Old 07-05-2017, 02:35 PM   #29
krayzie
Drive From Home
krayzie's Avatar
Drives: BRZ STI Performance
IIRC there was a post on Temple of Vtec a long time ago where somebody's Razo shift knob cracked and the dude money shifted into 2nd gear and hit 11,000rpm. The engine survived but the gearbox blew.
krayzie is offline   Reply With Quote
The Following 2 Users Say Thank You to krayzie For This Useful Post:
Irace86.2.0 (07-05-2017), Tcoat (07-05-2017)
Old 07-05-2017, 02:37 PM   #30
nikitopo
nikitopo's Avatar
Drives: '15 BRZ RA
Originally Posted by krayzie View Post
I want to attend this Gforce school of physics.
I think now he will go back to school.
Old 07-05-2017, 02:51 PM   #31
That can be a result as well. A lot depends on the clearances and some engines can take it better than others.
I just used the 1,000 rpm as a sort of place holder number. You could go over 1,000 or 10,000 a hundred times with no issue or you could blow things apart at 950 the first time you did it. It isn't an exact science.
I miss shifted a drag set up Pinto once. The engine survived fine, the tranny had some minor damage and the u-joints all but blew apart.
As far as the OP here goes he is fine.
krayzie (07-05-2017), Ultramaroon (07-05-2017)
Old 07-05-2017, 03:42 PM   #32
FR-Sky
FR-Sky's Avatar
Drives: 2013 FR-S 10 series [755]
It is called money shift..sounds so Gangster....
I think you are fine if you don't do it all the time...
plus, it is very hard to mis-shift from 3rd to 4th....little more practice, yeah?
FR-Sky is offline   Reply With Quote
Old 07-05-2017, 03:48 PM   #33
Ultramaroon
fabulous
Ultramaroon's Avatar
I believe, for the fa20, the weak link from an acute over-rev is between the wrist pin and piston. The holes stretch and give up the ghost. It has been covered here a few times.
Which astonishes me considering the floofiness of the valve springs. The valves must be super light.
Tcoat (07-05-2017)
Old 07-05-2017, 04:01 PM   #34
Irace86.2.0
Irace86.2.0's Avatar
Drives: Q5 + BRZ + M796
Did you even bloody well READ what I said before?
Yea. Even a thousand bro.
Old 07-05-2017, 04:12 PM   #35
Irace86.2.0
Holes stretch? From force or heat/friction? Acute overheating would cause metal expansion, right, and lubricants to heat to dangerously thin levels resulting in metal on metal contact? If that is what we are talking about then could that much heat really occur in a second or two max? I can't see it happening.
Old 07-05-2017, 04:20 PM   #36
You are stuck on heat. There is much more than heat involved in a miss shift over rev situation. The parts are simply not designed to move that fast and they hit things or shift and blow apart. Heat has nothing to do with that. We are not talking about sitting there with you foot on the gas at redline for an hour.
Old 07-05-2017, 04:29 PM   #37
Tell 'ya what. Why don't you just go out and make some videos of a few miss shifts at just 1,000 rpms over redline. Just a dozen or so would satisfy me that everything I have know and experienced about over revs is totally wrong. Hell you really want to convince me then do a couple at only 2,000 over since that should be fine as well.
Old 07-05-2017, 04:47 PM   #38
topholney
Drives: 2015 BRZ Limited
Originally Posted by skkk View Post
I did not... cause it just hit like slightly above the redline and then it dropped under the redline right away. I'm just so worried about it.
Early on when I started driving mine I miss-shifted from 5th to 4th. I immediately hit the clutch to save it but definitely freaked myself out. I've driven probably 30k miles since then and haven't noticed any issues. If you know for sure something doesn't feel right, then get it checked out. Just learn from your mistakes and it should be fine.
topholney is offline   Reply With Quote
Old 07-05-2017, 05:08 PM   #39
nikitopo
nikitopo's Avatar
Drives: '15 BRZ RA
I haven't figured out yet if this guy did it on purpose or by mistake. I was reading somewhere that he was trying that day to get used to the right-hand drive position:
On the other side, it is a bit bizarre to miss shift by accident and manage to make a lap record.
Old 07-05-2017, 06:04 PM   #40
Ultramaroon
fabulous
Peak linear accel. Casting yields.
Old 07-05-2017, 06:09 PM   #41
Ultramaroon
fabulous
His R8 which has a big ol' stepladder, gave out so he begrudgingly took out his backup vehicle which has a spring loaded centering mechanism. Forgetting about the spring, instead of allowing the gearshift to center itself for 4th, he nudged it across the nonexistent hard gate.
The rest is, as they say, expensive.
Old 07-05-2017, 06:43 PM   #42
nikitopo
nikitopo's Avatar
Drives: '15 BRZ RA
Or not so much for race cars
The Following User Says Thank You to nikitopo For This Useful Post:
Search this Thread:
Advanced Search
FS. Case of 12 Redline D6 ATF FastWhite Mechanical Maintenance and Tools 0 12-07-2015 01:59 AM
Redline 360 Review z3ro User/Vendor/Sponsor Reviews, Feedback, Comments 3 07-26-2014 08:41 AM
Redline 360 z3ro User/Vendor/Sponsor Reviews, Feedback, Comments 2 07-17-2014 10:49 AM
FS: Redline MT-90 BMWDavid Transmission and Driveline 3 01-07-2014 09:52 AM
redline kendalldwhite Scion FR-S / Toyota 86 GT86 General Forum 5 08-26-2012 03:12 PM
