86WORX
Old 01-04-2020, 10:47 PM   #197
SuperTom
SuperTom's Avatar
Drives: C5 Corvette, '17 Toyota 86, Jeep XJ
Originally Posted by Shadotracker View Post
I'm surprised that you haven't made the just the airbox out of chloroplast just yet. That is what my friend did for his STU build for his STI in autocross.
any links to his build?
I don't necessarily have to lose weight on the intake if it is effective. If im going to change my intake I want something ram air like the Gruppe M Revolution intake the shoots straight forward from the throttle body. just don't want to spend that kind of money right now.
I have a vararam on my corvette and when you get going that thing works! For the 86 it would be nice to pull in some air from the fog light holes
SuperTom is offline   Reply With Quote
Old 01-05-2020, 04:28 AM   #198
RayRay88
Drives: 2017 86 860 Special Edition
The 86 already has a cold air setup oem (TRD or oem box). It takes in air from the center opening in the bumper. There's no benefit to pulling in air from the foglight openings. Something like the Gruppe M probably takes in more air, via larger ducts, but in reality you're not going to see crazy gains vs just a high flow filter and snorkel mod.
RayRay88 is offline   Reply With Quote
Old 01-05-2020, 09:45 PM   #199
SuperTom
SuperTom's Avatar
sneak preview of something ive been working on. A stout but lightweight battery cage to mount my Shorai in the trunk
I used thicker aluminum even though a step down thinner aluminum would have worked. Still came out to only a hair over a pound!
With the Shorai
The Following 2 Users Say Thank You to SuperTom For This Useful Post:
new2subaru (01-05-2020), q335r49 (01-18-2020)
Old 01-07-2020, 01:58 PM   #200
SuperTom
SuperTom's Avatar
Got the battery installed in the trunk. Put it right in the center as that was the easiest to mount and drill holes ect. Also only added 2.25lbs of cabling
Had to figure out the new weights from each area of the car.
Front :
-Stock Battery/Trace/Holder -29.75, + .5lbs underhood connectors = -29.25lbs
Middle:
+ Cable 2.25lbs
Rear:
Shorai Battery/Mount/ Negative Cable +6.25lbs
New car weight 2342lbs
Stock battery/tray/Tie bar
Connection point I made out of and old Rubber Exhaust hanger
Connected those to the stock under battery bracket
Weight of the 4gauge cable I had leftover from stereo installs
- Minus what I didn't use
Weight of the Battery/Mount/Negative Cable
Installed in the trunk, used the spare tire mount for my ground point, Idled the car for 10 mins everything seems great!
In summary I was able to Take alot of weight off the front and only add a few total pounds, put some over the rear tires!!
jflogerzi (01-07-2020), new2subaru (01-07-2020)
Old 01-07-2020, 02:47 PM   #201
amcp1
Drives: frs
Only thing I'd say is you moved weight outside the wheelbase of the car. The more a mass is centered in the vehicle, the better it will handle. The Shorai in the stock spot should help F:R balance as your loosing weight towards the front.
My 2 cents.
amcp1 is offline   Reply With Quote
Old 01-07-2020, 08:03 PM   #202
SuperTom
SuperTom's Avatar
My 2 cents.
Well I already had it in the stock spot before. Back end of my car is really light if you are following my whole build. Main goal was to get the front even lighter and put a little weight in the rear.
Yes I wanted it more centered (in front of the spare tire area) but there wasn't enough flat surface anywhere else to mount it
Old 01-17-2020, 03:42 PM   #203
SuperTom
SuperTom's Avatar
Well it was cold as balls today but I managed to get the Cusco SOFT rear sway bar installed today. This was with Godspeed Endlinks and new Nolathane bushings.
Total Package was 1lb lighter!!
Current weight 2341lbs
Old 01-19-2020, 03:59 PM   #204
SuperTom
SuperTom's Avatar
Chase Bays Clutch line
Today installed the Chase Bays Clutch line. This removes the factory brackets with one clean line to the clutch slave. Also saves .25lbs off the front
CHase bays
Stock
Installed
Old 01-19-2020, 04:42 PM   #205
SuperTom
SuperTom's Avatar
Also installed some 86 Cam Solenoid covers today, and converted a majority of the bolts in the engine bay to titanium
Cam solenoid covers + Radiator cap cover added .5 lbs
Converting all the bolts to titanium -.5
I weight a batch of titanium bolts, then the stock bolts afterwards for a .25 pounds savings. I did this process 2x hence the -.5 lbs
Basically the titanium bolts are half the weight of stock
Titanium "Metal of the Gods!!"
