86WORX
Old 01-12-2019, 03:42 PM   #71
Zer0
Drives: 2015 frs
Mitch at http://www.swaptimeusa.com sent me a picture of the oem wire harness he will be reworking. It looks nice from GM. Can't wait to get it in my hands
Zer0 is offline   Reply With Quote
Old 01-13-2019, 12:20 AM   #72
Zer0
Drives: 2015 frs
A few more pictures centered up. Still contemplating pushing it back 3/4" or so. Looks like Vorshlag lower mounts will still be able to be used with new engine side mounts. May need to modify passenger side lower mount. Will definitely need to clearance driverside valve cover, and make room in the center of the firewall for the DI pump, and electrical connections If I push it back the 3/4".
Old 01-14-2019, 09:53 AM   #73
ka-titties
Drives: 2013 BRZ Limited 6MT
Keep up the great work. This thing is going to be bonkers. What's the intended use?
ka-titties is offline   Reply With Quote
Old 01-14-2019, 10:19 AM   #74
Zer0
Drives: 2015 frs
Just building a car 100% the way I want it built as a hobby to have fun. I'm thinking about 1mile events when it's done.
Old 01-19-2019, 05:12 PM   #75
Zer0
Drives: 2015 frs
I tacked up a lower passenger plate to build the passenger side mount on, and made a couple of big ass holes in the trans tunnel and firewall. Trying to find chassis center on firewall and center on the back of the engine to get everything aligned.
The Following User Says Thank You to Zer0 For This Useful Post:
DustinS (01-22-2019)
Old 01-20-2019, 02:53 PM   #76
Zer0
Drives: 2015 frs
I have it where it's going to sit. Using the lower Vorshlag mount on the driverside. I will be building the upper mount on both sides, as well as the lower mount on the passenger side.
Old 01-21-2019, 03:51 AM   #77
Zer0
Drives: 2015 frs
Reworked wire harness. Can't wait to get it.
Old 01-22-2019, 09:50 AM   #78
Zer0
Drives: 2015 frs
The stock crossmember is not going to work with the LT4 manifolds, and cats. Looks like I'm stuck in fabrication mode on this for a while. Going to get the manifolds, and cats on so I can come up with a plan to get everything in. It's going to get interesting. Looks like I will be redesigning the mounts as well. It's to bad because the Vorshlag mount kit was nice.
Old 01-29-2019, 11:27 PM   #79
Zer0
Drives: 2015 frs
Harness overview LT4 with all emission controls. Should have it soon shipping out today.
Old 02-07-2019, 03:33 AM   #80
Zer0
Drives: 2015 frs
I cut down a stock FR-S crossmember for testing clearances. I also received my engine harness. I will post more pics soon.
Old 02-09-2019, 11:24 PM   #81
Zer0
Drives: 2015 frs
I bolted in the cut down crossmember. I also test fit manifolds, and catalitic converters. I need to trim a little more material from the crossmember to get the cats bolted in. After the cats are bolted in I will have to see if the steering rack will fit in it's original location, or if adj. will need to be made to the steering setup. I plan on needing to make adjustments to the steering. I will post up pics when the cats are on.
Old 02-10-2019, 10:36 PM   #82
Zer0
Drives: 2015 frs
A little more clearancing on the crossmember, and transmission needed to get a perfect fit. Hopefully tomorrow.
DustinS (02-11-2019)
Old 02-15-2019, 11:20 PM   #83
Zer0
Drives: 2015 frs
I got the cats to fit. Next is to fit the steering rack. Once it is fit I can build the crossmember.
Colin86 (02-15-2019)
Old 02-15-2019, 11:39 PM   #84
Colin86
Drives: 86
Great work, and incredible project. Thanks so much for sharing with the forum!
Colin86 is offline   Reply With Quote
Search this Thread:
Advanced Search
Andy0323's Back To Basics Build Thread <Long Term Project> andy0323 Member's Car Journals 15 02-02-2018 01:16 AM
long term and short term brichard0625 Engine, Exhaust, Transmission 7 08-26-2013 09:56 AM
Long term Bt216 Scion FR-S / Toyota 86 GT86 General Forum 3 06-07-2013 12:58 AM
Fuel Trims - Long term and short term victorb Engine, Exhaust, Transmission 6 03-27-2013 03:18 PM
Short Term and Long Term Fuel Trims naikaidriver Engine, Exhaust, Transmission 3 03-18-2013 10:55 PM
