Old 08-09-2017, 05:31 PM   #29
Clipdat
Proud of BOXER
Clipdat's Avatar
Drives: Subaru Boxer
Yep, I know. This is one of the reasons I didn't go Bilsteins
Originally Posted by mav1178 View Post
The point of OE replacement shocks is not for wide wheel fitment. The same could be said for Bilstein and any other shocks that can be reused with stock springs.
Yeah, tell me about it. It looks like I'm going to have to spend hundreds of dollars to get my ASTs re-valved to get them how I want them.
Adjustable coilovers are great but the vast majority of people using them do not understand how to use and maintain them properly.
Originally Posted by humfrz
I'm old and lazy
Old 08-10-2017, 12:53 AM   #30
ThucP
do they sell just the shocks alone?
ThucP is offline   Reply With Quote
Old 08-10-2017, 03:50 AM   #31
TachyonBomb
Drives: 06 Evo GSR SE, 17 Series Yellow BRZ
I really do like these and was almost about to pull the trigger on them. But part of me really wants to wait until the spring rates for the following get discovered
stock 2017 brz PP suspension
sti pink springs
2015 jdm brz TS suspension
2018 USDM brz TS suspension (most likely a revised sti pink to work with sachs damper)
Just to get a better understanding of where the stock and OEM-ish suspensions are coming from before I move on from the 2017 PP suspension.
but for real I'm my this now trigger finger is itching for this lol!
TachyonBomb is offline   Reply With Quote
Old 08-10-2017, 06:23 PM   #32
mav1178
mav1178's Avatar
Drives: 2005 Toyota Camry
I'll be honest and say these are probably an upgrade over stock 2013-2015 shocks, and practically the same as what you have on your car now (stock shocks by Sachs).
The ride quality may be marginally better given that the shock design is meant for a mildly lowered application, however you can probably get more meaningful performance upgrade from swapping out tires.
The spring rate won't matter much given how soft they are.
The Following 3 Users Say Thank You to mav1178 For This Useful Post:
Capt Spaulding (11-03-2017), nikitopo (11-04-2017), TachyonBomb (08-10-2017)
Old 08-10-2017, 06:24 PM   #33
mav1178
mav1178's Avatar
Trying to figure out if they do or not. Showa sells this as a complete package in Japan.
The Following User Says Thank You to mav1178 For This Useful Post:
Old 08-10-2017, 07:43 PM   #34
churchx
churchx's Avatar
Drives: 2014 GT86
To me it looks like B6 looks a bit better offering from somewhat same budget class. Or depending on type of use, maybe also Koni Yellows, Flex Z or Tarmac 0. Of course if i'd live in Japan, it might be different, but adding on top of base price shipping & import charges, +no local serviceability ..
The Following User Says Thank You to churchx For This Useful Post:
Old 08-10-2017, 08:34 PM   #35
mav1178
mav1178's Avatar
Probably, but:
  • Adjustable coilovers should not be included on this list for comparison, it's not the same as non-adjustable OE replacement springs/shocks. They may be similar in price but the comparison should just end there. People shopping for STI springs aren't going to cross-shop low-end coilovers, and vice versa.
  • I'm working with the importer on establishing warranty/service/support in the US. They are Showa's distributor in Japan.
  • No import charges for North America. Obviously you are not in North America so parts of this doesn't apply for you.
A serious question: Is Bilstein B6 a better option? Why?
Old 08-10-2017, 11:37 PM   #36
TachyonBomb
I was kind of suspecting that about the OEM-ish options compared to the 2017 pp suspension. I guess I've just been waiting for someone to test them. I also wanted to wait until more 2017 specific options came out whether its in the aftermarket like these showas or the 2018 TS stuff STI is going make for it.
But I also like these because it's nice to have someone think of the shock travel and modify it to go with the spring instead of lowering the spring only and not taking the stock shocks piston travel parameter shift.
So I see there is one of these in stock on their website, I also see these are designated as 2017 specific can FRSport or anyone else shed some light on why or how the 2013-2016 version is different from the 2017 version?
