#85 |
Drives: 2015 frs
#86 |
Drives: 2015 frs
My ECU came in, and I started building the jig for the front crossmember.
#88 |
Drives: BRZ, WRX
Nice work with the jig, that will make things easier for you.
#89 |
Drives: 2015 frs
The ECU is a OEM GM E92 ECU. I love the way it looks too. Just get a project and lern as you go, or take some classes that challenge you and pushes you to develop new skills, and you will be right up there with the best of them over time.
#90 |
Drives: 2015 frs
#91 | |
Drives: BRZ, WRX
Round tubing would be better if you have the tools to work with it. I'll be using 1.75" for most of my front crossmember.
#92 |
Drives: 2015 frs
What wall thickness are you using? I have .095 available I was thinking to use that. I have the tools. Watching your build. I like it a lot. I want to do a similar rear subframe to the one you did, but for a Winter's quick change diff. Mine would be a bolt in unit.
#93 |
Drives: BRZ, WRX
All my tube is 0.102 wall, I mostly use 1.5" but the main hoop and part of the front crossmember is 1.75"
#94 |
Drives: 2015 frs
The jig is completed. I made it two pieces that bolt together.
| The Following User Says Thank You to Zer0 For This Useful Post: | DustinS (02-28-2019) |
#95 |
Drives: 2015 frs
I have begun working on the crossmember. What work has been done is mostly tacked up my welding machine is acting up. Hopefully I get it completed next week.
#96 |
Drives: 2015 Scion FRS
Very nice sir!
2015 Red FRS
Enkie LC5 18" Rims/Michelin 225-45 18 Super Sports Perrin resonated catback exhaust FT86 UEL catted header Stage 2 OFT tune |
| The Following User Says Thank You to Thedishdoc For This Useful Post: | Zer0 (03-08-2019) |
#97 |
Drives: 2015 frs
Out of the jig, but not finished yet. Needed to weld it in it's current state of build, then back to the jig to add the final parts
#98 |
Drives: 2015 frs
I have gotten further along with the crossmember. It weighs 30 lb. My stock one weighs 26lb with the two connectors that bolt below / behind the firewall and to the crossmember. This weight is also without motor mounts and the mount tabs cut off. I still need to add the two connectors that are on my stock crossmember but not on the one I made yet. I'm thinking 36lb when it's complete with motor mounts. It's a little heavier, but I think it will be stronger, and most important I will have more clearance.
| Andy0323's Back To Basics Build Thread <Long Term Project> | andy0323 | Member's Car Journals | 15 | 02-02-2018 01:16 AM |
| long term and short term | brichard0625 | Engine, Exhaust, Transmission | 7 | 08-26-2013 09:56 AM |
| Long term | Bt216 | Scion FR-S / Toyota 86 GT86 General Forum | 3 | 06-07-2013 12:58 AM |
| Fuel Trims - Long term and short term | victorb | Engine, Exhaust, Transmission | 6 | 03-27-2013 03:18 PM |
| Short Term and Long Term Fuel Trims | naikaidriver | Engine, Exhaust, Transmission | 3 | 03-18-2013 10:55 PM |
