#43 | |
Drives: 2022 GR86
Here is a close-up of one of my lug nuts: ![]() It appears that at some point closer to the wider part of the conical seat in the wheel the OEM lug nuts are a bit too wide, so they started chipping (or is it the finish that's chipping?). Also, probably the hex part of the lug nut doesn't extend much, and you can easily damage the finish of the wheel with the socket. I see similar issues around other lug nuts, although not quite as bad. Seems like spline-style lugs is the way to go. It's disappointing that the shop I went to didn't catch that, despite me specifically asking them if my lug nuts are ok for these wheels. Also, I didn't get a good advice on that when I reached out to Titan 7 directly weeks prior to installation. |
#44 |
Drives: Supra, Viper, Z06, GT350 and GX460
I see.. Titan suggested I use aftermarket lugs as well.
IG: @vipraz 94 Supra Turbo // 15 Viper GT // 16 Corvette Z06 // 18 Shelby GT350 // 19 BRZ LTD // 18 GX460 Premium // 13 Vrod Muscle
#45 |
Drives: 2022 GR86
Just installed Muteki 41885C Chrome 12mm x 1.25mm Closed End Spline Drive Lug Nuts - these look and sit much better!
On the photo with the stock lug nut you can see scratches from the socket -- I presume the lug nug was sitting so deep that the socket could only cover half of the length of the hex section. Yuck! ![]()
| The Following 2 Users Say Thank You to timurrrr For This Useful Post: | Clipdat (08-13-2022), soundman98 (10-19-2019) |
#46 |
Here is my car with T-S5 wheels...
#47 |
Drives: 2022 GR86
Another data point:
I've put my 17x9 T-S5s with new 245/40R17 GT Radial SX2 and OEM TPMS sensors on my bathroom scales and measured 43.8 lbs. For comparison the OEM PP wheels with medium-worn Michelin Primacy HP (stock) tires and no TPMS on the same scaled and measured 39.6 lbs. So looks like at the end of the day a combo of 17x9 with 245/40 is still heavier than OEM PP wheels + OEM tires. |
#48 | |
![]() Sent from my GM1915 using Tapatalk
2013 Series 10 FRS #553
| The Following User Says Thank You to jflogerzi For This Useful Post: | Clipdat (08-13-2022) |
#49 |
Drives: 2017 BRZ w/pp
The car looks great. I'm interested in the setup. I have the 2017 BRZ w/pp and the CSG Flex A coilovers. I'm currently running -2.5 chamber in front and -2.0 rear with the recommended height? About 1.3 lower than stock. Do you think the wheel and tire setup will fit?
Sent from my Pixel 2 XL using Tapatalk |
#50 | |
Drives: 2022 GR86
![]() FTR, I recently went to a Car Control Clinic and noticed that when my car spins out of a drift the front tire does rub against the fender a bit, even though I'm maxed out on front camber. You may want to keep that in mind wrt your lower ride height. Note that I've dropped 3 turns of the front coilovers (6mm?) since the last time I took photos, so I was at ~31mm drop from factory at that CCC. |
#51 | |
#52 |
Drives: 2022 GR86
Absolutely love these wheels!
Now that they're track-proven, I've decided to share some more photos: ![]() ![]() ![]() ![]() ![]()
| The Following 3 Users Say Thank You to timurrrr For This Useful Post: |
#53 | |
Drives: 2018 Subaru BRZ Limited with PP
#54 | |
Drives: 2022 GR86
Still not clear where the extra 1.8 lbs come from; I don't think TPMS + center caps + balancing weights + dust and dirt would account for that. Perhaps just an imprecision of my kitchen scales when used on an uneven pavement of my garage (I did try multiple locations though)... Here's a quick table of weight SX2s vs Primacy HP in different sizes: Code:
Size | SX2 | PHP | Difference 215/45R17 | 23.0 lbs | 20.8 lbs | 2.2 lbs 245/40R17 | 26.2 lbs | 22.5 lbs | 3.7 lbs Perhaps when I'm ready for RE71Rs I can get well below 40 lbs for the wheel+tire combo :P --- I couldn't easily find the weight of the OEM PP wheels without tires, but it used to be known to be ~22 lbs. |
| The Following User Says Thank You to timurrrr For This Useful Post: | Dzmitry (11-14-2019) |
#55 |
Drives: Track preped NA FRS
RE71R and yokos A052 are crazy light and have crazy grip. Be prepared to get a lot less durability out of them tho, probably 3 to 4 times less than the SX2.
| The Following User Says Thank You to Icecreamtruk For This Useful Post: | Clipdat (08-13-2022) |
#56 |
Drives: 2022 GR86
| New wheels - Rota Titan 17x9 | justinco | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 0 | 04-18-2017 02:30 PM |
| TWS Forged Wheels T66-F - Ultra lightweight Race Wheels with Style // DSG Performance | Jason@DSG | Wheels and Tires | 37 | 12-17-2014 03:50 PM |
| TWS T66-F Forged wheels on a Black FR-S | Touge Factory | Wheels and Tires | 17 | 08-21-2014 01:53 PM |
| Forged Wheels for 86 | Astra^EC | AFRICA | 5 | 09-24-2013 08:32 AM |
| AG.Function Forged Wheels | Eric@GetYourWheels | Wheels and Tires | 22 | 08-01-2012 01:16 PM |
