86WORX
Old 07-10-2017, 11:27 PM   #15
imnotsureaboutbrz
Drives: between cars...
Originally Posted by Sleepless View Post
That was a good read, I read it before I got my car but rereading leads me to believe that it may be the EBD I'm hearing not the brake lsd... I'm gonna have to wait 2 weeks to test my hypothesis.
imnotsureaboutbrz is offline   Reply With Quote
Old 07-11-2017, 01:27 AM   #16
Sleepless
Sleepless's Avatar
Drives: 2014 BRZ
@Sleepless @x808drifter
Per the CSG thread mentioned like 6 times already some feel that the EBD system prevents trail braking and weight transfer and the sudden application of brakes midcorner creates unexpected behaviour. (I haven't really felt that, trail braking for me)
I honestly don't know if that's what op is hearing but I think it's worth experimenting with. Knowing if the slip light is flashing will determine if the car is doing something without having a test.
I’m pretty sure that EBD is not the same as Brake LSD. Pedal Dance definitely gets ride of EBD; main reason I have the 86 Nanny from Beastronix. I’ve not seen anything regarding Pedal Dance and Brake LSD. EBD is active under braking. Brake LSD is active under acceleration.
Sleepless is offline   Reply With Quote
Old 07-11-2017, 02:40 AM   #17
strat61caster
strat61caster's Avatar
Ebd only happens when you use the brakes, it's not spontaneous, if you're using the brakes midcorner than that may be your high pitched noise.
idk just parroting the thread that pedal dance turns off the auto lsd, maybe not the case anymore for the '17+ I'm not quick enough or good enough to notice when auto lsd kicks in.
It's my understanding that while they are independent systems they both get turned off via pedal dance. I never meant to imply they were the same.
ineedyourdiddly
Old 07-11-2017, 01:58 PM   #18
Sleepless
Sleepless's Avatar
Drives: 2014 BRZ
I don't see any mention of Auto LSD or Brake LSD in the Pedal Dance thread. Is there a reference about it somewhere else?
Old 07-11-2017, 02:57 PM   #19
strat61caster
You're right, there's no explicit link in that thread except the description of lifting a wheel which is consistent with the description of what "auto-lsd" purports to accomplish:
Without the brake dance, if you upset the car's computers enough, it will still re-engage traction and stability control. This specifically involves enough of a loss of traction that you're getting what the ECU believe to be uncontrolled wheelspin, the equivalent of lifting a rear wheel.
http://www.ft86club.com/forums/showp...89&postcount=1
Mentioned here as well:
http://www.ft86club.com/forums/showp...02&postcount=7
Guess I just drew my own conclusions (that could be false), the "auto-LSD" feature didn't really come to light as an explanation until a year or two after this initial "research" and it's rare for anyone to go back and update a technical post years later.
ineedyourdiddly
Sleepless (07-11-2017)
Old 07-11-2017, 05:19 PM   #20
Why would one want Brake LSD off?
Does the pedal dance turn it off?
When the car is being pushed to the limits, the VSC ECU can think the inside rear wheel is spinning under certain conditions, and applies brakes to assist the Torsen.
Imagine having brakes suddenly being applied to one corner of the car at 125+. I've experienced it, and can replicate it at will. Pedal dancing eliminates this behavior. So does a mechanical LSD (like Cusco or OS Giken).
Normally, it's pretty seamless, particularly at lower speeds. When it happens at triple digit speeds... code brown may result. I've seen some cars fly off at T8 of WSIR (very bumpy 120+ corner) because of the E-diff function. The corner itself is only about 0.65G lateral, but the bumps can let a wheel spin, and then it gets scary.
Old 07-11-2017, 05:20 PM   #21
There was no 'problem' persay, I just heard a high pitch mechanical noise coming from the back tire. The car wasn't skipping across the pavement, but I was making those Michelin pss work. That run I finally hit the line I was wanting and resulted in besting the 2 other CS miatas and the 2 Z06s
well dang... I really thought I could avoid the pedal dance non-sense by going with a 2017 model... I guess we will see next month if I feel/hear any differences at the next event.
Nothing wrong with using the pedal dance!
E-Brake issue "clunking noise" when pulling the e-brake while rolling. Kinzo Suspension | Chassis | Brakes -- Sponsored by 949 Racing 55 06-20-2018 11:14 PM
Diagnosing a brake noise, need help.. Subie_Nubie Suspension | Chassis | Brakes -- Sponsored by 949 Racing 18 12-27-2017 03:47 AM
Brake pedal release noise FR-YES Issues | Warranty | Recalls / TSB 4 10-19-2014 05:39 AM
Loud clunk noise when i pull E-Brake Deagle50 Issues | Warranty | Recalls / TSB 28 09-20-2014 02:01 AM
rear brake noise norcal_brz Suspension | Chassis | Brakes -- Sponsored by 949 Racing 1 08-19-2013 04:25 PM
