Old 05-06-2013, 09:11 PM   #57
OICU812
Just a dude
OICU812's Avatar
Drives: Scion FR-S 2013
Looks good much better then shark fins etc...
Old 05-06-2013, 09:25 PM   #58
zoomzoomers
zoomzoomers's Avatar
Drives: 2013 Subaru SWP BRZ Limited 6AT
I too don't like the look of my factory BRZ antenna, but I've hesitated to change it (i.e. shark style) because I do not want to loose reception. Somebody needs to come up with a good alternative and quick. Keep us posted with your results.
Man Law#17:A man in the company of a hot, seductively dressed, woman MUST remain sober enough to fight!
MODS: AVO tubes + filter, Cusco (F) strut brace w/ MC brace, Perrin CBE, Subaru OEM trunk tray, Grimmspeed front license re-locator & hood struts and Beatsonic rear cam.
zoomzoomers is offline   Reply With Quote
Old 05-06-2013, 09:56 PM   #59
drtepper
drtepper's Avatar
Drives: WRB BRZ Limited 6MT + 96 Camry LE
Alright, so it doesn't seem like a g37 antenna will work. the housing is just way too small for all the junk in the brz base. Essentially the g37 antenna housing is only meant for sat radio/nav but the brz's housing is for both sat and fm radio so.. twice the stuffings. Here are the pics i got from my experiment today.
looks like we either need to find another car that uses a larger flat type antenna to mooch off of or fabricate our own non-shark-fin type shells to go over the stock housing. Any ideas?
@FTEIGHTSIX
drtepper is offline   Reply With Quote
The Following 3 Users Say Thank You to drtepper For This Useful Post:
FTEIGHTSIX (05-07-2013), Lonewolf (05-07-2013), Rosticles (06-25-2015)
Old 05-07-2013, 12:36 AM   #60
FTEIGHTSIX
Switched to the dark side
FTEIGHTSIX's Avatar
Drives: 91 & 95 240sx KA-T SOLD, 2013 BRZ
I think it still might be possible.
What if you took apart the antenna?
It looks like you can unscrew both the FM and HD antenna.
I would stack them.
It looks like it would still fit.
The g37 can still be separated from the outer shell and its base.
WTB: FA20 longblock in Socal or shipped.
FTEIGHTSIX is offline   Reply With Quote
Old 05-07-2013, 12:50 AM   #61
drtepper
drtepper's Avatar
I would stack them.
that was my first thought as well but I don't think that the g37 s vertical clearance in the housing can accommodate a stacked arrangement its pretty cramped in there.
Old 05-07-2013, 01:11 AM   #62
FTEIGHTSIX
FTEIGHTSIX's Avatar
I take back what I said after looking at mine just now.
Old 05-07-2013, 01:12 AM   #63
FTEIGHTSIX
FTEIGHTSIX's Avatar
I have tomorrow off.
I might try to take mine apart to see what I can come up with.
Old 05-07-2013, 01:26 AM   #64
FTEIGHTSIX
FTEIGHTSIX's Avatar
If all else fails, I'm just going to mount the FM part inside the car and the HD in the g37 antenna and hope it all works.
Old 05-07-2013, 02:42 AM   #65
drtepper
drtepper's Avatar
That's actually not a bad idea... but i'd probably opt to leave the Sat receiver inside like in between the headliner and the roof.. since i never use it anyway.. haha. At least I assume the square thing is the sat receiver.
Keep me posted if you get it done tomorrow. I might revisit it myself, if you've had any success.
Old 05-11-2013, 05:15 PM   #66
Spidey
Spidey's Avatar
Drives: 2013 FR-S, '85 Corolla GT-S Hatch
Thumbs up
I got my antenna today and installed. I used the G37 Convertible antenna. I removed the circuit board from the FR-S antenna and placed it into the G37 base.
There are two places where you have to desolder. Both are shown below.
Next, pry open the metal prongs holding the antenna cable in place, shown bellow already pried open.
Remove the two pins from the plastic clip and take note of the antenna position in as shown below. The small one came out by tugging on it. The antenna wire you have to unclip from the front as well.
The FR-s circuit board fits into the G37 antenna as shown.
There are 2 places to solder to the G37 base. One is the previously unsoldered wire underneath the board. After doing this I placed some GOOP over it to hold it in place just in case. The other was also unsoldered previously in the second pic. The hole in the board actually aligns with a screw hole we won't be using so, I just dumped a lot of solder wire into the hole. This can be seen below. I also soldered another wire to where the original antenna mast touches and ran a wire through a hole I made on the plastic case.
Note, The oem FR-S nut can be used with the G37 antenna base, so that’s what I did.
Done. Thanks to Enigmus for the info.
The paint color doesn't match perfectly, but its barely noticeable.
Spidey is offline   Reply With Quote
The Following 5 Users Say Thank You to Spidey For This Useful Post:
Chad86 (07-01-2014), civicdrivr (05-11-2013), Lonewolf (05-11-2013), Rosticles (06-25-2015), tbrocato (03-03-2014)
Old 05-11-2013, 08:22 PM   #67
Lonewolf
Lonewolf's Avatar
Drives: Moped
Thank you for the write-up! Some vendor should really get on making this type of product available...cough, cough @beatsonic
The Following User Says Thank You to Lonewolf For This Useful Post:
illest86 (03-31-2014)
Old 05-11-2013, 10:55 PM   #68
Spidey
Spidey's Avatar
Originally Posted by OICU812 View Post
Love this! I emailed Beatsonic saying they should make an option like this and basically was told no interest in it. Personally I think that looks better then anything out there for this car!!!
No offence to Beatsonic, they make a good product, but they are selling a piece of painted plastic for $115. It would take some engineering to fit all the components from the OEM antenna into a newly developed base and casing. I'm guessing they would charge over $300 for something like that.
Old 05-13-2013, 12:00 AM   #69
Lonewolf
Lonewolf's Avatar
Drives: Moped
It would still be nice to have the option...and with enough volume I think they can offer them around the $215 price range.
I emailed Beat Sonic and hopefully enough people will let them know that there is a market for something like this...
Old 05-13-2013, 12:02 AM   #70
Lonewolf
Lonewolf's Avatar
Drives: Moped
Awesome write-up, thank you! Mods please make this available in the DIY section of the site...
Search this Thread:
Advanced Search
Tom's antenna shark fin Hanzo Cosmetic Modification (Interior/Exterior/Lighting) 15 10-28-2012 01:44 PM
Flat black BRZ BRZranger Cosmetic Modification (Interior/Exterior/Lighting) 6 06-27-2012 04:23 PM
Flat Black BRZ Toods BRZ First-Gen (2012+) -- General Topics 4 06-20-2012 01:25 AM
Beat-Sonic USA Shark Fin Antenna for Subaru BRZ, DOES NOT FIT! xcelir8brz Electronics | Audio | NAV | Infotainment 2 06-05-2012 12:44 AM
I'm going to try my hand on a flat 4 4agze Other Vehicles & General Automotive Discussions 2 04-08-2011 08:46 PM
