#253 | |
Purist
Drives: 2013 FRS - Hot Lava
WTB: Everything Verus
RaceComp SS-1, Complete SuperPro bushings, TR Motorsport FF10 17x9 +45, GruppeS UEL, HKS Hi-Power V2, OFT(93/E85) |
#254 | |
Drives: Subaru BRZ
Don't forget don't your dust pan, it's sitting on your parcel shelf... |
#255 |
Drives: C5 Corvette, '17 Toyota 86, Jeep XJ
This is what I had ordered. you only need one roll if you can find it sold that way
https://www.aliexpress.com/item/3295...27424c4dHEw1Qh |
| The Following 2 Users Say Thank You to SuperTom For This Useful Post: | ichitaka05 (04-17-2020), scottman (04-12-2020) |
#256 |
Drives: 13 White MT FR-S
Have you driven it with the under body panels? I was going to do the exact same thing but I thought the exhaust would melt it almost immediately.
#257 | |
Last year I did a test piece with coroplast in the tunnel area. similar to the pieces Velox sells. Nothing melted |
| The Following User Says Thank You to SuperTom For This Useful Post: | ML (04-14-2020) |
#258 |
Just took some quick snaps yesterday. Ill admit to not being good at the whole picture taking thing but you get the idea
| The Following 3 Users Say Thank You to SuperTom For This Useful Post: |
#259 |
have you seen Marsh Composites? http://www.marshcomposites.com/products
| The Following User Says Thank You to ML For This Useful Post: | why? (04-16-2020) |
#260 | |
#262 |
Drives: Black BRZ
Awesome pics...
What would be really great with a weight loss build is some sort of performance data just to get an idea. Do you plan on doing 0-60 or any 1/4 mile runs with one of those Dragy GPS things? I do understand that straight-line performance is not the purpose of the car or even this build, but just to get an idea. Before/after track times at a local circuit would be great, too. Were you able to get any data before the build? Awesome update |
| The Following User Says Thank You to WC-BRZ For This Useful Post: | SuperTom (04-17-2020) |
#263 |
#264 | |
But I did get curious about the effects and went looking for a good weight @ HP calculator just for an idea. Obviously there is way more to #'s like gearing ect. But for a baseline idea of acceleration effects. I used this calculator https://robrobinette.com/et.htm Putting in weight 2774/ FLywheel HP 205 you get 1/4 mile at 14.6. I think most stock verified times are closer to 14.8. https://www.caranddriver.com/reviews...tested-review/ Entering weight 2350/ Flywheel HP 205 you get 13.8 in the 1/4. A difference of .8 secs. I don't think it would be that much maybe closer to .4 Then I put in 2350lbs/Flywheel HP 225 (estimating my power mods) and got 13.4 in the 1/4. Not saying my car would run that all but could be able to get into the high 13's. |
#265 |
Site Moderator
Drives: ichi 86 Project
Good read. I only read up to page 12 (new to old) and maybe missed it, but you have looked into Radium Engineer ECU bracket? It may shave few oz than stock steel bracket.
![]() Max Orido's rear diffuser might be lil bit lighter than Verus Engineer and it's designed for kouki bumper, so sadly zenki owner like me can't use it... but you can of course, 326Power ver looks small and prob lighter, but feels like not as functional as Max Orido one. ![]() For interior, TRD JP finally released some cf good. Door cover weight 1.2kg each (2.6lbs) ![]() ![]() ...but spending $4,400 just for door covers is hard pill to swallow. There's alumium door cover from Spnywoosh. I've heard some of older ver doesn't fit well, but cost only $220 isn't bad and shave 4lbs-ish total. ![]() Now... if someone can make a copy of 14R aero kit. Cuz front bumper & wider fender costing total of $15k! lol ![]() Anyways, keep up the good work! |
| The Following 4 Users Say Thank You to ichitaka05 For This Useful Post: |
#266 |
Light, looks good, inexpensive...pick two haha
| mothespaceman: 14' Satin White BRZ Build! | mothespaceman | Member's Car Journals | 25 | 09-19-2014 06:30 PM |
| White BRZ Limited Build Thread | NoFlush | Member's Car Journals | 4 | 05-10-2014 03:04 PM |
| white trd 2013 build | Pcharliep04 | Member's Car Journals | 0 | 04-24-2014 02:25 AM |
| Build-thread White Wasp FR-S by Mit_Peid | mit_peid | Member's Car Journals | 7 | 01-05-2014 08:47 PM |
| White GT manual Jan Build availlable | 86•BRZ | AUSTRALIA | 2 | 01-02-2013 12:45 AM |
