86WORX
Old 06-22-2017, 11:18 AM   #15
Gforce
Drives: 2013 Subaru BRZ
Originally Posted by why? View Post
That is specifically why most cars are designed now with the idea that the fuel pump be totally submerged until there is very little gas left. The smart ones are designed so that the pump is still submerged when the fuel gauge is telling you it is totally empty.
You might be surprised at how hot that very small amount if fuel can get. Mind you, if the FI system is not a tank return system the fuel tank stays much cooler. Older designs were fuel tank return systems and those could heat the fuel tank fuel up to vapour lock temperatures on hot days if there was not much fuel left.
Refuel just when the low fuel light goes on is good advice.
PS, the fuel pump is only submerged in the fuel it picks up. They sit quite tall, vertically oriented. The fuel pick up is the only part of the fuel pump assembly that is fully submerged. The pump itself draws fuel into the housing around itself which is what cools the pump obviously, that heat accumulates faster if the tank is nearly empty.
Older designs used two pumps: the main pump which hardly ever failed siting in a small chamber that was primed filled and partially pressurized by a small pre pump unit that frequently failed. That pre pump was not always fully submerged draw your own conclusions.
Gforce is offline   Reply With Quote
Old 06-22-2017, 11:29 AM   #16
Sideways
BRZZZZZ
Sideways's Avatar
Drives: 2013 BRZ Whiteout
I have always refueled when my gas light comes on. Our 86 tanks are plastic and fuel pump is mostly plastic or zinc plated steel. And even then, I refuel the same day as the gas light comes on.
I guess it will be bad if you park your car for extended period of time with empty tank or driving in hot weather on empty tank to overheat the pump.
Sideways is offline   Reply With Quote
Old 06-22-2017, 11:53 AM   #17
ZDan
ZDan's Avatar
Drives: '23 BRZ
Originally Posted by Gforce View Post
This advice is correct. In tank fuel pumps are cooled by the fuel in the tank. Frequently running the tank very low can shorten the service life of the fuel pump, especially in hot climates.
As long as the pump is drawing fuel, it is being cooled. So don't run out of gas. But people already know that's a bad idea anyway.
Regarding contaminants and moisture, you're going to have those anyway, whether you run the tank to near-empty or not.
Me too. I had a pump failure on one of my cars and it is pretty inconvenient. Fuel pumps last the life of the car if you don't abuse them.
Running the tank to indicated "empty" (and beyond by some amount) generally does not constitute "abuse". Repeatedly running out of gas would, but nobody wants to do that anyway.
Or when it gets to "E", or whenever you feel like it as long as you don't run out of gas.
People don't need to read an unnecessary alarmist article to know they need to put gas in the tank before they run out...
The Following 4 Users Say Thank You to ZDan For This Useful Post:
Cole (06-22-2017), new2subaru (06-22-2017), Tcoat (06-22-2017), Ultramaroon (06-22-2017)
Old 06-22-2017, 12:11 PM   #18
Any solid contaminants tend to accumulate in the low point of the tank, the fuel pump tends to draw from the low point. For those who think fuel is always free of contaminants ask yourself why all cars fit a fuel filter. Contaminants all pass through the pump on their way to the filter.
Water contaminatation is unavoidable. Fuel floats so guess where the water is. Gasoline contains water absorbing additives, most gas in Canada has lots of ethanol which dissolves water nicely. Shell V power 91 does not have ethanol but does have a water absorber. Water contamination is now rare, but, I still pop a bottle of gas line antifreeze into my cars once or twice a winter. Good preventative maintenance. Isopropyl alcohol versions are more expensive but twice as effective. Most water in fuel is condensation. Obviously the less fuel there is in your tank the more humid air there can be. The less often you refuel the more water there will be in your fuel. Condensation rates are affected by how many temperature cycles the same air volume goes through and how much air is there. In winter in Canada condensation in your fuel tank can be significant, ditto underground tanks although the temperature doesn't vary much at the depth of the storage tanks.
Always buy gas from a reputable retailer.
Ethanol "dissolves" water? Really?
This shit is hilarious in the sheer repetition misconceptions and quasi science.
