#58 |
Drives: 2015 frs
I made a little progress today.
I installed the front timing chain cover. I was able to press on the superdamper hub. Bolted the damper, spacer, and supercharger pulley onto the hub. I was going to bolt the flywheel on, but apparently the Spec supertwin clutch kit didn't include flywheel bolts. I ordered the flywheel bolts, and the flywheel locking tool. I need the tool to install the harmonic balancer center bolt. After the harmonic balancer crank bolt is in I can install the oil pump drive mandrel in front of the supercharger pulley. It bolts into the last 3 open holes on the damper assembly. |
| The Following User Says Thank You to Zer0 For This Useful Post: | Verl0r4n (10-31-2018) |
#59 |
Drives: 2015 frs
I got the damper buttoned up. I used a fly wheel holding tool. I wouldn't recommend installing the front crankshaft bolt without one. I used the old flex plate with the tool just in case it screwed up the ring gear. The tool was made well, and fit was perfect.
| The Following User Says Thank You to Zer0 For This Useful Post: | Verl0r4n (11-03-2018) |
#60 |
Drives: 2015 frs
About ready to measure to see if bell housing is centered to the crankshaft. Still need to torque everything down to spec, then get my readings. I will post up measurements I get and if I had to get offset dowel pins, and what offset I needed
| The Following User Says Thank You to Zer0 For This Useful Post: | DustinS (11-09-2018) |
#61 |
Drives: 2015 frs
I measure the offset of the bearing race to crankshaft centerline. It's not out enough to buy dowel pins .005 I adjusted the dial indacator, and magnetic stand. After adjustment I remeasured, it fell to a consistent .002 I called that good it's in spec
#62 |
Drives: 2015 frs
I ordered ARP flywheel bolts for my SPEC Supertwin clutch kit they wouldn't work. The original bolts have a 15mm head size with a 19mm flange formed under the bolt head. The ARP bolts had a 19mm 12 point head that once was tightened down was recessed into the fly wheel with no room for a socket to go into the recess with it. I ordered a set of ITC billet flywheel bolts that were made like the factory units. They worked with my flywheel, and are higher strength.
#63 |
Drives: 2015 frs
I installed the SPEC Supertwin clutch, bell housing, and transmission midplate. I got all the measurements to check the through out bearing air gap. I need a 0.33 shim. I ordered a shim pack so I can get everything dialed in, and bolted together next week hopefully.
| The Following User Says Thank You to Zer0 For This Useful Post: | Thedishdoc (03-08-2019) |
#64 |
Drives: 2013 BRZ Limited 6MT
this things gonna be a monster
#65 |
Drives: 2015 frs
Thanks, I hope it is.
#66 |
Drives: 2015 frs
Not much progress lately. I received the slave cylinder shims, and installed them. Next will be to mount the engine, and transmission together. After that slide it in the car, and adj firewall and trans tunnel until I like the fitment. I am also going to order the 8.8 rearend kit while I'm at it. That way I can set my driveline angle and not have to worry about it changing because of a rearend swap later down the road.
#67 |
Drives: 2015 frs
I received a front bash bar made by Street Faction for Christmas from my girlfriend today. I ran parts from Street Faction on my S14 Silvia, and loved them. They are more established now, and putting more personal touches in the design now.
#68 |
Drives: 2015 frs
From looking at other swaps it looked like I needed to remove 2 more brackets in the tunnel. So I did that today. Hopefully I can get the motor and trans mated together, and sitting in the engine compartment.
#69 |
Drives: 2015 frs
I ordered a stand alone LT4 harness from http://www.swaptimeusa.com awesome to do business with. Mitch does genIV and genV stand alone conversion harnesses using new oem units.
#70 |
Drives: 2015 frs
Made a little progress today. More to come tomorrow.
| Andy0323's Back To Basics Build Thread <Long Term Project> | andy0323 | Member's Car Journals | 15 | 02-02-2018 01:16 AM |
| long term and short term | brichard0625 | Engine, Exhaust, Transmission | 7 | 08-26-2013 09:56 AM |
| Long term | Bt216 | Scion FR-S / Toyota 86 GT86 General Forum | 3 | 06-07-2013 12:58 AM |
| Fuel Trims - Long term and short term | victorb | Engine, Exhaust, Transmission | 6 | 03-27-2013 03:18 PM |
| Short Term and Long Term Fuel Trims | naikaidriver | Engine, Exhaust, Transmission | 3 | 03-18-2013 10:55 PM |
