For This Useful Post:
Old 08-10-2017, 09:04 AM   #39
new2subaru
Weight Weenie
Drives: 15 FR-S
What do you think gasoline is?
Old 08-10-2017, 10:24 AM   #40
alan.chalkley
Drives: 4wd zooks
My mechanic has warned me not to use any ethanol blended fuel in any of my cars.
He said that the poor quality of E10 in sydney is destroying engines.
Old 08-10-2017, 11:04 AM   #41
My father was obsessed that gas stations used Varsol to cut the fuel and make more money and that by them doing tis they ruined his cars (the reality was that 100K+ with no oil change tends to cause issues).
I tried in vain to point out the economic reality of this but he never understood.
Retail Price: $12.99 gallon (4L)
Retail price $2 a gallon
Even at wholesale cost it makes no sense whatsoever for anybody to use a material that retails for $12 to stretch a product that sells for $2.
That is not even considering that many paint thinners are barely even combustible much less flammable enough to use as a fuel additives.
Old 08-10-2017, 11:13 AM   #42
cjd
cjd's Avatar
Drives: 2017 BRZ
Water has to be above boiling temp in order to evaporate? Why is my oil cooler thermostat fully open at 180*F?
Guess it's time to fire off a strongly worded letter to Mocal.
Isn't it a somewhat closed higher pressure system? That raises the boiling point...
I'm surprised no one has mentioned the garage mod. Keep it out of the elements.
Or the other car mod... Don't use it very much! Recommend pairing with the garage mod.
The Following 2 Users Say Thank You to cjd For This Useful Post:
BigHugeFatGuy (09-17-2017), Ultramaroon (08-10-2017)
Search this Thread:
Advanced Search
FR-S / BRZ reliability stats mkaresh Scion FR-S / Toyota 86 GT86 General Forum 82 03-12-2017 03:40 PM
Turbo Reliability VS Supercharger reliability KGB Forced Induction 130 09-08-2015 10:55 AM
FI Reliability pheonixone Forced Induction 42 02-22-2015 01:51 PM
