86WORX
Old 06-24-2017, 11:38 AM   #15
gtengr
Drives: 2017 BRZ
Originally Posted by nikitopo View Post
How is this related? These are internals. He should swap the complete engine.
The crank angle sensor changed to a different type. The older ecu wouldn't be able to interpret the different signal output. The mounting plate has been changed too. However, that doesn't necessarily mean the old sensor hardware doesn't bolt up.
gtengr is offline   Reply With Quote
The Following 2 Users Say Thank You to gtengr For This Useful Post:
Hades (11-11-2020), nikitopo (06-24-2017)
Old 06-24-2017, 11:44 AM   #16
gtengr
Drives: 2017 BRZ
Originally Posted by mrg666 View Post
Of course, the new engine is improved. But what are you going to get with the improved engine, +5hp? 400hp FI without any supporting mods? header+tune with more power? What is that you are talking about? Is it worth an engine swap? Justify the swap with data and win your argument.
I think it is being explored as a replacement if the stock 2013-2016 motor blows up and you don't want/need a built engine.
The Following User Says Thank You to gtengr For This Useful Post:
strat61caster (06-25-2017)
Old 06-24-2017, 11:50 AM   #17
Darkrune
Darkrune's Avatar
Drives: 2017 86
I have no argument. I am saying that you have no argument contralateral to swapping in the new engine, or FI on it, or any number of undiscovered items. The changes made to the engine are also a known variable. I imagine the changes were more for reliability that just happen to yield a 5 hp potential.
Darkrune is offline   Reply With Quote
Old 06-24-2017, 12:09 PM   #18
mrg666
pessimistic skeptic
mrg666's Avatar
Isn't potential incompatibilities and/or extra costs involved with swapping to '17 engine a "contralateral", as you used the word? I don't care what you imagine. I simply asked you to justify that decision with data. What are you going to gain with the swap?
The Following User Says Thank You to mrg666 For This Useful Post:
ILLSMOQ (10-20-2017)
Old 06-24-2017, 12:14 PM   #19
Darkrune
Darkrune's Avatar
Drives: 2017 86
And I am saying if the OP's motor lets go, what does he have to lose? He would get a newer engine with the latest angle cam adjustments etc. This whole thread is about an engine used for racing letting go.
edited for punctuation
P.S. You realize you can swap the harness too right?
The Following 2 Users Say Thank You to Darkrune For This Useful Post:
ILLSMOQ (10-20-2017), ROADRACER (11-07-2017)
Old 06-24-2017, 11:54 PM   #20
gtengr
Drives: 2017 BRZ
There's no answer at the moment. Very much a first person to try it sort of thing. Could be simple if you have a donor motor to take sensors from, or may be too expensive if you end up needing the ecu and harness too. The improved internals would be more durable and possibly incrementally lower oil temps.
Old 06-25-2017, 12:04 AM   #21
strat61caster
strat61caster's Avatar
The point isn't to swap for mo powah and building, it's a replacement engine, op is unlikely to majorly modify the engine so getting a newer design is a reasonable idea.
But given the other parts about sensors and connectors changing got the 15-16 it won't be plug and play and there will likely be more trouble shooting than with a 13-14 engine.
ineedyourdiddly
Old 10-20-2017, 09:36 PM   #22
ILLSMOQ
Drives: 2017 WR BLUE BRZ
Originally Posted by ROADRACER View Post
Has anyone done this? When my 2013 track car engine lets go it could be a good time to put in a donor 2017 engine if it is a direct bolt in replacement? The 2017 ecu/tune is supposed to be quite different, but it would be a good option if the 2013-16 systems would work fine with the newest version of the fa20.
I just did this. 2017 FA20 into a 2013 FRS. Is not a plug and play replacement...infact you have to do a lot of unplugging and swapping of parts to make it work. Basically the complete engine wire harness and the items listed below.
Crank reluctor wheel is different as well as the crank sensor and crank sensor mount which bolts in from behind the engine under the flywheel.
