Old 09-16-2017, 07:28 PM   #169
Drambeenie
Drambeenie's Avatar
Drives: Black 17 BRZ LT MT PP
BIG UPDATE!
The new riser covers came, and they fit perfectly with the inner structure. Attached them to the car and it's extremely solid. Also, SUPER FLUSH with the trunk! No gaps or anything. I'm so happy . Below are images and videos.
Solved these issues:
  • Front of the risers no longer come up when the trunk is slammed and the green clip stays connected.
  • Wing no longer vibrates during driving
  • Reduced the amount of vibration when slamming the wing
Oustanding issue:[LIST][*]Wing still wobbles slightly when slamming the trunk - Not sure if I should invest the time to make a middle riser given than this might be enough. What do you guys think? This riser cover is also made of not very strong material. The production one will be so that could have a further impact on the wobble.
Get ready these baby's are almost done!!
SPOILER FLUSH VIDEO
RISERS NO LIFT VIDEO
SMALL SLAM TEST
@johan what do you think of the wobble here?
TRUNK SLAM HARD
Also, If I don't have a middle riser, there are dimples in the trunk that will show. Here's what it looks like with the clear vinyl removed.
Drambeenie is offline   Reply With Quote
The Following 4 Users Say Thank You to Drambeenie For This Useful Post:
Akuma147 (09-16-2017), Andrew025 (09-16-2017), Elliotw (09-27-2017), tehShirt (09-16-2017)
Old 09-16-2017, 09:50 PM   #170
tehShirt
tehShirt's Avatar
Drives: 2014 Subaru Forester
Looking good!! Keep it up!
tehShirt is offline   Reply With Quote
Old 09-17-2017, 02:58 AM   #171
johan
Drives: '14 981CS, '99 NB1
The wobble is almost non-existant now imo. I think it's a total non-issue.
You mentioned that there is a stud or something in the spoiler that you can't remove where the middle support was? It can't be threaded out? - like with a double nut or something? If not, how did Subaru get it inside the wing in the first place...
johan is offline   Reply With Quote
The Following User Says Thank You to johan For This Useful Post:
Drambeenie (09-17-2017)
Old 09-17-2017, 08:41 AM   #172
Drambeenie
Drambeenie's Avatar
Awesome. I stripped the nut trying to remove it. I’m gonna get some vice grips and try again. If it was assembled it could be disassembled
Next step is to order the outer shells in the stronger production material.
The Following User Says Thank You to Drambeenie For This Useful Post:
johan (09-18-2017)
Old 09-17-2017, 07:51 PM   #173
jubella2
jubella2's Avatar
Drives: DGM BRZ
Nice!
jubella2 is offline   Reply With Quote
The Following User Says Thank You to jubella2 For This Useful Post:
Old 09-22-2017, 01:57 PM   #174
CAPSLOCK
CAPSLOCK's Avatar
Drives: Miata, 17' BRZ
Not sure if this has been covered in previous posts, but how do you plan to address the hole left by the center mounting point?
CAPSLOCK is offline   Reply With Quote
The Following User Says Thank You to CAPSLOCK For This Useful Post:
Drambeenie (09-22-2017)
Old 09-22-2017, 03:59 PM   #175
Drambeenie
Drambeenie's Avatar
You're referring to those two dimples right? Haven't discussed it in previous posts. I was chatting with @tehShirt and was thinking to either make some sort of badge like a rectangular small piece that covers it saying BRZ or something, or just make a rectangular piece that is paint matched and placed on top of it.
Do you have any ideas of what you'd do with that?
Old 09-23-2017, 10:38 PM   #176
CAPSLOCK
CAPSLOCK's Avatar
Would something like this work?
http://www.subispeed.com/hcd-paint-m...E#.WccL98ZryUk
Old 09-24-2017, 02:12 AM   #177
imnotsureaboutbrz
Drives: between cars...
I don't think the center part is a whole just a dimpled. I think any attempt to cover it will just draw attention to it. One thing that did come to mind is making/using a "wing stabilizer" like the Perrin one below. A simple pop on piece that will please the crowd that wants a center piece and would serve to cover the dimples.
imnotsureaboutbrz is offline   Reply With Quote
Old 09-24-2017, 09:58 AM   #178
Drambeenie
Drambeenie's Avatar
The dimples are surrounded by a 40mm x 28mm clear bra. In the pic above I removed it but without it being removed it looks odd sitting on the trunk. My current plan is a paint matched piece that covers the clear bra. For people who don’t want the centerpiece it’ll be covered.
The center wing stabilizers are something I’m going back and forth about. You don’t need them as the wing doesn’t wobble while driving, and only wobbles if you slam the trunk with your hand on the trunk.. But before I invest more $ I need to see if there’s enough interest in the project at all.
imnotsureaboutbrz (09-25-2017)
Old 09-27-2017, 12:51 AM   #179
Drambeenie
Drambeenie's Avatar
Just received pics of the risers straight out of the 3D SLA printer. Manufactured in Guangdong China. You can see how high quality the print is. Super smooth surface! These have not been sanded or treated in any way post printing.
These cost a lot given the super short quantity, but with a large scale order I can get these down to an appealing price point.
The Following 6 Users Say Thank You to Drambeenie For This Useful Post:
Andrew025 (09-27-2017), GhostRai (10-06-2017), spike021 (09-27-2017), TachyonBomb (09-27-2017), tacos (09-27-2017), tehShirt (09-27-2017)
Old 09-27-2017, 10:49 AM   #180
tehShirt
tehShirt's Avatar
The Following User Says Thank You to tehShirt For This Useful Post:
Drambeenie (09-27-2017)
Old 09-27-2017, 04:17 PM   #181
Elliotw
Elliotw's Avatar
Drives: '18 BRZ tS, '18 GTI SE, '11 RS
This is freakin awesome. Keep up the good work. who are you working with on the 3D printing?
Elliotw is offline   Reply With Quote
The Following User Says Thank You to Elliotw For This Useful Post:
Old 09-27-2017, 10:02 PM   #182
Drambeenie
Drambeenie's Avatar
Thanks dude! I found a great supplier through Alibaba. However the same quality print can come out of any good quality SLA 3D printer.
Elliotw (09-28-2017)
removal, spoiler, trunk, wing
Search this Thread:
Advanced Search
Remove trunk spoiler clips? Drambeenie Member's Car Journals 0 05-10-2017 12:31 AM
2017 BRZ Limited Spoiler Chayce808 Cosmetic Modification (Interior/Exterior/Lighting) 6 01-04-2017 01:49 AM
2017 BRZ without spoiler? vroomvroom1 BRZ First-Gen (2012+) -- General Topics 9 07-18-2016 11:46 AM
Remove spoiler for Rocket Bunny one? xrinnenganx Cosmetic Modification (Interior/Exterior/Lighting) 7 10-21-2014 11:28 AM
Is there a way to remove the spoiler? rapier7 BRZ First-Gen (2012+) -- General Topics 15 08-21-2013 11:58 PM
