| Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) Wash, Wax, Details, Repairs |
#43 | |
Drives: 2015 FRS Asphalt
![]() Also since you're getting a new paint job done there shouldn't be much paint correction done to your car before the ceramic coating is done. You'll have to wait 30 days after your car is painted before the ceramic coating can be done. For me it was worth getting ceramic coating since my car sits 24/7 in the hot hawaiian sun. Peeps compliment me all the time on how shiny my car looks after 2 1/2 years. Washing the car is a breeze because the dirt doesn't stick to the car like glue. ![]() Cquartz Finest tends to be much more expensive than Optimum Gloss Coat. Optimum replaced Opticoat Pro with Gloss coat. At the time I chose Opti Coat Pro because it carries a 5 yr warranty vs 2 yrs for Cquartz Finest. What color are you repainting your car? Hot Lava again? |
| The Following User Says Thank You to 86geek For This Useful Post: | Tcoat (05-19-2017) |
#44 | |
Ya if it is that much work to ceramic coat then the pleasure factor of doing it myself disappears and I will indeed get it done. I have never had a car done before but I have not heard one single con to it. Hmmmm I wonder if the place doing the paint is into that...
| The Following 2 Users Say Thank You to Tcoat For This Useful Post: | 86geek (05-19-2017), Ultramaroon (05-19-2017) |
#45 | |
Drives: car
What's the prep? If its just claying and polishing then that's no problem for the average detailer with the right tools. |
#46 | |
Drives: Subaru BRZ
The car is washed, any wax/polish removed, contaminates removed. Paint is corrected and polished etc before application. I didn't watch the guy as it was very drawn out, from memory over 4hrs.. |
#47 |
Drives: car
@JD001 yeah that's like an average saturday cleaning for me
Also I want to add to the thread that nobody has mentioned my favorite step, pure polishing or heavy glaze. If you want your car to look perfect, you cannot skip this last and most important step before waxing (or anytime really). After cleaning, I use a product like Meguiar's Ultimate Polish, which is a pure polish that contains no abraisives. Works awesome on my GBS paint as it makes it look darker and wetter. ![]() I apply it with a DA polisher and finishing pads to spread it thinly and evenly. The polish is hard to spread by hand and using a DA makes it 10x easier. You'll need microfibers and spray wax to remove it all, it is a lot harder to remove than wax after it dries so you can only do a panel at a time. Last edited by radroach; 05-23-2017 at 12:59 PM. |
#48 |
Drives: N/A
Basic wash items:
2 bucket with grit guards. High quality microfiber drying towel. High quality microfiber wash mitt. Dedicated wheel bucket and mitt/tools. Nice hose nozzle. That is the basic equipment to wash your car to a higher standard lets say. In terms of claying, unless you have some unusual circumstance, claying is needed maybe 1X a year. Claying has a possibility of marring the finish just by the nature of what your asking clay to do, your gliding a piece of clay over the lubricated finish to sheer off contamination. Unless your going to machine polish I would probably skip the polish step, again that would only need to be once every few years. If your washing correctly you should not have a need to polish honesty. Your choice of shampoo is great, I would consider a different protection product however if you are dedicated to a wax I would get Collinite 845. Its affordable and durable. If you are looking to purchase something local for protection, i would look into Meguiars Ultimate Wax, and top that with Meguiars Ultimate Fast Finish. Sealants would be my choice over a wax, Sonax polymer net shield or Menzerna power lock would probably be my go to for a sealant. Last edited by NLS8520; 05-23-2017 at 09:11 PM. |
#49 |
Drives: wrx, brz
@Tcoat It took me about 12 hours total to finish it on my car. Wash, Iron-X, wash, clay bar, paint correction, polish, ipa, then finally two coats of Cquartz. I'm not a pro though and there were quite a few breaks/general ****ing around in that time. You don't necessarily have to do all that, but any swirls or scratches you have will be locked in and the previous owner of my car installed quite a few swirls. With new paint it'd be pretty easy assuming you don't get bad buff marks from the shop.
Cquartz itself applies similarly to a wax or other paint sealant. Basically, apply in overlapping pattern, wait a few minutes, buff off. The professional Cquartz Finest lasts longer and the installers are hand picked, probably for their ability with paint correction and polishing as that's where all the labor is. I have to get out and actually take real photos of it, but I just finished earlier this week and it's been raining ever since. Needs 48hrs to cure fully and has to stay dry during that time. Not supposed to wash it for at least one week too. But yes, it sure is shiny. This is somewhat exaggerated by the shitty photo.
#50 |
fabulous
needs moar stretched
#51 | |
Drives: Grrrr
| The Following User Says Thank You to Scrappydoo For This Useful Post: | Tcoat (05-25-2017) |
#52 |
Drives: Subaru BRZ
^^^^exactly what I've been thinking^^^^
If Tcoat is going for a complete car respray he should consider adding a bit more attitude to the Lava paint by adding more sparkle.. so it pops! |
| The Following User Says Thank You to JD001 For This Useful Post: | Tcoat (05-25-2017) |
#53 | |
I will stick with the stock colour but you want to bet there will be more than one coat of clear on it.
| The Following 2 Users Say Thank You to Tcoat For This Useful Post: | Scrappydoo (05-25-2017), Ultramaroon (05-25-2017) |
#54 | |
Drives: Subaru BRZ
Sounds like a nice cosy relationship..
| The Following User Says Thank You to JD001 For This Useful Post: | Ultramaroon (05-25-2017) |
#55 |
fabulous
![]() Haha... Bullshit. You had me there for a sec.
| The Following 3 Users Say Thank You to Ultramaroon For This Useful Post: |
#56 |
| The Following 2 Users Say Thank You to Tcoat For This Useful Post: | JD001 (05-25-2017), Ultramaroon (05-25-2017) |
| Waxing your FRS/BRZ? | Dino451 | Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) | 88 | 10-29-2015 05:36 PM |
| Waxing off with DA | l0aded | Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) | 5 | 04-23-2015 04:04 PM |
| Waxing a new car | brzzz | Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) | 7 | 07-26-2012 10:15 AM |
| Waxing help. | jurjurson | Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) | 14 | 07-18-2012 05:27 PM |
| Waxing/washing guides for noobies? | Hanakuso | Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) | 4 | 06-04-2012 05:02 PM |
