Go Back   Toyota GR86, 86, FR-S and Subaru BRZ Forum & Owners Community - FT86CLUB > 1st Gens: Scion FR-S / Toyota 86 / Subaru BRZ > BRZ First-Gen (2012+) -- General Topics
BRZ First-Gen (2012+) -- General Topics All discussions about the first-gen Subaru BRZ coupe
Old 05-26-2017, 09:32 PM   #29
tony-brz
tony-brz's Avatar
Drives: '17 BRZ PP
Originally Posted by phiflyhigh View Post
If you listen right when the car hits 47mph and onward, the noise is there and constant through the shifts. Like a rattle, I don't know how else to explain it but it goes from rattle noise to a blade/cutting noise *sigh.
Are you sure it's not just a rattle in the interior? Harmonization is a thing. I have a 2017 too, at certain frequencies and on some road surfaces I hear a rattle in my interior similar to what I heard in your video.
My 2017 is at about 4500 miles.. and has seen 2 track days .
I think you're overreacting, unless the audio reproduction is just shit in your video.
BTW : i listened to your video with audiophile level headphones.
tony-brz is offline   Reply With Quote
The Following User Says Thank You to tony-brz For This Useful Post:
spike021 (05-26-2017)
Old 05-26-2017, 09:59 PM   #30
phiflyhigh
phiflyhigh's Avatar
Drives: 2017 Subaru BRZ
I'll try taking everything out of my car, and running a test drive to make sure I'm not crazy since no one here seems to think I have a car issue ><
phiflyhigh is offline   Reply With Quote
Old 05-26-2017, 10:03 PM   #31
tony-brz
tony-brz's Avatar
Drives: '17 BRZ PP
Dude, it's brand new, if our suggestions really aren't aligning with your opinion it's time to take it to the dealer.
BRZdart17 (05-26-2017)
Old 05-26-2017, 10:21 PM   #32
phiflyhigh
phiflyhigh's Avatar
yeah, i think i'm going to end up taking it to the dealer, get an oil change again, if it don't fix the problem, i'm going to have to tell a tech to ride with me to see if I'm just tripping. Thanks though for your guys help, and hopefully I'm just going crazy.
The Following 2 Users Say Thank You to phiflyhigh For This Useful Post:
BRZdart17 (05-26-2017), tony-brz (05-26-2017)
Old 05-26-2017, 11:49 PM   #33
Try this:
Open glove box
Locate plug in 12 volt socket
Remove plug
Lift carpet at front of passenger foot well
Find round tube sticking up
Push plug into tube
Test drive
Not joking. That sound tube makes the weirdest noise and it is probably even more annoying with the bigger intake in the 17s.
D_Thissen (05-27-2017)
Old 05-27-2017, 05:01 AM   #34
Esseff
Drives: 2017 BRZ Ltd White
"MAJOR PROBLEM WITH MY NEW 2017 BRZ!!!! HELP!"
I've told u a MILLION times, not to exaggerate!
Esseff is offline   Reply With Quote
The Following User Says Thank You to Esseff For This Useful Post:
Tcoat (05-27-2017)
Old 05-27-2017, 05:21 AM   #35
AND STOP YELLING AT US.
HachiRokuX (05-29-2017)
Old 05-27-2017, 06:48 AM   #36
nikitopo
nikitopo's Avatar
Drives: '15 BRZ RA
I did, it looks like it is above the 2 dots and not in the middle but my question is, how does having too much oil make the engine/motor sound like its grinding? I'm just trying to learn so this mistake doesn't happen again.
The oil level should not be in the middle of the 2 dots.
Well, I have very sensitive and fine tuned ears to hear the buzzing/grinding noise that doesn't sound normal to me, and I do see it as a problem because I have owned a 2013 Scion FRS and it never made that kind of buzzing/grinding noise PERIOD. I've put over 50,000 miles on her before moving onto this BRZ. I think I will take it to the dealership so they can check it out. Was just hoping someone on here can see what I'm talking about and help me out instead of criticizing how I drive : /
I don't think you had a FRS before that was driven 50k miles. You don't even know what is the normal oil level! If you want to get some help from here, what is the purpose of lying?
Check it with your dealer, because we cannot hear anything weird in your video. And you don't need to change your oil again!!! Read the car's manual, listen your dealer and follow the suggested service intervals from the factory.
Old 05-27-2017, 10:31 AM   #37
PandaSPUR
PandaPandaPandaPandaPanda
PandaSPUR's Avatar
Drives: 2015 BRZ Limited CWP
Grip the reverse lockout when you pass through those RPMs. Does the rattle disappear?
If it does, theres your problem, go buy the Perrin reverse lockout or any other lockout with an o-ring in it to dampen vibrations.
PandaSPUR is offline   Reply With Quote
Old 05-27-2017, 10:39 AM   #38
Gforce
Drives: 2013 Subaru BRZ
Originally Posted by Boomerang View Post
Check your oil level as you may have too much
This is very good advice. Checking oil levels on these boxer engines is a frustrating exercise in guesswork even for mechanics.
Otherwise, I do not hear any untoward noises in the video.
And 6,000 rpm is too high for an engine with only 1,000 miles on it.
And changing the oil at only 1,000 miles was not a good idea.
These engines benefit from leaving the build oil in the crankcase for as long as Subaru says, which I believe is 5,000 miles before the first change.
Gforce is offline   Reply With Quote
The Following User Says Thank You to Gforce For This Useful Post:
BRZdart17 (05-27-2017)
Old 05-27-2017, 11:15 AM   #39
extrashaky
Drives: 2014 BRZ Limited
I don't hear anything unusual in that video. My 2014 made all sorts of noises and rattles during the first few thousand miles. Most of them went away as the parts settled in.
Personally, I wouldn't even take it in for service. I would drive it a while longer to see if the noise got worse or went away on its own.
Old 05-27-2017, 12:31 PM   #40
SuperTom
SuperTom's Avatar
Drives: C5 Corvette, '17 Toyota 86, Jeep XJ
What?????
SuperTom is offline   Reply With Quote
Old 05-27-2017, 12:46 PM   #41
StraightOuttaCanadaEh
Wes
Originally Posted by SuperTom View Post
What?????
That means there's half a litre missing. It should be at the second dot
Old 05-27-2017, 01:08 PM   #42
phiflyhigh
phiflyhigh's Avatar
I just got a oil change at the dealership earlier today but the whirring/grinding noise was coming from inside the left air vents. I'm going to drive it on the highway later today and will hope it won't make the noise again. I'll post a new video if the camera in the inner vents so maybe you guys can hear it better.
2017 CHRYSLER PACIFICA MINIVAN VS 2017 TOYOTA 86 WHO WINS IN A DRAG RACE??? Extreme Dimensions Off-Topic Lounge [WARNING: NO POLITICS] 6 06-08-2017 09:59 AM
Major service Fletchlives78 AUSTRALIA 18 03-08-2017 06:22 AM
Boost Festival 2017: Feb 25, 2017 Willow Springs GTA, JustDrift, Drift ModinJapan Southern California 1 01-25-2017 01:46 AM
Known Major Issues I should know about.... Darkone BRZ First-Gen (2012+) -- General Topics 41 01-04-2017 10:51 PM
Major Mods.. Jaden Scion FR-S / Toyota 86 GT86 General Forum 72 08-28-2015 11:16 PM
