Old 05-11-2017, 05:21 PM   #15
Gforce
Drives: 2013 Subaru BRZ
Brake fluid should be completely flushed and replaced every two to three years maximum. If you live where the air is dry you can possibly go three years. Two years is the most common interval. If you track your car regularly you should be flushing brake fluid pretty frequently.
Gforce is offline   Reply With Quote
The Following User Says Thank You to Gforce For This Useful Post:
wparsons (05-11-2017)
Old 05-11-2017, 10:20 PM   #16
wparsons
wparsons's Avatar
I think both feel (which can be solved with MCB I hear) and stopping power. I like the brakes in other cars more. My gf's Cooper has massive rotors and that thing stops on a dime. I've also driven several other friends' and family cars and liked the brakes a lot. Don't know why that is, to be honest. I guess I just like to stop quicker lol.
Can you engage ABS in your car? If so, the brakes aren't what is limiting you from stopping quicker. How old is your car? If it's more than a couple years old, I'd flush the brake fluid, you could have air in the lines making them feel squishy. It might also be deceptive because we don't have much dive under braking compared to other cars.
And, unless your GF has a JCW Mini, the rotors are the same size as ours or smaller.
flickr
The Following User Says Thank You to wparsons For This Useful Post:
strat61caster (05-11-2017)
Old 05-12-2017, 02:56 AM   #17
Turdinator
Seņor Member
Turdinator's Avatar
Have you tried pushing the brake pedal harder?
1974 TA22 Celica
2013 86 GT
The Following User Says Thank You to Turdinator For This Useful Post:
wparsons (05-12-2017)
Old 05-12-2017, 08:50 AM   #18
ApexEight
Drives: 2014 Subaru BRZ Limited 6MT SSM
I'm running the PMu HC+800 on all-season Toyos. The fronts are nearing the end of their lives but the rears are still good. I need front rotors as well so I'll probably get Centric premiums and try some different front pads. With my setup I can engage ABS so the pads have enough power for the Toyos but what I don't like is the somewhat low inital bite and they squeal at very low speeds/light braking. The dust isn't a huge deal for me. I bought the car with the pads on them and tried re-bedding them with about a dozen back to back 80-20 hard stops and while the noise went away for a while, it eventually came back from daily driving. I'll be autocrossing with them on Sunday for the first time in this car so I'll report back with my experience. Fresh ATE Typ200 bleed.
Any pad good value pad recommendations? Considering Hawk HPS 5.0.
ApexEight is offline   Reply With Quote
Old 05-12-2017, 05:11 PM   #19
wparsons
wparsons's Avatar
I found the initial bite on the DS2500's better than stock, but not anywhere near as good as my club racer's when they're up to temp (they're barely as good as stock when totally cold). The club racer's are like glue when hot!
flickr
HID Headlight turns off during spirited driving tinma Cosmetic Modification (Interior/Exterior/Lighting) 14 11-19-2015 11:23 AM
Brake upgrade for a DD, spirited driving. justinsstang Suspension | Chassis | Brakes -- Sponsored by 949 Racing 22 09-23-2015 03:17 PM
Weight Reduction (budget diet) for daily/spirited driving 1086 Scion FR-S / Toyota 86 GT86 General Forum 86 03-22-2015 02:18 PM
Coil Overs for DD/ Spirited driving Wilso Suspension | Chassis | Brakes -- Sponsored by 949 Racing 22 06-11-2014 02:10 PM
Spirited 86 driving in Korea ESBjiujitsu FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 3 05-22-2012 03:47 AM