Pass side fuel rail is different and uses a different sensor
Coolant sensors are different
Ignition coils are different 2017 uses a 3 terminal connector 2013 uses a 2 terminal connector
ILLSMOQ is offline   Reply With Quote
The Following 28 Users Say Thank You to ILLSMOQ For This Useful Post:
alan.chalkley (10-23-2017), Alltezza (07-02-2018), Bonburner (10-25-2017), churchx (10-22-2017), Code Monkey (10-20-2017), Creole (06-30-2018), CSG Mike (10-20-2017), Darkrune (10-22-2017), endless_pain (10-24-2017), gravitylover (09-03-2020), gtengr (10-20-2017), Hades (11-11-2020), Joveen (09-01-2020), Kiske (05-09-2020), Muaddib (10-21-2017), new2subaru (10-21-2017), nikitopo (10-29-2017), ROADRACER (11-07-2017), sato (07-04-2018), Sleepless (04-10-2019), Sportsguy83 (10-23-2017), strat61caster (10-21-2017), T-Steve (11-12-2021), tCsonfrs (10-25-2017), Teseo (10-23-2017), Turdinator (10-22-2017), weederr33 (07-01-2018), whataboutbob (01-31-2023)
Old 10-22-2017, 06:03 PM   #23
Darkrune
Darkrune's Avatar
Drives: 2017 86
Was it worth swapping to the newer engine?
Sent from my SM-G935V using Tapatalk
Old 10-22-2017, 06:35 PM   #24
ILLSMOQ
It was for the owner of this car. He detonated his old engine...both crank case half’s had a few holes in them. Exhaust was full of coolant and metal chunks...did a real thorough job...pretty impressive actually
The Following 2 Users Say Thank You to ILLSMOQ For This Useful Post:
Bonburner (10-25-2017), Sportsguy83 (10-23-2017)
Old 10-23-2017, 04:13 AM   #25
VoltsFRS2013
VoltsFRS2013's Avatar
Drives: 2022' GR86 Premium 6MT
VoltsFRS2013 is offline   Reply With Quote
Old 10-23-2017, 07:28 AM   #26
Sportsguy83
I Love custom Turbo kits
Sportsguy83's Avatar
Drives: Limited BRZ
Originally Posted by Vracer111 View Post
Did a ZC swap on a CRX Si years back that was pretty straight forward...not bad at all going to the DOHC motor from the stock SOHC one, very minimal wiring changes...
I did a few honda motor swaps back in the day, Honda made it so simple to swap motors, harness, mounting points, connectors all were "swapable" between cars and/or with little modification. Those where the good days, with no CAN system in the car, just swap and go!
Old 10-29-2017, 02:48 AM   #27
TRAKRAVN
Drives: 2015 Scion FRS - Raven
Does anyone know how these differences compare to the 15-16 engine?
TRAKRAVN is offline   Reply With Quote
The Following User Says Thank You to TRAKRAVN For This Useful Post:
Trust86 (01-20-2018)
Old 03-20-2018, 05:34 PM   #28
pgranberg11
BoostedBRZ
Drives: Turbo BRZ
bump.. for what it's worth.. i had a similar experience with blowing a hole through my crankcase similar to above... I have a 2014 BRZ that was manufactured in 2013. I ended up going with a used 2015 moto and I ended up using the 2014 harness and the 2014 ECU since that ecu has my ecutek license flashed on it..... haven't started it up/tried turning it on; but all connectors/plugs plugged right in for whatever it's worth.
pgranberg11 is offline   Reply With Quote
FS: 2013 FA20 engine w/spun bearing Bullnettles Engine, Exhaust, Bolt-Ons 9 04-05-2017 07:39 PM
FS: FA20 Engine Sportsguy83 Engine, Exhaust, Bolt-Ons 12 03-01-2017 03:51 PM
2017 engine vs 2013 engine DailyDriver86 Engine, Exhaust, Transmission 17 11-09-2016 06:16 PM
Looking to buy FA20 engine ndreim Want-To-Buy Requests 0 12-15-2015 07:06 PM
FA20 Engine Wins Ward's 10 Best Engines of 2013 Jeffsu350 Scion FR-S / Toyota 86 GT86 General Forum 111 03-15-2015 04:39 AM
