#29 | |
| The Following User Says Thank You to strat61caster For This Useful Post: | Cole (05-17-2017) |
#30 |
Not a troll
| The Following User Says Thank You to Cole For This Useful Post: | strat61caster (05-17-2017) |
#31 | |
Drives: 2013 Firestorm FR-S
If you weren't aware of that, then it's clear that you haven't really done much research and certainly don't have the experience to be offering advice on the sort of topics you are. None of us are trying to have egos, we just hate seeing misinformation being spread so adamantly by someone who clearly doesn't fully understand what they're talking about. People come here seeking knowledgeable advice, and they already get enough conflicting messages from people who actually know what they're talking about. Adding in poorly informed/inexperienced inputs and it's going to make this all a lot more daunting. Have some humility, realize that you've got a lot to learn (we all do really, but some more than others), and start reading more and talking less.
"Shark_Bait88, the man who’s spent the most money modding his stock FR-S and it’s still stock." -@jdnguyen
| The Following 13 Users Say Thank You to Shark_Bait88 For This Useful Post: | 8RZ (05-18-2017), BatStig (05-18-2017), cjd (05-18-2017), Cole (05-18-2017), Icecreamtruk (05-18-2017), OND (05-18-2017), Qadthane (05-18-2017), Ro_Ja (05-18-2017), Stang70Fastback (05-18-2017), Tcoat (05-18-2017), Tokay444 (05-18-2017), vintagemxer (05-18-2017), WRBrzRX (05-18-2017) |
#32 |
Drives: 2013 Subaru BRZ
Enough with the suggestions for my own personal improvement.
I have pointed out and remain of the opinion that wider or bigger wheels are not better for this car. I have cited decisions made by the factory, who you will have to admit know exactly how to modify their own cars and have done so. Subaru/Toyota fit 18x7.5 optional wheels in some markets. They fit 225/40x18 tires to those wheels. Is nobody wondering how they decided to do that? I cited a real world test by road and track who found that the stock sized tire on a stock diameter wheel was quicker than the larger tire on the wider wheel. So many posters on this forum actually know very little about what they are talking about and think that by attacking someone personally, or using juvenile insults that they are correct. Well, newsflash, most of you are completely wrong and do not understand what you're doing, why you're doing it or why it has the effect on your cars that it does. I, on the other hand, am posting from decades of experience about modifications I researched thoroughly and implemented one by one so I know for sure what effect each modification achieved. In the result I have modified my car to be just about perfect for very fast road driving year round in all weather. It is no coincidence in my opinion that the 2017 factory car is very like my car, but without the Supercharger. Now if anyone has some facts to establish that anything the factory and I have done wrong, fire away. |
#33 | |
So, the most compact coilovers make 15 mm more room for wider wheels and tires with more camber, if I understand the point being made. That's just over 1/2 inch of additional clearance to the suspension so fitted. Just how wide a wheel will that fit and at what camber setting? I should warn you, these are trick questions you may be wise not to answer. |
#34 | |||||||
A.K.A. Starlord
Drives: 2015 Series.Blue
Alright. I'll bite.
As long as you continue giving uninformed suggestions to others, you will continue to be told to either learn what you're talking about, or stop talking. Quote:
Your BRZ is a CHEAP sports car. There is not a single part on your car that cannot be improved upon. There is a reason why my massive 18x9 wheels weigh less than the factory 17x7 wheels. There is a reason why my 4-piston Big Brake Kit weighs 10 lb less than the tiny factory brakes. Literally everything on the BRZ is designed with cost in mind. It is all a compromise. To claim that your car is "as good as it gets" because it is similar to OEM is completely silly. It's like claiming that your homemade apple pie is "as good as it gets" because it's similar to the generic supermarket version that they sell for $2. Your statement makes literally NO sense. Quote:
Likewise, on some tracks, with higher speed portions, a wider tire might not be beneficial because the added drag at higher speeds won't be made up for with higher ultimate cornering speeds. In autocross, a 245 section tire WILL be faster than a 215 section tire. FACT. If it wasn't, then you wouldn't have LITERALLY EVERYONE in STX running a 245 tire. Quote:
I compete in STX autocross. If Subaru was building the car to be the best it could be in STX, then they fucked up. Some people (strangely) drag race their BRZs, and if Subaru was building the car to be the best that it could be at that, then they fucked up. Other people heavily track their cars. If Subaru was building a hardcore track machine, then they fucked up. But they didn't fuck up, because they needed to make it affordable, and capable of doing a little bit of everything. They did that. They built the $2 store-brand apple pie. It's our job to make it as tasty as Aunt Gretchin's secret recipe pie.
