#113 |
Drives: 2013 Subaru BRZ
| The Following User Says Thank You to Gforce For This Useful Post: | driftartist (06-05-2017) |
#114 | |
I say again, I do not have to prove anything. It is a public service to clarify and correct any bs posted to this forum. If you say I am not doing so I await your clarification and correction by explaining how fitting a space saver or other different sized tire to a Torsen diff can do any damage to it whatsoever. Until then, I simply ignore your appeal to authority, which as you may know is a logical fallacy. Can you identify the error in my post and explain why it is wrong? I thought not. |
#115 | |
#116 |
Calling on all differential experts.
@Gforce @Tcoat @Ultramaroon I'm in the process of assembling a new tricycle/stroller combo for my 11 month old granddaughter. My question is ...... what type of differential does it have ..... open, LSD, Torsen or other ....... ?? The reason I ask is that I want to know, when she puts power to the drive axle, can she go around our deck only one direction or should I encourage her to change directions half of the time ......?? TIA pa-pa humfrz |
| The Following 2 Users Say Thank You to humfrz For This Useful Post: | Ultramaroon (06-04-2017), WRBrzRX (06-04-2017) |
#117 | |
#118 | |
#119 | |
| The Following User Says Thank You to Tcoat For This Useful Post: | humfrz (06-04-2017) |
#120 |
fabulous
Drift trike.
| The Following User Says Thank You to Ultramaroon For This Useful Post: | humfrz (06-04-2017) |
#121 |
fabulous
I think I see your point. I have some more studying to do. Wish I had one to disassemble.
#122 | |
Connection issues
Drives: '15 ultramarine
| The Following 2 Users Say Thank You to Sapphireho For This Useful Post: | humfrz (06-04-2017), Ultramaroon (06-04-2017) |
#123 |
OK, Folks ....... the "beast" is built. The engine is at the tuners getting rested and charged up. The big race will start at 0730 Monday morning.
Note the racetrack has a nice straight away, a 90 degree curve is behind me to my left with more straight away. As you can see in the close up, this machine has several noteworthy features: * its a roadster, with a soft top (which also acts as a roll bar) * the front (drive) axle can be locked or unlocked ..... blocking power from the engine (freewheeling .... eg Georgia overdrive) * the rack & pinion steering can be done by the driver or co-pilot * the seat is made by Recaro and has a 5 point hitch * dash mounted tray for a bottle and snacks * handy tray for co-pilot's water, snacks, cell phone * ample trunk space for spare diapers, burp clothes, and general clean up materials in case of a blow out from either end * duel, positive lock rear axle (parking brakes or for drifting) * HD skid plate for off road protection * the co-pilot's handle and other parts can be easily removed for it to convert to trike mode time for pa-pa's nap ...... I've had a busy morning .....
| The Following 3 Users Say Thank You to humfrz For This Useful Post: |
#124 |
Connection issues
#125 | |
Drives: Grrrr
Why are you assembling it on a cooker hob? |
#126 |
The first of those on the market was the Big Wheel I believe. The Classic trike of trike suffers from terminal oversteer, or more usually terminal overturning moment. The Big Wheel eliminated the overturning moment (unless the fat kid town the block stole your trike) and released the terrifying drift mode.
| The Following User Says Thank You to Gforce For This Useful Post: | Ultramaroon (06-04-2017) |
| loose rear-seat latches | hyperpunx | Issues | Warranty | Recalls / TSB | 34 | 02-22-2017 06:19 PM |
| what bushing should i get for better handling | nearvincent | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 5 | 10-15-2014 05:26 PM |
| Outside Rear View Mirror Housing Loose | tonytduc | Issues | Warranty | Recalls / TSB | 3 | 10-01-2014 04:20 PM |
| Help! Trd rear bumper loose :( | FaNtaSy | Cosmetic Modification (Interior/Exterior/Lighting) | 1 | 10-25-2013 09:01 AM |
| Best handling car? | gt8613 | FR-S / BRZ vs.... | 154 | 10-07-2013 10:57 PM |
