#85 | |
Weight Weenie
Drives: 15 FR-S
The gauges. I have chrome knobs but they are different. They're knurled. Sorry, no pics. Here's the ones I got with the magna cluster in the video below. That does a lot too. http://www.ft86speedfactory.com/rsp-...l#.W0QJciAnbIU Last edited by new2subaru; 07-09-2018 at 10:23 PM. |
#86 | |
Drives: C5 Corvette, '17 Toyota 86, Jeep XJ
https://www.86speed.com/products/frs...s-set-3pc.html |
#87 | |
Drives: 2017 Halo 86
lol $86.00 That's amazing, if you know what I mean
Build Thread / Daily Driver
OFT Stage 2+, GrimmSpeed CAI, JDL Ultra Quiet FP, Perrin 2.5" Resonated CBE, Enkei 18x8.5 +45, 245/35 Continental ExtremeContact |
#88 | |
Weight Weenie
Drives: 15 FR-S
Yep, that's them. I like them a lot |
| The Following User Says Thank You to new2subaru For This Useful Post: | SuperTom (07-10-2018) |
#89 |
Just got finished installing my ACE 350 headers!! Still waiting on base tune from CSG/Delicous they said by the weekend.
Took a spin with my OFT V4.03 tune but didn't go full throttle. Intial thoughts are great you can tell the torque dip is gone just as good or better then the Gruppe-s uel headers. Also I prefer the tone of EL header its sounds much cleaner and refined and maybe a bit quieter then the UEL. Sounds great with my Invidia CFP, HKS Legamax. Although I may change as I want 2.5" piping all the way throught to match the output of the ACE. Any of the Japanese exhausts are going to be 2.36". Considering Hooker Blacker Catted with Helmholtz chamber FP, and their dual catback (7lbs lighter than stock). Or Borla Catback (10lbs lighter than stock) Comparison picture. All bolts anti-seized, all connection surfaces lightly coated with acoustic-seal, ready to install ![]() scraped all surfaces of old gasket ![]() Forgot to take pics after it was all bolted up Did have to take off a 14mm for the passenger side motor mount and jacked an inch with a board under the oilpan. I also installed the Overpipe first which blocks access to one of the header bolts with a socket. I was able to reach around with a wrench to get to it. Overall painless install. Can't wait for my tune!!!
| The Following 4 Users Say Thank You to SuperTom For This Useful Post: |
#90 |
#91 |
Weight Weenie
Drives: 15 FR-S
They look really sharp with the Alcantara
| The Following User Says Thank You to new2subaru For This Useful Post: | SuperTom (07-20-2018) |
#92 |
Update: Have had a few back and forth datalogs with Delicious Tuning no revisions on the base tune they have sent so far. Which means their revisions must be getting better and better.
Just got in the first part to mate up with the ACE 350. I am switching to a Hooker Headers catted front pipe with an old school technology J-Pipe Helmholtz resonator. ~9.5lbs 2.5"OD. So only .25lbs heaver than my catted Invidia FP with no resonator and 60mm piping. Comes in 2 parts. Was disappointed it didn't come with a new front gasket but my ACE one I just put on should still be good. ![]() ![]() ![]() Interesting they sealed the inside of the J-pipe and it only has a small maybe 1/2 hole. This is supposed to get rid of Drone
#93 |
Update: 2nd revision logs sent in on Delicious Tune
Got Borla Catback in Weight After Tare of plate 29.25lbs includes Clamps I measured 39.25lbs for stock catcack that will be exactly 10lbs off the rear!
#94 |
Finally installed the new Hooker Blackheart Catted FP, And Borla Catback
NEW Estimated vehicle Weight = 2526.5 LBS Got about 10lbs lighter today with no increase volume in exhaust just a deeper tone and increase in flow with 2.5" (63mm) piping to mate up with ACE 350 headers! Inside of Borla muffler interesting! ![]() Carbon Fiber Driveshaft. If I wanted I could de-weld the stock Driveshaft mounting steel and save some more weight there! ![]() Everything Installed ![]()
#95 |
Weight Weenie
Drives: 15 FR-S
Is it fairly loud?
#96 |
| The Following 2 Users Say Thank You to SuperTom For This Useful Post: | MCTeeJ (07-30-2018), new2subaru (07-30-2018) |
#97 |
Sunday Update:
7th revision of Zach and Delicious Tune. The turn around is really fast on their part, the delay is usually on me getting logs back to them with my job being busy. The drivetrain seems smoother and smoother each time. Even the shifting seems smoother and the exhaust sounds more refined. Added some interior accents from Aliexpress. Im really impressed with the quality of the shift knob. ALso did the guage cluster and a mirror knob. ![]() ![]() ![]()
| The Following 2 Users Say Thank You to SuperTom For This Useful Post: | JeremyR (08-07-2018), new2subaru (08-05-2018) |
#98 |
Finished with Delicious Tuning the ACE 350. Took 7 revisions to get perfect. Acceleration is nice and smooth and powerful. Total exhaust is not loud at all and sound very smooth clean refined. With Hooker Blackheart catted/resonated fp and Borla Catback
Since the Borla catback moves the muffler up near the drive shaft there is a big Void where my HKS legamax suitcase or style muffler was. So I made a cheap wind blocker in that space with some coroplast write-up is here http://www.ft86club.com/forums/showthread.php?t=129499 ![]() Only gained 1.5lbs !! New weight 2528 |
| The Following User Says Thank You to SuperTom For This Useful Post: | Raven86Project (08-14-2018) |
| mothespaceman: 14' Satin White BRZ Build! | mothespaceman | Member's Car Journals | 25 | 09-19-2014 06:30 PM |
| White BRZ Limited Build Thread | NoFlush | Member's Car Journals | 4 | 05-10-2014 03:04 PM |
| white trd 2013 build | Pcharliep04 | Member's Car Journals | 0 | 04-24-2014 02:25 AM |
| Build-thread White Wasp FR-S by Mit_Peid | mit_peid | Member's Car Journals | 7 | 01-05-2014 08:47 PM |
| White GT manual Jan Build availlable | 86•BRZ | AUSTRALIA | 2 | 01-02-2013 12:45 AM |
