#757 | ||
Drives: '13 BRZ, '06 997, Other Things(TM)
The powerplant is completely unmodified, the car has never thrown a CEL before or since. In fairness, I was driving absolutely flat out with only momentary lifts of the throttle to turn into corners for at least 20-30 minutes before the light came on. I'm guessing most tracks aren't that hard on cars. Quote:
#758 | |
The Fail Boat
Drives: CWP S.B.
Did you drive with windows down & see if you can spot any different in the noise the engine makes? There is this one time at GMR that I actually notice it sounding different when i rev it "after keep it near the top for like the entire way up & down the gmr for like 25 min ish?" Pull my car to the side of road and let it idle for like 5 -10 mins & it went back to sounding normal.......then i drove off the mountain and had protein style in & out burger cuz it was scary.
#759 | |
Unfortunately I don't think I was the only thing that was warmed up :P I didn't notice any difference in noise. The car seemed to run completely normally (except for the engine feeling weak-- but as I said, it was probably the altitude and temperature: there was no sudden / noticeable change in engine performance associated with the CEL). It did shake my confidence in the car a bit. Part of the reason I bought my 997 was so that I could have something I could drive flat out without turning it into an aftermarket science project. I'll do suspension mods all day long, but I didn't want to mess with the engine on the BRZ back in '15 when I still had a lot of warranty left. These days I'm inclined to stick a supercharger, oil cooler, and some means of monitoring T's and P's on the car. I heard the Jackson Racing supercharger kit has a bit of boost push when you lift off the throttle though, which I'm not wild about. I'm also of two minds as to whether adding power to the car is a good idea at all: it's slow on hills and doesn't have the torque to do big filthy powerslides all the time, but being able to drive it flat-footed all over the place has its charms. |
#760 | |
Drives: '15 BRZ RA
If you 're considering doing a power upgrade to your BRZ, I would suggest to do it right and do it once. You'll need to open the engine and change the internals with forged ones and reduce the compression rate. Then you can install a supercharger. Another option is to try the 2.3 stroker kit from Toda and stay NA. You'll have all the advantages of NA and more torque. Check if these guys can provide an offer: info@todaracingusa.com |
| The Following User Says Thank You to nikitopo For This Useful Post: | Ganthrithor (09-27-2017) |
#761 | |
But it did mean that I could drive as fast as I cared to. Usually if I'm out with other people I drive a relaxed pace because they're not as familiar with the road.I don't think I'm going to do any significant engine work to the BRZ. I'll probably just keep it on tiny tyres to keep it slippery and continue saving pennies for a 997 GT3. I do think that the BRZ with a little flat six from a Cayman or something would be absolute perfection... ~300 hp, a bit more torque, and beautiful sounds. I'm kind of surprised nobody's done it given the number of weird and wonderful engine swap projects people have done on this platform. Maybe Sharkwerks could build me a GT3 engine with smaller bores and a way shorter stroke so I could end up with significantly less horsepower and a 10k rpm redline. That would be fun in a BRZ :P |
#762 | |||
Drives: '12 C63 P31, '17 GTI Sport, '00 MR2
Current: 2023 GRC Circuit Edition, 2012 C63 AMG P31
Past: (2) 2000 MR2 Spyder, 2017 GTI Sport, 2006 Porsche Cayman S, Supercharged 2013 BRZ-L, 2007 Honda S2000, 1992 Integra GS-R |
| The Following User Says Thank You to WolfpackS2k For This Useful Post: | Ganthrithor (09-28-2017) |
#763 | |
If I were to just read the complaints about the Twins on here and take every word written as the gospel truth ("I have NEVER over revved and have no clue why the car threw a rod") there is not a hope in hell I would have bought one since it appears there are nothing but problems with most of them. Very far from the reality and the same applies to Porsche.
| The Following User Says Thank You to Tcoat For This Useful Post: | Ganthrithor (09-28-2017) |
#764 | |
Old Guy
Drives: 16 STi, 22 MX-5 RF BBS, 04 OBS RPA
Fast cars, like Porsche, are nice. But, even a free car, like a Porsche, that only requires general maintenance will still cost more to run than a car with less expensive consumables. |
#765 | |
#766 | |
Old Guy
I own a c5z06. Parts are relatively inexpensive ($80 for oem rotors per, ~$50-60 per pad, tires are about $300 each), and I make a modest engineering salary. However, once I personally had experienced the faster car, I would go back to my roots of slower cars that are just less expensive to maintain. For me, there is less to worry about and more driving. For me, being able to drive to the limits of the car does mean something. Better basic engineering and parts are important to me... but not at the cost of being able to drive the car as I would want. Also, the logistics of replacement car cost, insurance, property insurance and other "secondary costs" have to be considered. To bring it all back around, I am considering a tS (even though the autoXer in my knows a base car modified is the same and cheaper) instead of "faster" cars. It depends on intent and goals. Keeping up isn't always the best thing. Getting behind the wheel and seeing what is fun is important. The checkbook and ease of doing it should always be considered. |
| The Following 3 Users Say Thank You to dowroa For This Useful Post: |
#767 | |
| The Following 2 Users Say Thank You to WolfpackS2k For This Useful Post: | Ganthrithor (09-28-2017), Tcoat (09-28-2017) |
#768 | |
Drives: '15 BRZ RA
. Most people don't have the necessary knowledge and/or the tools ...
| The Following User Says Thank You to nikitopo For This Useful Post: | Ganthrithor (09-28-2017) |
#769 | |
Not a massive difference considering it's a job that only needs to be done every couple of years. Cars are going to be a relatively expensive hobby regardless of the make and model, especially when you don't do the work yourself. |
| The Following 2 Users Say Thank You to funwheeldrive For This Useful Post: | dowroa (09-30-2017), Ganthrithor (09-28-2017) |
#770 | ||
11 qts Total Quartz 9000: $110 Filter + gasket: $30 Drain plug: $30 Drain container: $16 Hex bit for plug removal: $4 Oil filter housing tool: $6 ========= Total: $196 Obviously most of these are one-time expenses and I could get a cheaper oil next time. I could probably also save some money buying stuff off the internet instead of from my local shop, but I like the guys at my local shop ![]() Quote:
IDK. A $40k factory BRZ just doesn't make a lot of sense to me. Not without a completely different engine, anyway. Last edited by Ganthrithor; 09-28-2017 at 06:39 PM. |
| The Following 5 Users Say Thank You to Ganthrithor For This Useful Post: | daiheadjai (09-28-2017), dowroa (09-30-2017), funwheeldrive (09-28-2017), Pat (09-28-2017), Tcoat (09-28-2017) |
| Testing Waters: Stivo Wing in asphalt gray | DarkCard | Exterior Parts (Aero, Lighting, Etc.) | 3 | 10-08-2013 01:49 PM |
| Subaru BRZ STI Spied Testing on Nurburgring! | Hachiroku | BRZ First-Gen (2012+) -- General Topics | 162 | 07-05-2013 01:28 AM |
| Subaru's FT-86 STI Coupe Spied Testing In Southwest! | Hachiroku | Scion FR-S / Toyota 86 GT86 General Forum | 68 | 09-23-2010 01:53 AM |
