Old 10-14-2017, 10:58 PM   #15
Weigaldo
Weigaldo's Avatar
Drives: 2016 Steel AT FRS
Get tuner to make these changes and reflash id even go to max base idle speed of 1200 instead of 1400. If you dont alter the Maf offset after start tables car will continue to idle fast at startup. These changes wont effect rest of tune ust startup, but you would ned to reflash
Steve (if you find this), are the 1 and 2 rows on the maf correction tables the ones you mentioned in another thread about building in more correction at colder temps? Would I be able to get away with 8's across the board or should I do that for Chicago weather?
Weigaldo is offline   Reply With Quote
Old 10-15-2017, 04:50 AM   #16
Kodename47
Kodename47's Avatar
Drives: UK GT86
Yes, you could try that. I think mine are now the same on all rows.
.: Stealth 86 :.
Kodename 47 DJ:
The Following User Says Thank You to Kodename47 For This Useful Post:
Weigaldo (10-15-2017)
Old 10-15-2017, 08:34 AM   #17
Weigaldo
Weigaldo's Avatar
Thanks! I'm going to try it out today!
Old 10-15-2017, 03:15 PM   #18
Dr. BRZ
Dr. BRZ's Avatar
Drives: 2013 WR Blue Pearl BRZ Limited 6MT.
Wtf guys?! You don’t need to do all that lol. Right when you turn on the car, reverse the car for like 3 seconds and it will silenced out the cold start. So simple!
Dr. BRZ is offline   Reply With Quote
Old 10-15-2017, 04:34 PM   #19
churchx
churchx's Avatar
Drives: 2014 GT86
The colder ambient temps are, the longer cold starts. I can easily see it becoming issue with some louder aftermarket exhausts when it takes 5-10minutes in winter when you brush off snow/scrape off ice/maybe even showel off snow off road, to make it driveable at all. 3sec in reverse when it's below -20C and parallel parked between other cars?
Old 10-16-2017, 01:55 AM   #20
Dr. BRZ
Dr. BRZ's Avatar
Just do it and don’t complain.
Do e85 cold starts damage engine? jaorocks1 Engine, Exhaust, Transmission 20 12-02-2015 06:12 AM
Random tip - cold starts Dammod AFRICA 34 09-22-2015 02:38 AM
White Smoke cold start up in Cold Weather (turbo cars) whitefrs Forced Induction 17 09-25-2013 06:05 PM
Cold morning starts coldy CANADA 43 04-23-2013 03:30 PM
Issue: Cold starts jesseps CANADA 7 11-24-2012 12:26 PM