![]() Check out my blog, read all about my BRZ adventures, and oogle my sweet cell-phone photos! You can also find me on Instagram, and on Facebook. |
| The Following 14 Users Say Thank You to Stang70Fastback For This Useful Post: | 8RZ (05-19-2017), churchx (05-18-2017), cjd (05-18-2017), Cole (05-18-2017), D_Thissen (05-18-2017), KnightRyderx2 (05-18-2017), Ro_Ja (05-18-2017), Shark_Bait88 (05-18-2017), smg1138 (05-18-2017), strat61caster (05-18-2017), Tokay444 (05-18-2017), Vic4uf (05-21-2017), WRBrzRX (05-18-2017), x808drifter (05-18-2017) |
#35 |
Drives: 2014 FR-S
| The Following 3 Users Say Thank You to KnightRyderx2 For This Useful Post: |
#36 |
| The Following 4 Users Say Thank You to strat61caster For This Useful Post: |
#37 | |
Not a troll
| The Following 5 Users Say Thank You to Cole For This Useful Post: | finch1750 (05-18-2017), Shark_Bait88 (05-18-2017), Stang70Fastback (05-18-2017), strat61caster (05-18-2017), WRBrzRX (05-18-2017) |
#38 |
No, no, no. You need to go positive camber, because "positive" means better!
| The Following 3 Users Say Thank You to Shark_Bait88 For This Useful Post: |
#39 |
The misinformation that gets spewed on this forum is ridiculous. OEM is not always perfect. The 86 chassis is built on a budget. If the market would support this car costing 40k, the car would cost 40k. Fact is, it wont and Subaru/Toyota had to make sacrifices in order to get it at a price point that would actually sell.
#40 | |
I agree with some of your suggestions. I disagree with some of your suggestions. I don't think you're an idiot (maybe a little stubborn like most people). Having a reasonable discussion shouldn't be this hard. Just say that you like your car set up with X instead of Y. Maybe you tried Y and it didn't fit your needs. Try to keep in mind your preferences and situation are not exactly the same as everyone else's. And if a person gets 1 thing wrong it doesn't necessarily invalidate everything they've ever said. But if literally everyone is telling you to rethink something, it might be time to at least listen and consider the alternative. I'm still learning things all the time about building suspensions (and communicating with people). Some of things I've seen in the last 2 years would have blown me away 10 years ago. Anyone want to see a shock dyno of the Ohlins on a FIA GT3 championship winning racecar? Guarantee you'll be scratching your heads. That might be for another thread though. Anyway, I try to stay out of bitchfests as much as possible. So I'm going to go drink a beer and play outside. Have fun everyone! - Andrew |
| The Following 15 Users Say Thank You to Racecomp Engineering For This Useful Post: | 8RZ (05-19-2017), churchx (05-18-2017), cjd (05-18-2017), Cole (05-18-2017), D_Thissen (05-18-2017), KnightRyderx2 (05-19-2017), OND (05-18-2017), Ro_Ja (05-18-2017), Shark_Bait88 (05-19-2017), smg1138 (05-18-2017), Stang70Fastback (05-18-2017), strat61caster (05-18-2017), Vic4uf (05-21-2017), WRBrzRX (05-18-2017), x808drifter (05-18-2017) |
#41 |
Not a troll
| The Following 2 Users Say Thank You to Cole For This Useful Post: | Qadthane (05-18-2017), Shark_Bait88 (05-19-2017) |
#42 |
Yes you tease.
| The Following User Says Thank You to strat61caster For This Useful Post: | Shark_Bait88 (05-19-2017) |
| Tags |
| coilovers, daily driven, help please, question, suspension |
| Coilovers Coilovers, Coilovers: Tein, KW, BC, D2, Cusco, Eibach + more FREE SHIPPING! | No Limit Motorsport | Brakes, Suspension, Chassis | 204 | 05-26-2017 01:09 PM |
| Free SS Brake Lines with Purchase of any Coilovers!!! BC Racing, KW V3, Stance, Tein | Dustin@Dynosty | Brakes, Suspension, Chassis | 24 | 09-17-2013 03:19 PM |
| First purchase? | cncnjn | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 16 | 07-21-2013 05:41 PM |
| Where to purchase TRD KIT? | 914_WHITE_FRS | Cosmetic Modification (Interior/Exterior/Lighting) | 1 | 04-26-2013 03:08 AM |
| Special Purchase price-TEIN FLEX FR-S/BRZ coilovers | Stav | Canada Classifieds | 5 | 04-21-2013 06:41 PM |
