#29 |
Drives: 2014 GT86
TWS are forged and VERY light (10.63lbs 4.82kg, half the weight of stock wheels). Enkeis probably are much heavier. Price? I'm sure that during season team spends many many times more money then even those expensive forged wheels cost.
#30 | |
Drives: '23 BRZ
They also have great grip even stone cold To tell the truth they behave like normal street tires on the street. But careful over standing water...
#31 | |
Drives: '23 BRZ
If you really want to fully utilize 245s, get 8.5" minimum, or 9", or even 9.5" wheels. |
| The Following User Says Thank You to ZDan For This Useful Post: | Shark_Bait88 (05-18-2017) |
#32 |
Drives: 2013 FRS
#33 | |
Drives: 2013 Firestorm FR-S
As for autox, you should come out and try it. Might change your motivations a bit. There's one on Sunday the 28th in Joliet with the Chicago Region SCCA group. I'll be out there, along with a good number of other Toyobaru guys.Also, if you aren't already a member I'd recommend joining the Midwest 86 and Chi-Town 86 groups on FB. Best way to learn about track days, autox, rallyx, drift days, meets, and cruises that everyone in the area is going to.
"Shark_Bait88, the man who’s spent the most money modding his stock FR-S and it’s still stock." -@jdnguyen
#34 |
Drives: '15 BRZ RA
Well, they don't sell them just to teams. I am just saying that the double cost is not justified. Construction method is important, but not the only important factor. Enkeis method is not inferior to the forged ones and they provided evidence many times. If all the teams/winners used only forged wheels, then I agree that it would be different.
#35 |
I'd argue that forged is worth the extra money, particularly with the weight savings you see with something like the TWS. However, it's only worth the money if the costs balance properly. For a lot of enthusiasts, they aren't likely going to spend the extra money on forged wheels like TWS. A strong cast wheel will suffice for most grassroots uses. Same for some lower budget racing teams, and sponsorships/contingency programs definitely play a role in that decision. However, if there's money in the budget for it, I'd always go for the forged option over a comparable cast.
#36 | ||
Drives: 2013 FRS
| The Following User Says Thank You to James Russels For This Useful Post: | Shark_Bait88 (05-18-2017) |
#37 | ||||
Drives: '23 BRZ
Same tire on a wider wheel will give more stability and provide a wider contact patch, won't roll over onto shoulder as readily at a given amount of negative camber. Quote:
I wouldn't worry too too much about it though. Tire choice is WAY more important anyway. |
| The Following User Says Thank You to ZDan For This Useful Post: | Icecreamtruk (05-18-2017) |
#38 | |
9" with grippy 245s will change the feel of the car, but if you add the extra power through FI then it will be a good match. ZDan is right about compound being more important, but 17x9s and 245s seem to be more preferential for FI cars. 17x8 with 225 seems to be the sweet spot for NA cars, at least that track. As far as making the right choice, just do LOTS of research before making any purchases. There are plenty of guys in the Chicagloand area that'll be happy to give you rides so you can see how different setups feel.
#39 | |
Drives: 2013 FRS
#40 | |
#41 | |
FT86Club Official Vendor
Drives: 2013 BRZ, 2015 WRX, 2000 RSTi
![]() --Dan Mach V FastWRX.com |
| The Following 3 Users Say Thank You to Mach V Dan For This Useful Post: |
#42 | |
| 16" wheels. What's needed to "sharpen" it up again? | NWFRS | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 19 | 08-21-2015 06:48 PM |
| All the "smaller" aftermarket steering wheel options | susko | Cosmetic Modification (Interior/Exterior/Lighting) | 5 | 08-15-2015 07:38 PM |
| Any aftermarket "front bumper garnish" (black that cover lower middle) | jacobzking | Cosmetic Modification (Interior/Exterior/Lighting) | 17 | 12-09-2013 10:59 PM |
| WTB: OEM 16" wheels/tires or similar 16" skinny alloy wheels (USA, CA) | smmmurf | Wheels and Tires | 0 | 04-05-2013 01:42 PM |
| Anyone else try running "square" tires on "staggered" wheels? | hamlet | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 21 | 12-19-2012 01:59 PM |
