86WORX
Old 09-01-2017, 07:57 PM   #141
imnotsureaboutbrz
Drives: between cars...
Originally Posted by Drambeenie View Post
Ahh that's actually a vinyl oval my girlfriend made me when I took the spoiler off the car to prevent any rain from getting into the trunk .
The original piece doesn't have any PPF film underneath, and this riser actually has exactly the same footprint as the OEM piece. We got it 3D scanned and then traced the curve exactly. The risers contain foam and rubber underneath to prevent that, but it's a good idea to also perhaps supply paint protection film as well.
well... that answers that... drive on!
imnotsureaboutbrz is offline   Reply With Quote
Old 09-02-2017, 10:11 PM   #142
Drambeenie
Drambeenie's Avatar
Drives: Black 17 BRZ LT MT PP
Was wondering why the risers suddenly got soo jiggly...Looks like the shitty PLA material created with the FDM 3D printed failed the slam the trunk test. This material has been great for test fitting but mechanical tests, which is the next step basically, it fails.
Going to reinforce this weak spot and get the next inner core prototype out of Glass Nylon. Expensive for prototyping but has to be safe!
Drambeenie is offline   Reply With Quote
The Following User Says Thank You to Drambeenie For This Useful Post:
tehShirt (09-05-2017)
Old 09-04-2017, 10:02 PM   #143
Aluma007
Drives: 2017 Brz
looks great!
Aluma007 is offline   Reply With Quote
The Following User Says Thank You to Aluma007 For This Useful Post:
Drambeenie (09-05-2017)
Old 09-05-2017, 03:02 PM   #144
Drambeenie
Drambeenie's Avatar
Small update: The Glass Nylon internals have been ordered along with a strong ABS cover. They're expected to arrive on the 14th (longer timeline for this material) at which point I will do some trunk slam and fitment testing. I'm expecting this to be the last prototype due to using production materials, but anything could happen.
I also can get the parts at a lower price if I order more at once, so perhaps I'll setup a preorder once the part is ready for production.
The Following 3 Users Say Thank You to Drambeenie For This Useful Post:
Akuma147 (09-06-2017), Andrew025 (09-06-2017), tehShirt (09-05-2017)
Old 09-07-2017, 05:38 PM   #145
Kaotic Lazagna
Drives: GR Corolla
Could it feel heavier since the existing weight is farther out? Kinda like holding and swinging a gallon bottle of water closer or farther away from your body???
The Following User Says Thank You to Kaotic Lazagna For This Useful Post:
Drambeenie (09-08-2017)
Old 09-08-2017, 09:24 AM   #146
Drambeenie
Drambeenie's Avatar
Yes that's certainly possible. Also could explain why the front green clips easily pop-out; the focal point has changed and there's a ton more weight pulling it up.
Old 09-09-2017, 03:26 PM   #147
Poodles
Drives: 2015 Series.Blue
Just found this thread. Hobby of mine is 3D printing as well, and yeah, PLA is definitely NOT good for mechanical strength on parts. ABS at least and you may have issues with glass nylon out of a FDM printer. I'd try ABS and try beefing the part up a bit (and more infill!). Unless you have access to a Markforge, which would likely be stronger than the wing...
I was looking at a Tommy Kaira wing but after seeing this...wonder how hard it would be to install on a 2015.
The Following User Says Thank You to Poodles For This Useful Post:
Drambeenie (09-09-2017)
Old 09-09-2017, 04:15 PM   #148
Drambeenie
Drambeenie's Avatar
Glad you found it! 3D printing is pretty awesome. I ordered the Glass Nylon using an SLS printing company - The detail is incredible and its soo strong.
The 2017 wing could go on the prior models but would require drilling for screw placement - and you'd need to order a 17 wing. Unpainted they run for around $450. FT86SpeedFactory also sell a Carbon Reproduction of the 17 wing for prior year BRZ models.
I just test fitted the internal part and it works great. I'll post a video about that soon! We're almost down to the wire!
Old 09-09-2017, 07:29 PM   #149
Aluma007
Drives: 2017 Brz
just curious, how will the extra height affect the downforce?
Old 09-09-2017, 08:04 PM   #150
Drambeenie
Drambeenie's Avatar
The wing will increase downforce as its higher and further back than stock. Don't have exact numbers though.
Old 09-09-2017, 09:55 PM   #151
Drambeenie
Drambeenie's Avatar
The glass Nylon internals came. They have the texture of a sugar cube and are extremely strong. When I clapped both pieces together it sounded like cement. Looks can be deceiving!
Also got my new drambeenie logo on it which features the same dinosaur thing as my avatar, which is actually a blow up pool toy belonging to my friends kid.
imnotsureaboutbrz (09-10-2017)
Old 09-10-2017, 04:01 PM   #152
Drambeenie
Drambeenie's Avatar
The Glass Nylon risers are extremely strong and fit perfectly. I replaced the green clips with a bolt as a test to see if it'll keep the risers from popping up and they do! The risers don't raise at all. The only issue with that is if the green clips aren't strong enough and I do need to use bolts, it's extremely difficult to access them from within the trunk - So I need to think of a solution for that. Asking people to use a saw drill is not gonna fly.
I drove around the city with the wing reaching a maximum speed of 50mph and also drove on very bumpy roads. The spoiler doesn't seem to flex when driving even on bumpy roads - it's really solid, and the Glass Nylon pieces have no cracks or anything, even with multiple hard trunk slam tests. $ material, but it's the good stuff!
However, after doing the trunk slam test, it's pretty clear that a middle riser is 100% necessary and can't just be an optional thing. The aluminum spoiler jiggles ALOT if you slam the trunk from the trunk. If you're pushing down on the spoiler to close the trunk there's very little-to-no jiggle, but I can't tell people they can only close their trunks one way - So a middle riser will now be developed to prevent this issues.
CLICK ON THE IMAGE BELOW TO PLAY THE VIDEO OF THE TRUNK SLAM TEST.
tehShirt (09-10-2017)
Old 09-10-2017, 04:55 PM   #153
Mithosphere
Fart-noise maker
Mithosphere's Avatar
Drives: 2014 Scion FR-S
How much jiggle? Is it pretty stable at speed?
Mithosphere is offline   Reply With Quote
The Following User Says Thank You to Mithosphere For This Useful Post:
Drambeenie (09-10-2017)
Old 09-10-2017, 06:17 PM   #154
Drambeenie
Drambeenie's Avatar
When driving little to none. If I hit big bumps it vibrates, but my car is lowered so it's much stiffer.
Just took it on the highway at highway speeds and it handled very well little to no movement. It's when I got to slower speeds and drove over bumps it vibrated slightly and not on all bumps.
With the center support I bet it won't move at all, but we'll find out!
removal, spoiler, trunk, wing
Remove trunk spoiler clips? Drambeenie Member's Car Journals 0 05-10-2017 12:31 AM
2017 BRZ Limited Spoiler Chayce808 Cosmetic Modification (Interior/Exterior/Lighting) 6 01-04-2017 01:49 AM
2017 BRZ without spoiler? vroomvroom1 BRZ First-Gen (2012+) -- General Topics 9 07-18-2016 11:46 AM
Remove spoiler for Rocket Bunny one? xrinnenganx Cosmetic Modification (Interior/Exterior/Lighting) 7 10-21-2014 11:28 AM
Is there a way to remove the spoiler? rapier7 BRZ First-Gen (2012+) -- General Topics 15 08-21-2013 11:58 PM
