#225 |
Drives: C5 Corvette, '17 Toyota 86, Jeep XJ
Finally installed my swizz cheezed ebrake. Was waiting on my new ebrake handle to show up
So drilled down the ebrake to save .5 lb of it, new handle added .25lb back on. While I had everything apart was able to take over .25 off the brackets for the ebrake lines/ removed rear most bracket for center console not needed Stock 3.1 ![]() swisscheesed with new heavier handle ![]() Ebrake line brackets ![]() One less bracket and material removal ![]() Installed ![]() Weight saved .5lbs total New weight 2330.75 LBS Last edited by SuperTom; 02-13-2020 at 05:16 PM. |
| The Following User Says Thank You to SuperTom For This Useful Post: | Tristor (02-26-2020) |
#226 | |
The guy w/o an FRS or BRZ
Drives: '23 GR86 Premium 6MT Halo White
Sent from my Pixel 2 using Tapatalk Last edited by ROFL it's Waffle; 02-13-2020 at 04:09 PM. |
#227 | |
Functional integrity wasn't sacrificed drilling multiple smaller holes vs. a few big holes. I can pull on the ebrake hard and it feels just as solid as before. Most of that steel is pretty thick |
#228 |
Just added some weight today but hopefully the aero benefits will outweight the gain especially with all the highway driving I do.
Added on the Verus non-aggressive diffuser. With hardware used adds 8.5lbs on the rear Say its looks great and is sturdy. Fit with my FactionFab ti exhaust. Only thing with mine was the back of the diffuser (toward the front of the car) had to be at full droop to go over the muffler cannisters. ![]() ![]() ![]() ![]() You can see at full droop in the rear air will still be able to get up the inside of the diffuser. So the Verus suspension cover is mandatory in my case. I think ill be making my own very soon. ![]() This aero project is not complete but will be working on ways to smooth the underbody to the diffuser. New weight up to 2339 |
#229 |
Drives: 2014 Subaru Forester
#230 |
Its called SSCO anodized on ebay. I like it very much. Pulling on the handle just feels more positive, even with material removed on my ebrake. The center grippy area can also be removed, believe there are other colors available.
You do have to get your own drift button https://www.ebay.com/itm/SSCO-ANODIZ...72.m2749.l2649 |
| The Following User Says Thank You to SuperTom For This Useful Post: | tehShirt (02-19-2020) |
#231 | |
#232 |
Drives: 2017 toyota 86
Is your muffler in the way or the pipe going to the muffler?
My csg mxp catback muffler fit but the pipe to muffler was routed in a way it got in the way so i just cut off some of the diffuser metal in that area. Made no real negative difference but i could now mount diffuser up as high as possible. I think it offers most drag reduction downforce and ground clearance higher up it is. |
#233 |
Drives: 2015 Scion FRS
Do you have a link for the calipers? love the thread!
#234 | |
The roundness of the canisters(mufflers is what would be touching the diffuser. I will be filling in the space from the diffuser up past the gas tank soon. So the diffuser hanging low wont matter as much, although I prefer if it were up higher as well. My concern with it hanging low is air getting trapped above the diffuser, so that space will get filled. |
#235 |
Thanks for the compliment. The calipers were on rock auto. Search for 2006 Subaru Impreza 2.5 Turbocharged (WRX) rear calipers. You have option to get plain, or pay a little more for the Red powdercoated like I did. Part #'s is CENTRIC 14247525 & CENTRIC 14247526. Looks like they are selling out fast. |
#236 |
Drives: 2010 corolla
Can't wait for more updates on this thing!
| The Following User Says Thank You to beltax90 For This Useful Post: | SuperTom (03-09-2020) |
#237 |
Drives: 2013 frs red
Car must feel great right now. Hows the acceleration?
#238 |
Just removed my stock wheels and spacers and put my hypergrams back on. Light wheels definitely make a difference in that instant acceleration
Currently working on the undercar aero to mate up with the rear diffuser. Mainly making smooth panels for the whole underbody. And just got a genuine SARD wing to install. Family situations have slowed progress |
| The Following 2 Users Say Thank You to SuperTom For This Useful Post: | Lantanafrs2 (03-09-2020), why? (03-11-2020) |
| mothespaceman: 14' Satin White BRZ Build! | mothespaceman | Member's Car Journals | 25 | 09-19-2014 06:30 PM |
| White BRZ Limited Build Thread | NoFlush | Member's Car Journals | 4 | 05-10-2014 03:04 PM |
| white trd 2013 build | Pcharliep04 | Member's Car Journals | 0 | 04-24-2014 02:25 AM |
| Build-thread White Wasp FR-S by Mit_Peid | mit_peid | Member's Car Journals | 7 | 01-05-2014 08:47 PM |
| White GT manual Jan Build availlable | 86•BRZ | AUSTRALIA | 2 | 01-02-2013 12:45 AM |