Cole (06-22-2017), KL (06-23-2017), why? (06-22-2017)
Old 06-22-2017, 12:12 PM   #19
Here is the reality of this! ^^^^ Low gas means nothing. Empty means possible issues.
why? (06-22-2017)
Old 06-22-2017, 12:17 PM   #20
StraightOuttaCanadaEh
Wes
I think he meant to say miscible.
The Following User Says Thank You to StraightOuttaCanadaEh For This Useful Post:
KL (06-23-2017)
Old 06-22-2017, 12:20 PM   #21
And this is reality as well ^^^
I bought a barn find Karmann Ghia that sat with and empty tank for 15 years. Anybody want to guess how much rust or moisture was in the tank?
Nothing!!!!!
How people think that there is enough air movement in and out of a tank to keep building up new moisture is beyond me.
Take a 5 gallon pail.
Cut a small hole in the lid.
Place it outside and let it sit through heat cycles.
See how much water builds up from condensation.
It will probably not even be detectable.
We have huge half full tanks of oil at work that are tested weekly for water. The total found over the course of a year is about 2 quarts. Any amount of condensation in a car fuel tank will be so low it may as well not exist.
DarkSunrise (06-22-2017), Ultramaroon (06-22-2017)
Old 06-22-2017, 01:26 PM   #22
Scrappydoo
Scrappydoo's Avatar
Drives: Grrrr
It's not an acorn it's an old chestnut.
Scrappydoo is offline   Reply With Quote
Old 06-22-2017, 02:23 PM   #23
Azzudien
Drives: 2017 Series Yellow BRZ
So let me see if I can sum up this entire thread:
Run out of gas is bad
Azzudien is offline   Reply With Quote
The Following 3 Users Say Thank You to Azzudien For This Useful Post:
Dadhawk (06-22-2017), sato (06-22-2017), Tcoat (06-22-2017)
Old 06-22-2017, 03:41 PM   #24
And running low on gas is not the same as being out of gas.
Old 06-22-2017, 04:03 PM   #25
1st86 Driver!
Yep. Here is our fuel pump. You would have to keep your tank well over half full to keep the pump submerged, never mind it's wrapped in plastic and not directly in contact with the fuel. It's the fuel running through the pump that cools/lubricates, not the fuel around it. I suspect the pump would work fine completely outside the tank.
The Following 7 Users Say Thank You to Dadhawk For This Useful Post:
Azzudien (06-23-2017), DarkSunrise (06-22-2017), lantsalot (06-22-2017), roddy (06-22-2017), Tcoat (06-22-2017), Ultramaroon (06-22-2017), why? (06-22-2017)
Old 06-22-2017, 04:27 PM   #26
Not according to some!
Dadhawk (06-22-2017), roddy (06-22-2017), Ultramaroon (06-22-2017), why? (06-22-2017)
Old 06-22-2017, 04:55 PM   #27
Yoshoobaroo
TRACKBREAD
Yoshoobaroo's Avatar
That's the fuel pump inside its surge tank. That 'bucket' is designed to stay full of fuel even when the tank is very very low, to ensure cooling.
The Following User Says Thank You to Yoshoobaroo For This Useful Post:
Old 06-22-2017, 05:18 PM   #28
ZDan
ZDan's Avatar
Drives: '23 BRZ
If this ensures that the fuel pump is cooled "even when the tank is very very low", why again should people worry?
B.S. story is B.S. Sure, it's not a good idea to run completely out of fuel, but people already have incentive not to do that!
The Following 2 Users Say Thank You to ZDan For This Useful Post:
Dadhawk (06-22-2017), Tcoat (06-22-2017)
found water where I shouldn't ed8756 Engine, Exhaust, Transmission 14 09-19-2014 11:06 PM
From OPPO: Why you shouldn't modify your car for the track. rice_classic Tracking / Autocross / HPDE / Drifting 28 03-03-2014 10:42 AM
Maybe I just shouldn't own this car execoll BRZ First-Gen (2012+) -- General Topics 26 12-06-2013 07:08 PM
Am i the only one who thinks carbon fiber shouldn't be in interiors? dem00n Other Vehicles & General Automotive Discussions 40 01-28-2013 08:02 PM
shouldn't have called.. shiud Scion FR-S / Toyota 86 GT86 General Forum 26 07-06-2012 11:02 PM
