#127 |
JDM Spirit of the '90s
Drives: 2015 FR-S Turbo
Nice parts! When I look at this thread the JDM Revolution 86 comes to mind.
| The Following User Says Thank You to Raven86Project For This Useful Post: | SuperTom (10-06-2018) |
#128 |
Drives: C5 Corvette, '17 Toyota 86, Jeep XJ
#129 | |
It weights 2173lbs (988kgs) ![]()
#130 |
#131 |
Drives: 2012 GT86 EU-spec
Love your dedication!
| The Following User Says Thank You to Vin For This Useful Post: | SuperTom (10-14-2018) |
#132 |
Finally had nice weather on a day off to complete one of the doors. Took me most of the day to transfer everything over. I believe I can cut a lot of time out when I do the passenger side.
Had a few holes for clips I had to open a bit with a Dremel. But most important was the overall fitment was perfect!! Bolted up the first time no adjustments made ![]() ![]() Getting close to sunset finished in time ![]() Stock door was heavy as fk. Not 50lbs I had heard, my scale says 43lbs stripped ![]() So after I get the passenger side done this will be good for 64.5lbs weight reduction off the car. Side note one of the bottom window stoppers is a big heavy piece of steel. I could easily make it out of aluminum and chop another pound off each door. New car weight should be ~2375.25! |
| The Following User Says Thank You to SuperTom For This Useful Post: | Clipdat (10-19-2018) |
#133 |
Driver
Drives: 16 Subaru BRZ
good stuff, you going to paint match the doors or just leave them be?
BRZ Build Thread
See you space cowboy... |
#134 |
#135 |
Driver
good deal, the doors worth the price?
BRZ Build Thread
#136 | ||
Proud of BOXER
Drives: Subaru Boxer
Paint is heavy, leave them unpainted for weight savings!
| The Following User Says Thank You to Clipdat For This Useful Post: | SuperTom (12-03-2019) |
#137 |
Got lucky and happened to be browsing the Siebon site some of their dry parts were heavily discounted. Plus a found a great online code got both the trunk and doors for ~$3k shipped. They may have been selling off stock I don't see them listed anymore, only the wet which is much heavier and more for looks
#138 |
| The Following User Says Thank You to SuperTom For This Useful Post: | HachiRokuX (12-31-2018) |
#139 |
Finished passenger side a few pics of the inside. Also removed these black heavy chunks of steel from inside the door. I thought they may be a window stopper but after moving the windows up and down they do nothing that I can see -1 Free pound!
Everything swapped ![]() Finished! ![]() Heavy chunks of steel 1/2 lb each
| The Following 2 Users Say Thank You to SuperTom For This Useful Post: | Clipdat (12-07-2019), new2subaru (10-24-2018) |
#140 |
Also have a new weight loss mod im going to be working on will take my time. This sucker is heavier than I expected. Got a used Dash bar for $100, it weights 17lbs. Going to swiss cheese the FK out this thing!
| mothespaceman: 14' Satin White BRZ Build! | mothespaceman | Member's Car Journals | 25 | 09-19-2014 06:30 PM |
| White BRZ Limited Build Thread | NoFlush | Member's Car Journals | 4 | 05-10-2014 03:04 PM |
| white trd 2013 build | Pcharliep04 | Member's Car Journals | 0 | 04-24-2014 02:25 AM |
| Build-thread White Wasp FR-S by Mit_Peid | mit_peid | Member's Car Journals | 7 | 01-05-2014 08:47 PM |
| White GT manual Jan Build availlable | 86•BRZ | AUSTRALIA | 2 | 01-02-2013 12:45 AM |
