#141 |
Drives: 2015 frs
I hope so! I pulled out the mounts to weld them up tonight. Hopefully tomorrow I can pull the crossmember out and final weld in the lower mount brackets to the crossmember
#142 |
Drives: 2015 frs
Mounts are welded up and complete. Next is drop the crossmember, and weld on the tacked in lower motor mount . Doing that now. Then bolt it all together and check everything still fits.
#143 |
Drives: 2015 frs
I finished welding the mount plates to the crossmember. Did a test fit I was able to start all the bolts, but there is some side load on the bolts. I will need to clearance the holes with a dremel or one size up with a drill bit.
#144 |
Drives: 2015 frs
Drilled holes one size bigger on upper and lower mounts. Everything went together easily. Next items to tackle are confirm correct driveline
angles, rework trans mount as needed, steering rack mounts, and steering shaft fab from column to rack.
#145 |
Drives: 2015 frs
I adj. the driveline angles I'm able to get on the vertical plane engine 1° down, driveshaft .5° down, Differential 0°. This seems to be about the best I can get. I need to get the readings on the horizontal plane. Not a fan of the offset pinion on the differential.
#146 |
Drives: 2013 BRZ Limited 6MT
What are you using to take these measurements? What tools and method?
#147 |
Drives: 2015 frs
Digital protractor to measure the degree, and direction of the slopes of the engine, driveshaft, and differential then a little math, or plug it into a app to do it for you. That's for the top to bottom angles. The side to side angles will be trickier. I will be starting work on those on my day off.
#148 |
Drives: 2015 frs
Started the transmission mount build. Pictures are the upper portion of the mount transmission side. Next will be the lower portion on the chassis side. I may lighten the trans side with a few holes still.
#149 |
Drives: 2015 frs
Reshaped the upper mount, and made the center bushing section for the lower mount.
| The Following User Says Thank You to Zer0 For This Useful Post: | Milhouse86 (10-11-2019) |
#150 |
Drives: 2015 frs
I have been working on the chassis side of the transmission mount. I have plates built for the underside the transmission tunnel, and plates that sandwich the sheet metal of the tunnel with plates on the inside of the passenger compartment. Here is a picture of the chassis side trans mount center section.
#151 |
Drives: 2015 frs
Transmission mount setup
#152 |
That turned out great
| The Following User Says Thank You to ka-titties For This Useful Post: | Zer0 (10-16-2019) |
#153 |
Drives: 2015 frs
Test fit. Inside plate one on each side, and mount holding the transmission in its final location. Will pull out, and powder coat the fabricated mount kit and crossmember. Hopefully this week. Probably more like 2 weeks out. Forgot about making the rack and sway bar mounts.
#154 | |
| Andy0323's Back To Basics Build Thread <Long Term Project> | andy0323 | Member's Car Journals | 15 | 02-02-2018 01:16 AM |
| long term and short term | brichard0625 | Engine, Exhaust, Transmission | 7 | 08-26-2013 09:56 AM |
| Long term | Bt216 | Scion FR-S / Toyota 86 GT86 General Forum | 3 | 06-07-2013 12:58 AM |
| Fuel Trims - Long term and short term | victorb | Engine, Exhaust, Transmission | 6 | 03-27-2013 03:18 PM |
| Short Term and Long Term Fuel Trims | naikaidriver | Engine, Exhaust, Transmission | 3 | 03-18-2013 10:55 PM |
