Engine, Exhaust, Transmission Discuss the FR-S | 86 | BRZ engine, exhaust and drivetrain. |
08-22-2019, 08:49 AM | #71 | |
Drives: Whiteout FR-S, Evo 8 RS
08-22-2019, 12:45 PM | #72 |
Trying to drop a 17+ engine into a 13-16 is just not worth it!
The Following User Says Thank You to CSG Mike For This Useful Post: | mrg666 (08-23-2019) |
08-22-2019, 01:18 PM | #73 |
Drives: 2013 Subaru BRZ
08-22-2019, 05:14 PM | #74 |
08-22-2019, 09:51 PM | #75 |
Drives: brz
08-24-2019, 03:23 PM | #76 |
Drives: Friggin Really Sweet
Would rebuilding/strengthening an 13' engine be a good route to go to prevent potential engine failures especially when it's pushed hard?
If build the 13' with a 17 base would it be better/reliable? With engine rebuild(s) will I pass smog/emissions?(I honestly don't know+in california) Thank you. I'm really trying to keep this engine for as long as I can with the original car and have been contemplating on getting it done before any track use is considered although it is hailed to get seat time in as much as possible but if an engine blows it's seat time loss as well. To LS/2J it I'd rather sell the car and get an A90(Which I'll get later down the road+still have FRS/or not for it) for that amount i'd spend on the FRS tbh but i'd love to/want to keep this car. |
08-24-2019, 03:39 PM | #77 | |
Drives: brz
The Following User Says Thank You to solidsnake11 For This Useful Post: | nikitopo (08-24-2019) |
09-23-2019, 08:51 PM | #78 |
Hey guys. So I've been getting a few messages in regard to whats to be done and the difficulty with swapping the engine properly. So I'm gonna answer here to the best of my memory:
Its really cut and dry, the only thing was I had to use the cam gears which I think needs the E16 or E12 torx socket, crank trigger wheel and all the sensors (Fuel pressure, coolant temp, crank sensor etc.) from the 13'. Apologies, but I don't have that info for the correct torx size right now because all my tools are in storage. I ended up purchasing a torx kit from O'Rielly's. Also had to keep the alternator and A/C compressor from the 13. The only sensors I kept from the 2017 were the cam position sensors since they are more accurate. Being that you have to take the cam gears off, putting the timing chain back on was a bit of a hassle. But, as long as you do it right there is no worries. Lastly, I left my transmission mounted in the car so getting the engine back in was a little annoying because you have to get the alignment of the engine right along with the clutch and the transmission teeth. It was time consuming, about 16 - 20 hours working slow with hand tools, but I'd give it a 4 out of 10 difficutly. |
09-23-2019, 10:15 PM | #79 |
Drives: brz
09-24-2019, 12:16 AM | #80 | |
EDIT* okay just had a chance to talk to him again. He says; Plastic manifold 17+ engines will bolt right up pnp but aluminum intake manual trans engines need to swap cam gears and trigger wheel. They send a completely different signal. Last edited by D-VO; 10-22-2019 at 02:48 PM. |
The Following User Says Thank You to D-VO For This Useful Post: | el-92 (10-18-2019) |
05-22-2020, 03:02 PM | #81 |
Drives: 2015 scion fr-s
Looking to do a swap from my 2015. Anybody have any info on compatibility with the 17+? I’m sure it’s less plug and play but what would I have to swap? What issues would I run in to?
07-30-2020, 08:21 AM | #82 | |
can't find it , only shops that sell the whole connector without any codes... i'm interested on the connector type...
08-06-2020, 12:39 PM | #83 |
You're supposed to be keeping the 2013 harness.
08-06-2020, 02:47 PM | #84 |
Drives: 2016 BRZ Limited
I recently installed a 2017 A/T engine (black manifold) into my 2016 a/t brz. I transferred every single sensor and the complete wiring harness from my 2016 engine, to my new 2017 engine. The car starts and runs okay for a minute but then gives me P0011 and P0021 CEL (timing over advanced) Do i need a different tune for the 2017 engine to run correctly?
Similar Threads | ||||
FS: 2013 FA20 engine w/spun bearing | Bullnettles | Engine, Exhaust, Bolt-Ons | 9 | 04-05-2017 06:39 PM |
FS: FA20 Engine | Sportsguy83 | Engine, Exhaust, Bolt-Ons | 12 | 03-01-2017 02:51 PM |
2017 engine vs 2013 engine | DailyDriver86 | Engine, Exhaust, Transmission | 17 | 11-09-2016 05:16 PM |
Looking to buy FA20 engine | ndreim | Want-To-Buy Requests | 0 | 12-15-2015 06:06 PM |
FA20 Engine Wins Ward's 10 Best Engines of 2013 | Jeffsu350 | Scion FR-S / Toyota 86 GT86 General Forum | 111 | 03-15-2015 03:39 AM |
