#15 |
Drives: 2014 BRZ
Guess I'll have to give it a try. Next track day is the 26th...
#16 |
Drives: 2013 BRZ Limited
Other cars solve this problem by making a very simple sheet metal heat sink that you can attach to the motor.
Instagram: @zdr_93523
Youtube: https://www.youtube.com/user/zdr93523 Pink Ribbon Racing 2013 BRZ Limited NASA ST2 and TT2 race car www.makesmodels.com www.camautomag.com |
#17 |
Drives: 2014 BRZ
Wonder if easy to do on a street car. I imagine it is easier to do during a race car build when it's all stripped out.
#18 |
I haven't looked for the the PS motor, but it is super simple. You can literally bend something that looks like a heat sink and zip tie it to the motor and it should facilitate enough heat transfer to keep it from cutting out. I've never thought about it since we run such wide non-DOT slicks on the car and the steering effort is generally heavier, but mine may be having the same problem.
#19 |
I'll see if I can make a solution for this. If I do, I'll offer it up.
#20 |
Drives: Hydra EMS Powered FRS Raven Black
If you pull the fuse you'll have an impossible time turning the car just like when the system shuts down. You either reduce your caster as I'm assuming you've added some or you build a cooler. I was going to do this with copper tubing and a computer cooler pump.
The ECU CAN option is beyond a simple fix but it's something we can do with the Hydra EMS. Given I felt the car was better with less caster (feel and braking) and it pretty much eliminated the system consistently shutting off, it's best just to leave well enough alone. Try making a simple fluid cooler as I don't think a heat sink alone will not do the trick. |
| The Following User Says Thank You to Element Tuning For This Useful Post: | strat61caster (05-17-2017) |
#21 |
Drives: 2013 BRZ sprintex SC
Do we have any solution for this problem?
Having that issue on my 2013 after changing the tyres to semi slicks. And onlyyyyy on trailbraking. If you leave the brakes before the turn or once it happens you are good to go. |
| FS: OEM Steering Rack | MicheleAbbate | Brakes, Suspension, Chassis | 0 | 04-18-2016 03:51 PM |
| Cusco steering rack stay | olsonpg | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 6 | 07-27-2015 08:35 PM |
| TiC steering rack bushings review | mokinbird87 | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 0 | 07-21-2014 01:43 PM |
| Steering Rack Play | FR Sports | CANADA | 1 | 06-04-2014 10:00 PM |
| Steering rack | diss7 | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 6 | 04-07-2014 01:12 AM |