Stock bolt
Titanium
Bag of stock afterwards
Bags of titanium
Rusted Cam solenoids
Nice!
Everything combined didn't gain or lose weight but the engine bay now looks great. The pics came out a bit blurry but those titanium bolts really shine in real life
new2subaru (01-19-2020), q335r49 (03-03-2020)
Old 01-22-2020, 06:53 AM   #206
scottman
scottman's Avatar
Drives: 13 mt fr-s
Dude.
Very inspiring work!
All your pics and documentation were very helpful.
You got me to pull the trigger on that smaller willwood 4pot too. Cant wait until spring.
Have you considered a brake booster delete?
scottman is offline   Reply With Quote
The Following User Says Thank You to scottman For This Useful Post:
SuperTom (01-22-2020)
Old 01-22-2020, 09:18 AM   #207
SuperTom
SuperTom's Avatar
Originally Posted by scottman View Post
Dude.
THanks!
You will love that loss of rotating mass upfront with the Smaller Wilwood
Yes I really want to do that BBD so bad. Im having trouble finding any real documentation on deleting the ABS.
I know you could just rip it all out and have a bunch of lights/possible limp mode.
Im talking about keeping the black box to trick the computer/ remove everything else. Anything Ive found is vague information
I saw a pic from one guy who rerouted all the ABS back into itself. It looked like a convoluted mess. I want all the ABS piping gone/ Just keeping the black box.
Simple and Light is the goal with this build
The Following User Says Thank You to SuperTom For This Useful Post:
scottman (01-22-2020)
Old 01-25-2020, 06:57 PM   #208
SuperTom
SuperTom's Avatar
Whats your favorite type of cheese?
Mine is Swiss Cheese!
A lot of work to save .5 lbs but it was free
Found it easier to drill smaller holes than bigger holes through the Steel it also keep material around each hole
Original is 3lbs 1oz, got it down to 2lbs 9oz
new2subaru (01-25-2020), q335r49 (03-03-2020)
Old 01-25-2020, 09:43 PM   #209
new2subaru
Weight Weenie
Drives: 15 FR-S
Nice!
The Following User Says Thank You to new2subaru For This Useful Post:
SuperTom (01-25-2020)
Old 01-26-2020, 07:37 PM   #210
SuperTom
SuperTom's Avatar
Seibon Hood
just installed my Seibon Dry Carbon Vented hood today!
I know you may be saying why didn't I go with the MPH hood which is lighter and I know functional
- I really don't like the square box design of his vent looks, Looks better on BRZ's with the boxy front bumper
- Since everything else is Seibon on my build I didn't want different CF's so close to each other.
- These parts are now closeout so I didn't want to miss my chance and the prices are dropped.
- If and when I do the roof I will go with MPH's since its way lighter than the Seibon if Im going to go through all that trouble. It wont be close to the other parts if there is a diffrence
So on to it looks like this saves 2.5lbs over stock and that includes the hood pins
Seibon Hood = 13.5lbs
Hood Pins = .5lbs
Stock hood with insulation = 16.5
Stock hood
Some installed shots. It was cloudy out so you cant see the weave too well. Fitment was great
New Vehicle weight 2338.5 LBS
Iceman (01-27-2020), new2subaru (01-27-2020)
mothespaceman: 14' Satin White BRZ Build! mothespaceman Member's Car Journals 25 09-19-2014 06:30 PM
White BRZ Limited Build Thread NoFlush Member's Car Journals 4 05-10-2014 03:04 PM
white trd 2013 build Pcharliep04 Member's Car Journals 0 04-24-2014 02:25 AM
Build-thread White Wasp FR-S by Mit_Peid mit_peid Member's Car Journals 7 01-05-2014 08:47 PM
White GT manual Jan Build availlable 86•BRZ AUSTRALIA 2 01-02-2013 12:45 AM
