#29 |
Drives: 2017 toyota 86
I know this is old. But is that the torque solution TB spacer with the grams? Thinking about getting grams or blox TB but using TB spacer for WMI got to confirm fitment.
#30 |
Yes it is! idk if they work better (or worse) together than individually as I got it tuned together but it's been running fine since!
#31 | |
That's because you're getting in more air at lower throttle openings, not because it's actually flowing more at WOT. I'd be interested in seeing raw MAF readings at WOT on a bigger TB vs the stock one on the same car and tune. Anything I've read from reputable tuners says that on an N/A setup the stock TB isn't a bottleneck, so going bigger doesn't add hp.
#32 |
Drives: 2013 WR Blue Pearl BRZ Limited 6MT.
I will be mating this up with the racer x intake manifold and greddy snorkel. All that air suction. Just need time peeps.
| The Following User Says Thank You to Dr. BRZ For This Useful Post: | SuperTom (01-10-2020) |
#33 |
Wes
that should sound nice
Instagram: @gt86ws
| The Following User Says Thank You to StraightOuttaCanadaEh For This Useful Post: | Dr. BRZ (06-25-2019) |
#34 |
Drives: 2015 BRZ Limited
I saw in that RacerX manifold thread that you were going to get one. Didn't realize you had the Grams TB as well. I too have a Grams, and was lurking on that manifold thread, waiting for someone to try it. I'd be interested in your results after you get everything together.
Harrop Supercharger | Delicious Tuning Flex Fuel Kit | ACE Type-A 350 Header + OP | CSG Touring 86 Catback | RacerX Fabrication Catch Can | Jackson Racing Dual Radiator/Oil Cooler | Tuned by Zach from CSG
#35 | |
| The Following User Says Thank You to Dr. BRZ For This Useful Post: | MJones_RB (06-26-2019) |
| OEM throttle body | nikitopo | Engine, Exhaust, Bolt-Ons | 10 | 01-07-2024 12:50 PM |
| OFT and Grams throttle body | 86Speedy | Software Tuning | 27 | 05-05-2017 06:21 PM |
