#99 | |
Still a pretty good record since we didn't start talking about blue dinasours or something.
| The Following 2 Users Say Thank You to Tcoat For This Useful Post: | Cole (06-03-2017), Ultramaroon (06-03-2017) |
#100 |
fabulous
How many times do I have to say it? They weren't blue. They had a bluish hue.
| The Following User Says Thank You to Ultramaroon For This Useful Post: | Tcoat (06-03-2017) |
#101 |
Well only Hum would know for sure.
| The Following 3 Users Say Thank You to Tcoat For This Useful Post: |
#102 |
Well, the one that I do remember had a blueish streak on it .....
![]() humfrz |
#103 |
Must have been a special edition.
| The Following User Says Thank You to Tcoat For This Useful Post: | humfrz (06-03-2017) |
#104 | |
Drives: 2013 Subaru BRZ
Have you figured out how different the rolling circumference of the tires would have to be to cause a problem in the manner you describe? Even if the space saver were to be that small (and it would have to be very small) the Torsen or any patent infringement avoiding variation of the Torsen would not wear any more than an open differential would in the same situation. That is to say, the supposed "limited slip" function you suppose would generate heat just wouldn't and reveals a lack of understanding about how Torsen type diffs work. They generate less heat when they are transferring torque than they would just differentiating. They are not relative wheel speed activated. Genius design actually. Bombproof enough for a Hummer. Differentials are stronger than the axles they drive. You only find differential oil coolers on competition cars. Your theory is well expressed, and courteous, but isn't correct. Anybody else care to take a crack at it? Most of the posts since my challenge are sufficiently infantile as to warrant ignorance, consistent with that displayed. |
#105 | |||
| The Following User Says Thank You to Tcoat For This Useful Post: | WRBrzRX (06-03-2017) |
#106 |
Since you are also wrong no surprises there.
The description is accurate until it gets into limits on wheel speeds. Torsen type diffs are not speed sensitive nor are they speed actuated. From a differentiation perspective a Torsen is a completely open diff. Going straight down the road or through the sharpest bend there is no limit to the differentiation a Torsen can accomodate. The "gear ratio" concept is half right. The limit on torque bias, the bias ratio, is imposed by the angle of the gear teeth on the helical planetary gear. Obviously, this is a fixed limit both as to a specific application and in an absolute sense. Torsen work by axial thrust on the helical planetary gear. The gear is pushed endways into a specially machined "pocket" or in some types against a specially designed thrust washer, usually hardened steel. Interesting is the fact that the thrust reverses on overrun allowing for the possibility of a different bias ratio under braking. ABS overrides Torsen effects most if the time but without ABS Torsen can improve braking performance also. The key to understanding why wheel size makes no difference is to understand that the torque bias requires different thrust on the left and right axle shafts. Wheel speed has no effect on this. It is also easy to see that the friction is largely static friction anyway if full torque bias is engaged. Torsen in theory would run cooler when torque biasing than when differentiating. The one exception is a pre loaded Torsen such as the T2R type or some Quaife types. They have a spring loaded thrust washer which provides slightly more than zero torque resistance. Last edited by Gforce; 06-03-2017 at 12:39 PM. |
#107 | |
#108 |
For the record this thread first described the problem accurately in post #15, new tires of different and inferior spec put on the rear axle which is a no no. I answered that question correctly in post #29. Immediately challenged incorrectly by one of the less knowledgable posters to this forum, admittedly in a crowded field of contenders. Any doubt about that issue was neatly resolved by the poster himself in post #33, possibly in a misguided attempt at sarcasm so inadvertent in that respect. Accurate nonetheless.
By post #18 the topic had already veered off into a discussion about use of the deadly space saver spare. I have done my best to correct the ignorance displayed by many on this thread as a public service. I acknowledge there are none so blind as those who will not see. Even the "cannot sees" can be forgiven for not understanding. |
#109 | |
fabulous
Do we agree that when the outputs are being driven equally (no differentiation) that a component of the input thrust vector places an axial load on the worm gears? I think yes. This is where the friction comes into play. Under load, at the onset of differentiation, those gear teeth do rub relative to each other. They are not involutes. (edit: They do have that component in their shape but they are somewhere in between worm and spur in operating principle.) It is that very same friction on which the torsen relies. The only time a torsen truly behaves like an open diff is when there is zero torque applied to the input. Without any statement to consequence of continuous operation, do we agree on these points academically?
#110 | |
#111 | |
Kurenai Samurai
Drives: Red and manual
| The Following User Says Thank You to driftartist For This Useful Post: | WRBrzRX (06-03-2017) |
#112 | |
Torque biasing differentials are engineered to differentiate exactly as open bevel gear differentials do. They are not speed sensitive, they react only to torque. They bias torque by exploiting the internal frictional forces generated by helical worm gearsets and, more importantly, the frictional forces generated by the ends of (or faces of the side gears in the case of T1 and the new split gear types) the worm gears when they engage the diff case. Torsen bias torque delivered at the crown and pinion, transferred through the "carrier" which is the Torsen part. They can only bias torque by reacting to uneven torque resistance at the output shafts. Furthermore, unlike an LSD they cannot limit slip to the output shaft experiencing the lesser reaction torque. Understanding why that is so allows one to understand how a Torsen works, that it isn't really an LSD and why using a space saver or other tire of even significantly different rolling circumference cannot wear the torque biasing components of the Torsen. Despite what the lawyers who write owner's manuals might say. There are some good reasons not to run different sized tires on the drive axles of a car but differential wear isn't one of them. |
| loose rear-seat latches | hyperpunx | Issues | Warranty | Recalls / TSB | 34 | 02-22-2017 06:19 PM |
| what bushing should i get for better handling | nearvincent | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 5 | 10-15-2014 05:26 PM |
| Outside Rear View Mirror Housing Loose | tonytduc | Issues | Warranty | Recalls / TSB | 3 | 10-01-2014 04:20 PM |
| Help! Trd rear bumper loose :( | FaNtaSy | Cosmetic Modification (Interior/Exterior/Lighting) | 1 | 10-25-2013 09:01 AM |
| Best handling car? | gt8613 | FR-S / BRZ vs.... | 154 | 10-07-2013 10:57 PM |