Also I would like to know if springs made for the stock shocks are interchangeable with the springs in this set up?
It would be neat to add a 25mm drop spring into this shock because it would only be operating 10mm lower than it was intended to instead of operating 25mm (1in) lower thank it was intended to if it was on an OEM shock. Of course there is the rear axle issue that comes with lowering but never the less interesting.
Old 08-11-2017, 03:00 AM   #37
mav1178
mav1178's Avatar
To address your questions:
  • The Evolution kit(s) all come with the same shock, but Showa has a different part number for the 2017+ kouki models. I was told by Showa's importer that the springs are different, I suspect the springs are slightly progressive rate and may have slightly different overall feel vs the 2013-16 zenki models. On paper the springs are virtually the same rate.
  • The shocks are OE replacement, so any OE replacement aftermarket springs will work with this setup.
  • It would be, except it won't be as intended and may be lowered past the optimum range. Plus, Showa as a company is very conservative and they tend to stay on the safe side when it comes to parts.
TachyonBomb (08-11-2017)
Old 08-14-2017, 04:12 AM   #38
Norkoastal
Never on Time Always Late
Norkoastal's Avatar
Drives: #silenced crickets
Any perceived improvements from this new set vs. the 13-16 sti pink spring/silver sti strut combo? Im constantly battling crappy roads, and would prefer this comfort focused style over a coilover system if tye performance benefits/height (raise) arent diminished.
CO>CA Cartel
Norkoastal is offline   Reply With Quote
Old 08-17-2017, 04:53 PM   #39
mav1178
mav1178's Avatar
Hard to say without driving two identical cars side by side w/ these springs/shocks vs yours.
If your suspension is still stock and have significant mileage on them, they may very well be worn out.
Old 08-17-2017, 07:50 PM   #40
Norkoastal
Norkoastal's Avatar
Im interested in a sti silver strut pink spring comparison to these (my current setup). By the look of the extended body, there is more travel to help keep the springs soft which will help with the crap roads around here that eat up most suspensions travel and make for a bouncier ride.
CO>CA Cartel
Old 08-23-2017, 11:51 PM   #41
wootwoot
Drives: FRS
Questions:
1. There has been talk in this thread of increased suspension travel with this kit. What I am seeing is a shaft that protrudes from the shock body a shorter distance than the stock unit. By the looks of it, once you put the bump stop on and the spring compresses you won't have much of any travel left. So what am I missing?
2. Why does the 2017 kit lower the car 15mm all around but the 2012+ lowers it 10mm front and 15mm rear?
3. Why is the 2017 kit $100 more?
wootwoot is offline   Reply With Quote
Old 08-24-2017, 06:03 PM   #42
mav1178
mav1178's Avatar
Originally Posted by wootwoot View Post
Questions:
1) The shock piston is in a better position. Suspension travel isn't longer, just the shock piston will be in a better position and won't bottom out as easily vs a stock design shock body
2) I had discussions with them about this, it mostly stems from the fact that Chuhatsu (the maker of the springs) took an OEM approach and wanted springs that matched with the factory handling. So to a certain extent, this discrepancy in lowering amount is attributed to the fact that the factory spring rates are slightly different.
3) See #2 above. The shocks are identical (part numbers) but springs are different.
Search this Thread:
Advanced Search
Suspension UPGRADE - Shock/Spring Pkg vs. Coilover System - Which to choose? themajesticone Suspension | Chassis | Brakes -- Sponsored by 949 Racing 80 11-14-2014 07:01 AM
Rebuilding strut/shock dampers to be firmer than spring rates? fooddude Suspension | Chassis | Brakes -- Sponsored by 949 Racing 10 04-16-2014 01:23 AM
Can shock-dynos tell you what the highest spring rate it can handle? fooddude Suspension | Chassis | Brakes -- Sponsored by 949 Racing 42 02-16-2014 05:43 PM
Stock dampers on the BRZ are made by Showa. Same for FRS? mrha Suspension | Chassis | Brakes -- Sponsored by 949 Racing 17 10-19-2012 06:40 PM
