#127 |
Drives: 2007 GT3 | 22' BRZ
Close up of the Moton 2 ways and a set of Swift springs for testing.
#128 |
Drives: Black BRZ
This is nuts...can't wait to read your review on these - I hope you post some in depth feedback when you get a chance
Will you wait another month or so until everything opens up and get these installed at a shop or would you just be installing them on your own and then heading out for a drive just to get a feel? |
#129 | |
The car will most likely retire as a street car and become a track only car so I'll be leaving it at my friend's shop from now on. We are beginning to make and design carbon panels/aero for the 86 chassis
| The Following User Says Thank You to Route For This Useful Post: | new2subaru (04-23-2020) |
#130 |
TRD 14R shipment has landed.
| The Following 6 Users Say Thank You to Route For This Useful Post: | HaXx (05-07-2020), MCTeeJ (04-28-2020), new2subaru (04-23-2020), trueno86power (04-20-2020), TylerLieberman (05-16-2020), weederr33 (04-20-2020) |
#131 |
Airborne at your service
Drives: '17 BRZ Series.Yellow
Ohhh that' 14R exhaust looks awesome! It looks like it uses the same muffler as the high response ver. r that I have on my car.
Btw, where did you get that HKS brake fluid cover??
| The Following User Says Thank You to weederr33 For This Useful Post: | SuperTom (04-23-2020) |
#132 |
I got it a long time ago from a Gridlife event!
| The Following User Says Thank You to Route For This Useful Post: | weederr33 (04-20-2020) |
#133 |
Ouuuuf, that rear bumper is going to look clean on your car man. Keep up the good fight :O
| The Following User Says Thank You to Berserker For This Useful Post: | Route (04-21-2020) |
#134 |
[||•]=(86)=[•||]
Drives: 2017 Toyota 86
Ohh so that you that I've seen on the FB group ! Damn man, nice find ! I'm a sucker for TRD parts and that the holy grail of TRD !
Great job, can't wait for the final result !
| The Following User Says Thank You to trueno86power For This Useful Post: | Route (04-21-2020) |
#135 |
Drives: 2019 BRZ / E36 325is
i know this guy, i think i saw him on the youtube!
23 GR86 Halo MT Prem - Racecomp Engineering SS-2 - Sayber Designs - Voltex - RE71RS - Project Mu |
#136 |
Drives: 2018 Subaru BRZ
Your whip is mad dope yo!
On my fourth 86... and everything in between
| The Following User Says Thank You to Scracho For This Useful Post: | Route (05-06-2020) |
#137 |
#138 |
2/4 Moton shocks are installed, my Antigravity battery has come in and so has the tray. Battery setup should weigh around 5lbs in total.
Advans have also gone to a new home. ![]() ![]() ![]() ![]()
#139 | |
Drives: jrsc_brz
edit: whats up w the swifts? i have some on tha FA, u try them?
JACKSON RACING l RALLYBACKER l FORGESTAR l FORTUNE AUTO l INVIDIA
| The Following User Says Thank You to HaXx For This Useful Post: | Route (05-07-2020) |
#140 | |
Thanks for the compliment! I use the bottom setting to keep as much suspension travel as I can in the rear and because the springs on these are considerably stiffer than my KW’s I’m going to assume I’ll need to lower the shock quite a bit to get the ride height I’m aiming for. As for the Swifts, I’m going to test the car out on the track with 16kg springs front/rear and if that’s too stiff I’ll swap the Swifts in since they are 12kg springs.
| The Following User Says Thank You to Route For This Useful Post: | HaXx (05-07-2020) |
| Tags |
| 14r, brz, frs, trd, voltex |
| My Asphalt FRS Build | ZaneRL9 | Member's Car Journals | 14 | 06-13-2015 04:38 PM |
| hattrickey's Asphalt Build | hattrickey | Member's Car Journals | 4 | 08-16-2014 01:00 PM |
| asphalt.frs.22's Evil fr-s build | asphalt.frs.22 | Member's Car Journals | 1 | 05-30-2014 08:21 PM |
| Opposed Asphalt build | Opposed | Member's Car Journals | 30 | 01-16-2014 12:03 AM |
| New FRS Asphalt build. | Erik-Frs | Member's Car Journals | 24 | 09-18-2013 09:18 PM |
