#15 |
Less drag, with less downforce. Are you out of options to increase front downforce and/or ways to make the rear looser?
I use a much, much larger wing than your GTC200, with a higher mount, without balance issues. |
#16 |
Drives: 2014 BRZ
This is not how I understand canards to work. My understanding is that drag reduction is their main purpose by causing the air flow to be smoother around the front wheels. I'm pretty sure you'd needs some seriously massive canards to actually generate any downforce.
#17 | |
Drives: 2014 BRZ
)Thx
#18 | |
| The Following User Says Thank You to CSG Mike For This Useful Post: | Sleepless (09-03-2018) |
#19 | |
Remember there is both static and dynamic balance involved, in getting the cornering behavior you want out of a car. When one limits you, you can use the other to (somewhat) compensate/balance. |
#20 | |
Drives: 2022 LR Defender, 2015 FRS_ST5/TT5
Lutfy
2015 FRS NASA ST/TT5
2022 LR Defender 2023 BMW M2 |
| The Following User Says Thank You to lutfy For This Useful Post: | AndyBRZ (09-11-2018) |
#21 |
There is still downforce at negative AOA, because your AOA measurement is relative to the ground, and not the plane of the airflow over/around the car, hitting your wing.
#22 | |
Drives: 2014 Silver BRZ Track Car
Like you, I was missing a few MPH at the end of most tracks when comparing to before Aero BRZ in my case. Awesome on the shorty and twisty ones. After reading your thread, I have no doubt what was causing the drag. I was running 6 degrees positive AOA at the center Really out of ignorance more than anything and basing myself in the curves I saw in the internet. I am going to shorten the eyelets myself and go to -2 degrees AOA at the center of the wing to start with. That should suffice. For the record, the two eyelets when threaded into the rod are too long to bottom out inside the rod and you will not get them any closer with the potential to break them. I plan to shorten all eyelet threads at least 1/4" on each end so it should give me what I need for down to -4 AOA at the center and to avoid contact between them. Please keep us posted with your results on the different AOA at the center of it and your impression on downforce and drag. I do have the canards and the APR front splitter along with the APR rear spats and the FT86 aggressive rear diffuser with differential covers. Like you, I have contemplated to swap this wing for the GT250 which I know produces less drag cause I have driven on it on my buddy's BRZ but it is much more $$ and I am on a tight budget. On the other hand, I had talked to the guys from GoodAero and I wish I had the budget to really invest with them. They are awesome and very thorough but unfortunately, cannot afford it. |
#23 | |
I realized no need to get rid of the wing just find a way to adjust. Will update with new settings soon. Lutfy
#24 | |
Drives: Track preped NA FRS
I also had an offtrack excursion at 110mph, so now Im rebuilding my splitter (the rest can be left to imagination). Im going for a bigger and more robust splitter this time, trying to add front downforce instead of removing more from the rear. |
| The Following User Says Thank You to Icecreamtruk For This Useful Post: | CSG Mike (09-11-2018) |
#25 | |
![]() When you got it down to 1 degree, was your current rod height set to full low? Mine was maxxed out (low end) before I got shorter rods. Do you know your previous setting (angle) prior? Even at fully maxxed out (low), I was facing touch of high speed understeer but rear end stability was very confidence inspiring. I could put the power down (was limited by LSD until I got that fixed) much earlier. BUT it was costing me some speed.... Lutfy
#26 | |
#27 | |
FWIW, I am running -3.2 front, -2.6~ rear with zero toe. I had 550/550lbs square but had to get 650lbs rear to get rid of the nasty push. Now the car is balanced (mostly and very well indeed with a touch of understeer), I was trying to gradually reduce aero (back) to gain some time and experiment. I'll have to admit, the LSD made a fair bit of difference in my car. I had to go from almost full stiff (compression) at the back to middle setting. In the past I was using shock as a bandaid to balance but thats not the issue now. Lutfy
#28 | |
| The Following User Says Thank You to CSG Mike For This Useful Post: | lutfy (09-11-2018) |
| APR GTC200 wing + Seibon CSL Trunk (SOCAL) | Greddy86 | Exterior Parts (Aero, Lighting, Etc.) | 22 | 04-01-2018 01:51 PM |
| Does anybody have seibon gt wing or apr gtc200 universal wing on their car? | spicyricecake | Cosmetic Modification (Interior/Exterior/Lighting) | 6 | 03-17-2016 09:38 AM |
| WTB: Apr GTC200 or Seibon GT wing | spicyricecake | Want-To-Buy Requests | 0 | 03-14-2016 10:28 AM |
| BRZ: Setting up Aha radio? | WarthogBrz | Electronics | Audio | NAV | Infotainment | 7 | 03-22-2014 05:27 AM |
| This is how I pan on setting my car up where does it put me | jdzumwalt | Tracking / Autocross / HPDE / Drifting | 16 | 02-10-2013 11:24 PM |
