Old 07-12-2017, 03:51 PM   #15
tigermack
STX 188
tigermack's Avatar
Drives: STX BRZ
Send a message via AIM to tigermack
Originally Posted by norcalpb View Post
that's in the rear and that car is from the 90s
Front of that car has bent strut towers, too.
tigermack is offline   Reply With Quote
Old 07-12-2017, 04:53 PM   #16
finch1750
Undisputed El Presidente
finch1750's Avatar
Drives: Zenki 37J ZN6
Originally Posted by solidONE View Post
how about checking the strut tower? you've not shown how badly the strut tower is misshapen. It might not even be all that bad.
Press the undamaged flat camber top against the 'damaged' shock tower and check for gaps with some short of feeler or feeler gauge. If there isn't too big a gap, then you've been worried about nothing. Just replace that POS camber plate.
It isnt bad enough to be able to get a good pic of it. So I could just be overeacting. The nut not sitting flush was the only sign of it being damaged. Once torqued down it seems to fit basically flush.
Originally Posted by tigermack View Post
Common with e36's. Might need reinforcement plates.
Interesting. Did people generally repair it first or just throw on the plates and call it good?
Also Feal, just like BC, Stance, etc have their top hats made in Taiwan.
True. Guess it shouldn't surprise me that much
Old 07-12-2017, 04:58 PM   #17
solidONE
solidONE's Avatar
Drives: FR-S Whiteout
A good part is a good part, regardless where it was made. You dont think USA or Germany make unreliable things? LMAO Even JDM companies put out shoddy parts (hemm takata.. ahemm).
Intent > Content
The Following User Says Thank You to solidONE For This Useful Post:
Scrappydoo (07-13-2017)
Old 07-12-2017, 05:27 PM   #18
tigermack
STX 188
tigermack's Avatar
Drives: STX BRZ
You put the plates on under and bolt it down. It should pull it flat. At least that's how it was with the e36, very thin sheet metal. I also ended up using a rubber mallet to help flatten it down.
The Following User Says Thank You to tigermack For This Useful Post:
finch1750 (07-12-2017)
Old 07-12-2017, 08:49 PM   #19
strat61caster
strat61caster's Avatar
You'd call this a good part?
ineedyourdiddly
Old 07-12-2017, 08:56 PM   #20
go_a_way1
Not Bаnned Anymore
go_a_way1's Avatar
Drives: Heavily Modified FRS
My turbo is made in Taiwan, no complaints from me here. I feel this is more of an issue with the metals chose for the application, not where it was made lol.
The Following 3 Users Say Thank You to go_a_way1 For This Useful Post:
finch1750 (07-12-2017), solidONE (07-13-2017), strat61caster (07-12-2017)
Old 07-13-2017, 04:49 PM   #21
solidONE
solidONE's Avatar
nope. I'd call it a POS.. lmao
Although, we dont even know how exactly it got bent the way it did. Was it like this new out of the box? Was it damaged due to improper install? Or did it inexplicably change shape for no reason? lol
Intent > Content
Old 07-13-2017, 05:15 PM   #22
strat61caster
Deformed strut towers, top hats, camber plates, have been an issue for decades, actually since their very first inception, it's basic engineering and material science and sometimes manufacturers get it wrong, aftermarket companies get it wrong slightly more frequently.
Google "deformed strut tower" and you'll get hundreds of pictures of E36's like Tigermack mentions.
Only time and data collection will tell if this is a problem with the 86 chassis itself or certain aftermarket designs, or just a fluke.
ineedyourdiddly
Old 07-13-2017, 05:17 PM   #23
solidONE
solidONE's Avatar
^ yuck
Intent > Content
Old 07-13-2017, 05:33 PM   #24
strat61caster
^ yuck
Given the fact that this is the only one I've seen so far after 5 years of the 86 getting pounded on I'm optimistic that this will be a rare case of potentially severe use (OP's roads are pretty shitty, you don't have to drive a car hard or fast to wear it out prematurely) or a bad aftermarket part or a fluke.
ineedyourdiddly
The Following 2 Users Say Thank You to strat61caster For This Useful Post:
mabviper (07-13-2017), solidONE (07-13-2017)
Old 07-13-2017, 08:54 PM   #25
solidONE
solidONE's Avatar
Definitely not a common thing on this chassis. So much for german engineering eh?
Intent > Content
Search this Thread:
Advanced Search
FS: TRD Tower strut bar Sehwan Kim Brakes, Suspension, Chassis 0 01-04-2017 02:26 PM
This is how camber affects toe in front. Also RCE camber plate info. Pat Suspension | Chassis | Brakes -- Sponsored by 949 Racing 17 05-04-2016 11:08 PM
Strut Tower Bar VS Strut Tower Brace norcalpb BRZ First-Gen (2012+) -- General Topics 8 10-23-2014 11:31 PM
Do I need a Strut Tower Bar? muffinz Suspension | Chassis | Brakes -- Sponsored by 949 Racing 45 10-11-2014 02:53 PM
"Strut" Your Stuff With A BeatRush Strut Tower Brace // DSG PERFORMANCE Jason@DSG Groupbuys 14 12-31-2013 10:06 AM
