FS: 10:1 Ptuning Built Motor, MAKES NOISE, VIDEO!!!
Looking to see if there is any interested and what offers I can get for a built motor that is making noise. Not 100% sure on what the issue is. Listen to video (keep in mind that is a cold start inside a concrete garage).
It was build by Ptunning in December 2014 and had their Turbo Kit on it. Had wideband, failsafe, injector kit, etc and was tuned by Ptuning to 420HP. 3 thousand miles later in August of 2016, during a 4th gear highway pull, the noise appeared and the car was trailered home immediately. I purchased the car as is last year. Started it up once and recorded a video. It was not smoking and I did not see any metal shavings or coolant in the oil. I have different plans for the car so the motor is for sale. I have all the receipts from Ptuning build. Here are some details: #SC7405CP Pistons, 0.5mm overbore, 10:1 compression, 86mm. Biran Cower I-Beam Rods. Cleaned block Square decked 2 sides Honed Block Re-grind rods journal 25mm Straightened crank Balanced Set Clearance OME Rod bearings OEM Main bearings ARP Head stud kit AP case bolts set OEM Bearing set-connecting rods OEM Engine Timing Cover OEM engine gasket kit set Disassemble cylinder heads Check cylinder heads Cleaned cylinder heads. Decked cylinder heads. PM me or text me with offers or if you want more info (612)229-1797. Thanks, Stan. *****VIDEO***** *************** ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() [IMG]http://i531.photobucket.com/albums/dd360/figak/IMG_9831_zps2mq8v***.jpg[/IMG] Last edited by FRSH86; 05-25-2017 at 03:27 PM. Reason: video |
Moderators, I totally forgot. I will get a photo with the date and my username today.
Thanks. |
Drives: 2014 BRZ Limited
Sounds like a spun bearing; were you turning in the highway during the pull? I can't imagine losing oil pressure in a straight line... What kind of oil pan were you using?
This is what I got from the previous owner, so I don't know for sure. I bought the car like this. No oil light was on. Stock oil pan.
#5 | |
Site Moderator
Drives: ichi 86 Project
Please follow the Member Classified Rules (#2) or I'll delete the thread.
ichi |
Sign added. Thanks.
| The Following User Says Thank You to FRSH86 For This Useful Post: | ichitaka05 (05-25-2017) |
No one is interested?
BUMP
#10 |
Drives: frs
Dibs on turbo
#11 |
#12 |
#13 |
Drives: WSP FRS, S13 240sx
Bid: $700 shipped.
#14 |
Thanks for the offers! But I'll have to decline.
| Full blown turbo kit on built motor e85 VIDEO 3rd 4th gear pull | Anthony7515 | Off-Topic Lounge [WARNING: NO POLITICS] | 3 | 03-31-2017 01:47 AM |
| Full blown turbo kit on built motor e85 VIDEO 3rd 4th gear pull | Anthony7515 | BRZ First-Gen (2012+) -- General Topics | 0 | 03-31-2017 12:30 AM |
| Full blown turbo kit on built motor e85 VIDEO | Anthony7515 | Forced Induction | 0 | 03-31-2017 12:27 AM |
| PTUNING: 501WHP 377WTQ 20psi Stock Motor PTUNING Spec-SS GTX3076R Turbo System | ptuning | Forced Induction | 47 | 06-16-2014 04:52 PM |
| FT-86 makes UK debut at Goodwood Moving Motor Show | Hachiroku | FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum | 28 | 07-09-2010 03:57 PM |
